The Kiwi Ears Allegro Mini portable DAC / headphone amplifier is a small device that can support high-resolution streams up to PCM 32bit 384kHz and DSD128, and is capable of delivering up to 30mW under 32Ω. This means you can enjoy high-resolution files and drive a wide range of headphones and earphones available on the market. The sound reproduction offered by the Allegro Mini is clear and precise in the treble, with deep, immersive bass for a rich, pleasant listening experience. Source connection is via USB-C port and output via single-ended 3.5mm jack or balanced 4.4mm jack.
Product type | Portable DAC / Headphone Amplifier |
Input | 1x USB-C |
Outputs | 1x Jack 3.5mm 1x Balanced Jack 4.4mm |
Supported sample rates | PCM 32bit 384kHz, DSD128 |
THD+N | < 0.004% (@32 Ohms) |
Output power | 2x30mW (32Ω, THD+N < 1%) |
SNR | ≥ 114dB (@32 Ohms, A-Weighted) |
Frequency response | 20Hz–20kHz (±0.2dB) |
Background noise | < 3μV (A-weighted) |
Color | Silver |
Package | 1x Kiwi Ears Allegro Mini |
Input | USB |
Output | Jack 3.5mm |
Output | Jack 4.4mm |
DAC / ADC Chip | NC |
Max sampling rate | 384kHz |
Max sampling rate | DSD128 |
Color | Silver |
Class | N/A |
Networking | No |
Remote Control | No |
