DDHIFI TC44PRO M3 Portable DAC
With the TC44PRO M3, ddHifi presents a portable DAC based on two CS43198 DAC chips from Cirrus Logic with a sleek design and a 3.5mm and 4.4mm jack output. This small portable DAC is capable of handling a signal up to PCM 32bit 384kHz and DSD256, and is designed to accompany you wherever you go and adapt to any situation.
Reference : 20690
89,00 €tax incl.
74,17 € tax excl.
ddHiFi TC44PRO M3 Portable DAC 2x CS43198 32bit 384kHz DSD256
DDHiFi TC44PRO M3 : Front view
With the TC44PRO M3, ddHifi presents a portable DAC based on two CS43198 DAC chips from Cirrus Logic with a sleek design and a single-ended 3.5mm and balanced 4.4mm jack output. This small portable DAC is capable of handling a signal up to PCM 32bit 384kHz and DSD256, and is designed to accompany you wherever you go and adapt to any situation.
ddHiFi TC44PRO M3: Dual Cirrus Logic chips
For its digital-to-analogue conversion, the TC44PRO M3 relies on two Cirrus Logic CS43198 DAC chips, providing signal support up to PCM 32bit 384kHz and DSD256. In terms of amplification, the Cirrus Logic chips deliver an output power of 90mW at 32Ω single-ended and 120mW at 32Ω balanced.
DDHiFi TC44PRO M3 : Internal circuit
DDHiFi TC44PRO M3 : 3.5 and 4.4 mm jack output
ddHiFi TC44PRO M3: 3.5 mm + 4.4 mm Jack output
To ensure broad compatibility with the widest range of headphones and earphones, the TC44PRO M3 incorporates a single-ended 3.5mm jack and balanced 4.4mm jack output, allowing you to enjoy the benefits of balanced output while ensuring that you can always use this device whatever the situation and whatever equipment you have access to.
ddHiFi TC44PRO M3: Aesthetically polished
The TC44PRO M3 adopts the aesthetic lines of ddHiFi's Surface product series. Its textured, angular aluminium alloy body creates a harmonious balance between minimalism and sophistication.
DDHiFi TC44PRO M3 : 3/4 view
DDHiFi TC44PRO M3 : Blue LED
ddHiFi TC44PRO M3: LED indication
To ensure that you always know at a glance which sampling rate is being used, the TC44PRO M3 is equipped with a colour-coded LED to indicate which lossless format is being used: Blue for PCM and Green for DSD.
ddHiFi TC44PRO M3: Leather strap
To take you anywhere, the TC44PRO M3 comes with a stylish leather strap, making it easy to carry or attach anywhere.
DDHiFi TC44PRO M3 : Leather strap
Product typePortable DAC
Connectors1x Male USB-C
1x Female balanced 4.4mm jack
1x Female single-ended 3.5mm jack
DAC chips2x CS43198
Output powerBalanced: 120mW @ 32Ω
Single-ended: 90mW @ 32Ω
Signal-to-noise ratio (SNR)125dB
Dynamic range120dB
Total harmonic distortion (THD)-110dB
Supported sampling ratesPCM: up to 32 Bit 384kHz
Native DSD: DSD64 / DSD128 / DSD256
Dimensions30.4 x 12.4 x 17mm
Weight11g
ColorGrey
Package1x ddHiFi TC44PRO M3
1x Leather strap
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rate384kHz
Max sampling rateDSD256
ColorGray
DDHIFI TC44PRO M3 Portable DAC 2x CS43198 32bit 384kHz DSD256
With the TC44PRO M3, ddHifi presents a portable DAC based on two CS43198 DAC chips from Cirrus Logic with a sleek design and a 3.5mm and 4.4mm jack...
