MOONDROP ECHO-B Adapter DAC USB-C to Balanced Jack 4.4mm
The Moondrop Echo-B is a compact, high-performance USB-C to 4.4mm balanced jack adapter, designed to deliver a high-resolution audio experience with ease. It incorporates a DAC/headphone amplifier chip capable of supporting sampling rates up to PCM 32bit 384kHz.
4.0 / 5
Reference : 20603
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 04-07-2025.
Moondrop Echo-B Adapter DAC Headphone Amplifier USB-C to Balanced Jack 4.4mm 32bit 384kHz
Photo of MOONDROP ECHO B DAC adapter
The Moondrop Echo-B is a compact, high-performance USB-C to 4.4mm balanced jack adapter, designed to deliver a high-resolution audio experience with ease. It incorporates a DAC/headphone amplifier chip capable of supporting sampling rates up to PCM 32bit 384kHz. Thanks to its plug and play compatibility with many operating systems via the UAC 2.0 protocol, the Echo-B is extremely easy to use. It guarantees clear, precise sound reproduction, with a THD+N of just 0.001% and an SNR of 117dB. Added to this is the possibility of DSP tuning via the Moondrop app for customized sound rendering.
Advantages of MOONDROP ECHO B
Product typeAdapter / DAC USB-C to jack 4.4mm
Connectors1x Male USB-C
1x Female balanced Jack 4.4mm
SNR117dB (A-WT)
Dynamic range120dB (A-WT)
THD+N0.001%
DSP settingsVia Moondrop app
OS compatibilityWindows, MAC OS, Android, IOS
Package1x Moondrop Echo-B
OutputJack 4.4mm
DAC / ADC ChipNC
Max sampling rate384kHz
ColorSilver
ConnecticMale & Female
ConnectorJack 4.4mm
ConnectorUSB-C
Remote ControlControl app
2 reviews
Grésille
Bonne puissance et belle qualité sonore, mais des grésillements sont audibles sur certaines bass
This review has been posted for MOONDROP ECHO-B Adapter DAC Headphone Amplifier USB-C to Balanced Jack 4.4mm 32bit 384kHz
Parfait !
Combiné avec mes Truthear Nova, j´ai enfin la puissance nécessaire pour écouter mes musiques pleinement.
Les bass sont puissantes, le fond noir et intéressant, et le rapport qualité-prix est parfait.
The Moondrop Echo-B is a compact, high-performance USB-C to 4.4mm balanced jack adapter, designed to deliver a high-resolution audio experience...
