SHANLING UA4 Balanced Portable DAC Silver
The Shanling UA4 portable balanced DAC is an easily transportable and relatively affordable solution for enjoying high-resolution audio streams in all circumstances. It features high-end components such as an ES9069Q DAC chip, enabling it to support 32bit 768kHz PCM, native DSD up to DSD512 and MQA streams.
Reference : 18612
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 26-06-2025.
SHANLING UA4 DAC Portable Balanced DAC USB-C ES9069Q 32bit 768Khz DSD512 MQA Silver
Photo of SHANLING UA4
The Shanling UA4 portable balanced DAC is an easily transportable and relatively affordable solution for enjoying high-resolution audio streams in all circumstances. It features high-end components such as an ES9069Q DAC chip, enabling it to support 32bit 768kHz PCM, native DSD up to DSD512 and MQA streams. Two RT6863 headphone amplifier chips give it an output power of up to 211mW @ 32 ohm. A small display and three control buttons let you easily access settings and control playback. Input is via USB-C port and two outputs are available: 3.5mm jack and 4.4mm balanced jack.
Shanling UA4: a practical interface
The Shanling UA4 portable DAC features three buttons for adjusting the volume and play/pause of your audio tracks. In addition, a small screen lets you navigate the settings menu and display information about the track currently playing.
SHANLING UA4 screen
SHANLING UA4 compatibility
Shanling UA4: great compatibility
The USB port supports UAC1.0 and UAC2.0 standards and is compatible with Windows, Mac, Android, IOS or even a games console such as a Nintendo Switch.
Product typePortable DAC
DAC chipES9069Q
Amplification chip2x RT6863
Input1x USB-C
Output1x Single-ended 3.5mm jack
1x Balanced 4.4mm jack
Supported sample ratesPCM 32bit 768kHz, native DSD up to DSD512, MQA
Output power211mW @ 32 Ohm
Gain adjustementHigh et Low
Digital filters8
3.5MM JACK OUTPUT MEASUREMENT
Output power2.1V @ 32Ω
Frequency response20Hz - 40kHz (-0.7dB)
THD+N0.0008% @ 32Ω (A-Weight @1.5V)
Dynamic range120dB @ 32Ω (A-Weight)
Channel separation124dB @ 32Ω (A-Weight)
SNR124dB@32Ω (A-Weight)
Output impedance< 0.4Ω
BALANCED 4.4MM JACK OUTPUT MEASUREMENT
THD+N0.0006% @ 32Ω (A-Weight @1.5V)
Dynamic range116dB @ 32Ω (A-Weight)
Channel separation106dB @ 32Ω (A-Weight)
SNR120dB@32Ω (A-Weight)
Output impedance< 0.8Ω
Dimensions60 x 25 x 11mm
ColorSilver
Weight20.8g
Package1x Shanling UAC4 portable DAC
1x USB-C to USB-C cable
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9069Q
Max sampling rateMQA
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
SHANLING UA4 Portable Balanced DAC USB-C ES9069Q 32bit 768Khz DSD512 MQA Silver
The Shanling UA4 portable balanced DAC is an easily transportable and relatively affordable solution for enjoying high-resolution audio streams in...
