Adapter DAC AL5686 Male Lightning to Female Jack 3.5mm 32bit 384kHz
This TC35C DD adapter for smartphone is composed of a male Lightning connector and a female 3.5mm jack. It also includes a Realtek AL5686 DAC for efficient conversion of the audio signal for a clear and precise reproduction, while supporting high resolution streams, up to PCM 32bit 384kHz. The robust connector body is made of CNC machined aluminum. Its practical "T" shape allows for a compact design.
Be sure to plug in the headphones before connecting the DAC to the Apple device.
| Specifications | |
| Product type | Adapter and DAC |
| Connectors | 1x Male Lightning 1x Female Jack 3.5mm |
| DAC Chip | Realtek AL5686 |
| Supported sampling rates | PCM up to 32bit 384kHz |
| Frequency response | 20Hz - 20kHz |
| Output power | 30mW @ 32Ω |
| Dynamic range | > 110dB |
| THD+N | < -92dB |
| SNR | > 120dB |
| General | |
| Dimensions | 16.6 x 16.2 x 9.6mm |
| Weight | 3.5g |
| Input | Lightning |
| Output | Jack 3.5mm |
| DAC / ADC Chip | AL5686 |
| Max sampling rate | 384kHz |
| Color | Blue |
| Color | Black |
| Networking | No |
| Remote Control | No |
| Contacts Material (Connector) | N/A |
