SHANLING UA5 DAC Portable Headphone Amplifier Balanced 2x ES9038Q2M RE6863 32bit 768kHz DSD512 Black
The Shanling UA5 is a high performance portable DAC and headphone amplifier. Its digital/analog conversion stage is based on a pair of ESS ES9038Q2M DACs, allowing it to efficiently decode the audio stream, ensuring highly accurate sound reproduction. This architecture also allows it to read high resolution audio streams, in PCM up to 32bit 768kHz or in DSD up to DSD512. Its amplification stage is entrusted to a Ricore RE6863 chip.
By buying this product you get 23 loyalty points
Reference : 15948
239,00 €tax incl.
199,17 € tax excl.
Shanling UA5
Shanling UA5 DAC Amplificateur Casque Portable Symétrique 2x ES9038Q2M RE6863 32bit 768kHz DSD512 Noir
As for the design, the UA5 is extremely compact, allowing it to slip easily into a pocket. It is also equipped with a 1.44" OLED screen displaying the settings of the device. A wheel placed on the edge of the UA5 allows it to easily and accurately adjust the volume level.
As for the power supply, the UA5 offers two operating modes. It can either be powered directly via the USB port, or operate in hybrid mode, in which case the conversion and amplification stages are powered by the internal 200mAh battery.
Finally, for its connectivity, we find in input a USB-C port and in output, both an unbalanced output on Jack 3.5mm and a balanced output on Jack 4.4mm
Product typePortable DAC and headphone amplifier
Input1x USB-C
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
DAC Chip2x ESS ES9038Q2M
Amplification chipRicore RE6863
Output powerSingle-ended : 135mW @ 32Ω
Balanced : 210mW @ 32Ω
DSD up to DSD512
OS CompatibilityAndroid
Windows
Mac
iOS
UAC SupportUAC 2.0
UAC 1.0
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipES9038Q2M
Max sampling rateDSD512
Max sampling rate768kHz
The Shanling UA5 is a high performance portable DAC and headphone amplifier. Its digital/analog conversion stage is based on a pair of ESS...
