ROSESELSA RS9029 Portable DAC
New
The RS9029 from Roseselsa is a portable DAC based on an ESS SABRE ES9039Q2M DAC chip for digital/analogue conversion up to 32 bit 384kHz PCM and DSD256. For furthermore flexibility, it has two jack outputs, one 3.5mm single-ended and one 4.4mm balanced. Furthermore, it offers an output power of up to 300mW at 32Ω, making it compatible with most earphones and headphones on the market.
Reference : 20739
89,00 €tax incl.
74,17 € tax excl.
Roseselsa RS9029 Portable DAC ES9039Q2M 32bit 384kHz DSD256
Roseselsa RS9029 : Front view
Roseselsa RS9029 : High-end ESS SABRE DAC chip
The RS9039 takes its name from the SABRE ES9039Q2M DAC chip on which it is based. This top-of-the-range chip from ESS is equipped with Hyperstream IV technology and enables this dongle to support a signal up to 32bit 384kHz PCM and native DSD256.
Roseselsa RS9029 : DAC chip
Roseselsa RS9029 with the number 300 on it
Roseselsa RS9029 :Puissance de sortie de 300mW
The RS9029 offers an output power of 300mW at 32Ω balanced and 240mW at 32Ω single-ended, enabling it to deliver rich, deep bass reproduction with the majority of headphones and earphones on the market.
Roseselsa RS9029 : Aluminium body and dual output
The RS9029 benefits from a matt-finish aluminium body that's as lightweight as it is solid, ensuring a sober aesthetic and unfailing durability. Furthermore, for maximum flexibility, the RS9029 offers two jack outputs, one 3.5mm and one 4.4mm, giving you the choice of balanced and single-ended output.
Roseselsa RS9029 : Back view and jack outputs
Roseselsa RS9029 : LDO microchip
Roseselsa RS9029 : Virtually no background noise
Fitted with low-noise LDO power chips and boasting an exceptional signal-to-noise ratio of 126d8, the RS9029 has virtually no background noise, allowing even the subtlest details of your music to stand out clearly.
Product typePortable DAC
Input1x USB-C
Output1x Jack 3.5mm
1x Jack 4.4mm
DAC chip1x ES9039Q2M
Supported sampling ratesPCM 32bit 384kHz
DSD256
Output powerSingle-ended : 240mW @32Ω
Balanced : 300mW @32Ω
Total harmonic distortion (THD)0.0003% @1kHz 32Ω
Signal-to-noise ratio (SNR)126dB @1kHz 32Ω
Dimensions48 x 22 x 12mm
Weight15g
ColorGrey
Package1x Roseselsa RS9029
2x USB-C cable
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9039Q2M
Max sampling rate384kHz
Max sampling rateDSD256
ColorGray
ROSESELSA RS9029 Portable DAC ES9039Q2M 32bit 384kHz DSD256
The RS9029 from Roseselsa is a portable DAC based on an ESS SABRE ES9039Q2M DAC chip for digital/analogue conversion up to 32 bit 384kHz PCM and...
