The Kiwi Ears Allegro Pro portable DAC / headphone amplifier is a small device based on the use of two ES9603 headphone amp chips. It supports high-resolution streams up to PCM 32bit 384kHz and DSD128, and is capable of delivering up to 170mW under 32Ω. This means you can enjoy high-resolution files and drive a wide range of headphones and earphones available on the market. The sound reproduction offered by the Allegro Pro is clear and precise in the treble, with deep, immersive bass for a rich, pleasant listening experience. Source connection is via USB-C port and output via single-ended 3.5mm jack or balanced 4.4mm jack. Added to this is the possibility of choosing three distinct operating modes: a Hi-Fi mode for high-fidelity listening, a Gaming mode for immersive rendering, and a Movie mode for a cinematic experience. Each mode is accessed via a button on one side of the device, identifiable by an RGB LED.
Product type | Portable DAC / headphone Amplifier |
OPA | 2x ES9603 |
Input | 1x USB-C |
Outputs | 1x Single-ended Jack 3.5mm 1x Balanced Jack 4.4mm |
Supported sampling rates | PCM up to 32bit 384kHz, DSD up to DSD128 |
THD+N | < 0.006% (@32Ω) |
Output power | Jack 3.5mm: 68mW @ 32Ω (THD+N <1%) Balanced Jack 4.4mm: 170mW @ 32Ω (THD+N <1%) |
SNR | ≥ 113dB (@ 32Ω, A-Weighted) |
Frequency response | 20Hz–40kHz |
Operating mode indicator | Blue: Gaming mode Red: Music mode Green: Cinema Mode |
Color | Argent |
Package | 1x Kiwi Ears Allegro Pro |
Input | USB |
Output | Jack 4.4mm |
Output | Jack 3.5mm |
DAC / ADC Chip | NC |
Max sampling rate | 384kHz |
Max sampling rate | DSD128 |
Color | Silver |
Class | N/A |
Networking | No |
Remote Control | No |
