IBASSO NUNCHAKU Portable DAC Headphone Amplifier
The iBasso Nunchaku is a balanced portable DAC and headphone amplifier based on two CS43198 chips coupled to an FPGA to handle signal conversion up to 32bit PCM and DSD512. As for the amplification stage, you can choose between operation using power tubes for a warm sound or more traditional Class AB operation for a more neutral sound with improved dynamics. The Nunchaku has an output power of 2x525mW at 32Ω, which is more than enough to drive any earphones and most headphones on the market.
Reference : 20512
299,00 €tax incl.
249,17 € tax excl.
iBasso Nunchaku Portable DAC Tube Headphone Amplifier 2xCS43198 32bit 768kHz DSD512
iBasso Nunchaku : 3/4 view
iBasso Nunchaku: Raytheon power tubes
The Nunchaku uses two Raytheon JAN6418 power tubes, renowned for their compact size, low power consumption and operating stability. Unlike most portable products that use 9V or 12V power supplies, the Nunchaku uses a 22.5V anode power supply specially designed for the JAN6418 tubes. This higher voltage provides furthermore flexibility, ensuring that the tubes operate at their full potential. The two JAN6418 tubes give the Nunchaku a distinctive analogue sound, with a warm, relaxed and smooth tone that's a pleasure to listen to.
iBasso Nunchaku : power tubes
iBasso Nunchaku: Class AB mode
Furthermore, in addition to the TUBE output mode, the Nunchaku also features a Class AB amplifier circuit, allowing users to switch between these two output modes to enjoy two distinct sound profiles. In TUBE mode, the sound is soft and warm, with the characteristic timbre of this technology. Class AB mode, on the other hand, offers a more neutral tone as well as greater resolution and improved dynamics.
iBasso Nunchaku: operating diagram of amplification modes
iBasso Nunchaku : amplifier stage
iBasso Nunchaku: 2x525mW amplification
Instead of an all-in-one amplifier chip, the Nunchaku uses a set of 2 OPAs and 4 BUF634A buffers from Texas Instruments for a total output power of 525mW+525mW at 32Ω, enabling it to drive all earphones and a good proportion of headphones on the market. Furthermore, this structure provides excellent efficiency with power consumption not exceeding 120mA/5V in TUBE mode and 100mA/5V in Class AB mode.
iBasso Nunchaku: Dual DAC CS43198
The Nunchaku's conversion stage is no slouch either, using two top-of-the-range CS43198 chips from Cirrus Logic, which, when coupled with the FPGA developed in-house by iBasso, enable conversion of a signal up to 32bit 768kHz PCM and DSD512, all in a symmetrical architecture.
Furthermore, the Nunchaku is equipped with a Femtosecond clock developed by iBasso, guaranteeing perfect signal synchronisation.
iBasso Nunchaku : Dual DAC CS43198
iBasso Nunchaku : JRC volume control
iBasso Nunchaku: JRC volume control
The Nunchaku's TUBE mode also incorporates a hardware JRC volume control, allowing the DACs to operate at their maximum output levels in order to give the tubes the most powerful signal possible to amplify. It is this amplified signal that is then lowered, reducing the background noise at the same time, resulting in a drastic improvement in the signal-to-noise ratio (SNR).
iBasso Nunchaku: OLED screen
The Nunchaku boasts a magnificent 0.96-inch OLED screen, so you can see information such as volume, mode, sample rate and gain level at a glance.
iBasso Nunchaku : OLED screen
iBasso Nunchaku : PORON Suspension
iBasso Nunchaku: PORON Suspension
In order to greatly reduce the impact that movements of the device could have on sound reproduction in TUBE mode, iBasso has fitted the Nunchaku with a suspension based on PORON material, which effectively absorbs shocks. The tubes protected in this way are much less sensitive to movement and shocks, ensuring quality reproduction, even when you're on the move.
Product typePortable DAC
Mobile headphone amplifier
Input1x USB-C
Outputs1x Balanced 4.4mm jack
1x Single-ended 3.5 mm jack
Tubes2x Raytheon JAN6418
DAC2x CS43198
Supported sampling ratesPCM 32bit 768kHz
DSD512 Native
Balanced 4.4mm jack output (Class AB mode)
Total harmonic distortion more noise (THD+N)-119dB (0.00011%) @1kHz 200Ω
Output voltageLow gain : 2.8Vrms
High gain : 4.1Vrms
Output power450mW @ 32Ω
Signal-to-noise ratio (SNR)130dB
Dynamic range130dB
Crosstalk145dB
Frequency response15Hz-40kHz (±0.5dB)
Balanced 4.4mm jack output (TUBE mode)
Output voltageLow gain : 2.3Vrms
High gain : 4.5Vrms
Output power525mW @ 32Ω
Signal-to-noise ratio (SNR)107dB
Dynamic range110dB
Crosstalk82dB
Frequency response15Hz-40kHz (±1dB)
Single-ended 3.5mm jack output (Class AB mode)
Total harmonic distortion more noise (THD+N)-115dB (0.00017%) @ 1kHz 600Ω
Output voltageLow gain : 1.4Vrms
High gain : 2Vrms
Output power125mW @ 32Ω
Signal-to-noise ratio (SNR)125dB
Dynamic range125dB
Crosstalk116dB
Single-ended 3.5mm jack output (TUBE mode)
Output voltageLow gain : 1.15Vrms
High gain : 2.25Vrms
Output power150mW @ 32Ω
Signal-to-noise ratio (SNR)112dB
Dynamic range112dB
Crosstalk82dB
Dimensions65 x 34.6mm
Weight50g
ColorSilver
Package1x iBasso Nunchaku
1x Protective case
1x USB-C to USB-C cable
1x Câble USB-C vers Lightning
1x USB-C to USB-A adapter
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
ClassClass A / AB
ClassTube amp
IBASSO NUNCHAKU Portable DAC Tube Headphone Amplifier 2xCS43198 32bit 768kHz DSD512
The iBasso Nunchaku is a balanced portable DAC and headphone amplifier based on two CS43198 chips coupled to an FPGA to handle signal conversion up...
