AUDIO-GD PRECISION 3 Balanced Class A Amplifier ACSS 2x 70W / 8 Ohm
The PRECISION 3 of Audio-GD is a power amplifier with a balanced Class A input and gain stage with a neat design that offers excellent audio performance.
KEY POINTS :
  • Class A discrete entrance floor
  • 40,000μF of capacitors
  • 2x70W 8 Ohms and 2x13W under 40 Ohm
  • 0.1 KOA resistors and WIMA capacitors
4.9 / 5
By buying this product you get 56 loyalty points
Reference : 12352
569,00 €tax incl.
474,17 € tax excl.
Including 1,00 € for green tax
Available
Shipping date: 26-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
Power Amplifier / Class A / ACSS Input Stage
Audio-GD PRECISION 3
An amplifier at the price quality ratio simply unbeatable ...
Audio-GD once again presents their prowess in terms of technology and electronic design with this PRECISION 3 amplifier with 100% discrete architecture
The famous brand of high fidelity audio offers us here an amplifier in the most accomplished form possible with outstanding performance:
It delivers 2x 70 under 8 Ohm and 2x15W under 40 Ohm (For headphones), being completely discreet.
The input stage is in Class A, without feedback on the ACSS input, and letting the DC into the RCA.
Built without OPA, no capacitors on the signal path.
The "Diamond Cross" output stage without negative feedback avoids crossover distortion, thus competing with Class A amplifiers.
  • 4 transistors of 150W / 15A each
  • Oversized transformer with 40,000μF NOVER filter
  • KOA 0.1% High Precision Resistors and WIMA Capacitors
  • Separate Power / Amplification Section to Eliminate Electromagnetic Radiation
Each product of the brand is scrupulously tested from every angle with one of the most powerful systems in the world:
the Audio Analyzer 2700 Series from Audio Precision.
This power amplifier is the natural companion of the following AUDIO GD DAC preamps:
NFB 28.28, NFB29.28, NFB28.38, NFB29.38.
A simple connectivity, simply effective
The PRECISION 3 has 2 analog inputs: 1x RCA and 1x ACSS. The output is of course on 2 terminal blocks HP, where you just have to connect your speakers to enjoy.
The result is simple: great musicality, thanks to an exceptional dynamic and a rich sound extremely detailed in every respect.
PRECISION 3 Audio-GD
Mono XLR Bridgeable Mode to RCA or ACSS
The Mono bridge mode of the PRECISION 3 allows you to output 1X200W per block. It is imperative to have a pre-amplification with balanced outputs XLR classic or with a preamplifier DAC AUDIO GD series NFB . You just have to connect your speakers to enjoy as shown below. Nevertheless, it is necessary to use AUDIO GD proprietary modulation cables available here from XLR to RCA X4 or ACSS to ACSS X4 .
Audio GD precision 3 bridge RCA
WIRING BRIDGE MONO preamp XLR to PRECISION 3 in ACSS
WIRING BRIDGE MONO XLR preamp to PRECISION 3 in RCA
It is also possible to bi-amplify the output of a DAC AUDIO GD NFB preamp in ACSS or RCA via a classic preamp:
CABLAGE BI-AMPLIFICATION ACSS to ACSS.
WIRING
BI-AMPLIFICATION RCA to RCA.
Do not forget to remove the straps on the speaker terminals.
A HiFi amplifier clean and doing more than his job
Class A Symmetric / ACSS
This PRECISION 3 is equipped with a high quality transformer, very high quality Nover capacitors, and very high performance MJL1302 / 3281 transistors for the output stage.
This amplifier is also designed around a purely symmetrical Class A ACSS discrete circuit, with separate power supply to avoid any interference or electromagnetic interference on the signal.
Audio-GD PRECISION-3
Class A Class A has the particularity of having its active components still in conduction. The quiescent current remains higher than the output current, l thus imitating harmonic distortion. The signal coming out of the Precision 3 is therefore of excellent quality, due to the absence of this famous crossing distortion of the alternations of the sinusoids.
ACSS Technology
Audio-GD has its own technological signature, called ACSS for "Audio-GD Current Signal System".
This technology allows a simpler and more direct input stage, reducing distortion.
Thanks to the expertise and know-how of the firm, this technology offers a less colorful sound, more detailed, and unparalleled neutrality.
ACSS
alue "> 1x RCA / 1x ACSS
THD <0.003%
Output voltage 25V
Gain 25dB
Frequency response 20Hz - 20kHz (at 0.5dB)
crosstalk <-100dB
inputs
Exits 2x Stereo Speaker Terminals
Signal to noise ratio > 115dB
Output power 2x70W under 8 Ohm / 2x15 under 40 Ohm
Input sensitivity 1.5V (RCA) / 2mA (ACSS)
Various
Consumption 30W
Weight 8kg
Housing material 100% Aluminum
Color Black
Dimensions 240x360x80mm
Accessories 1x Power cable
MaterialAluminium
ColorNoir
StructureAluminium
ClassClass A / AB
Puissance Totale50-100 Watts
Colissimo - TNT - SoColissimo
7 reviews
Petit rectificatif à mes précédents posts…
Après l'avoir testé sur des enceintes plus délicates à alimenter, ce Precision 3 avoue finalement assez vite ses limites.
Aussi, mieux vaut le réserver, si non bridgé, à des enceintes de 90dB mini et, si possible, d'une impédance moyenne supérieure à 4 ohm.
Sinon, les basses fréquences deviennent mal contrôlées, et la précision (!) générale régresse (baisse de netteté et de dynamisme).
This review has been posted for AUDIO-GD PRECISION 3 Balanced Class A Amplifier ACSS 2x 70W / 8 Ohm
Précision 3
Bonjour
Commandé lundi reçu mercredi , merci .
j' ai remplacé mon ampli de puissance G&W classe A 2x 50w par le précision 3 ,
après quelques heures d' écoutes j'ai la même sonorité avec peut étre un
peu plus de basse , mais ce n' est que le début du rodage ( 100h d' après Audio GD )
Encore merci a Audiophonic pour leurs conseils .
rapport qualité prix imbattable.
Client audio-gd depuis 10 ans j'ai eu a peu près toute la gamme. Le "petit" dernier est impressionnant de vivacité et de précision. dans mon bureau j'avais un tripath class D couplé a un audio-GD FUN upgradé 2 fois. Le changement d'ampli est incroyable extension des registres grave et aiguë, image très précise... Il nécessite encore du rodage, en 3 jours on sent la différence. Pour de grosses enceintes c'est pas un SA-300 ou un C500 ... mais pour le prix rien à dire ! Merci à Audiophonics pour le rapidité d'expédition.
ecxellent en bridgé !
deuxiéme impression : magnifique ampli !!! semble très solide et connexion complètes .....
mon installation : haut parleur xavian piccola (scan peak) , cables hp black rhodium , DAC audio-gd amanero 28-38,branché sur ampli audio-gd précision 3 ,en bridgé (donc 2 amplis) (acheté sur audiophonics ) , le tout branché en usb asynchrone sur tour pc , lecteur foobar2000 sous asio ..... avec lecture sous sacd d ou lecture DSD , PCM 24bits ....
premier écoute : WHAAAAAA !!!! quel ouverture !!! son limpide ......profond ..... clair ....précision......3D parfait !!!!
pour être honnête SUBLIME , les instruments existe les hp donnent leur potentiel , les performances sont la !!! je vis la scène avec les amplis qui donne une cohérence sublime excellent ne faiblissent jamais qq soit le niveau , reste a la hauteur du signal transmis , le DAC est d une précision incroyable , la musique est transportée avec aisance les albums sont précis , vivant !!! le choix de l album reste primordiale car la qualité d enregistrement reste perfectible par ce DAC ,si il est très bon cela restera excellent dans le cas contraire cela s entends aussi tout en restant bon ...... ce pack DAC, AMPLI audio-gd avec enceinte est formidable , excellent , et pour très longtemps ...pourtant écouter et tester plusieurs installations dac/ampli et honnêtement , je vous le dit ici ....... LES INSTRUMENTS ECXISTES , la puissance, la profondeur ,la précision , la rondeur sont la et sans faiblir !!....excellent amplis !ainsi que DAC ..... merci a audiophonics et audio-gd et enceinte xavian !
Précisons
Dans mon précédent post, la référence à un prix d'achat à 2.500€ est maladroite. Il serait bien trop cher évidemment. A cause de sa présentation et de sa finition de fait insuffisante.
Car je pensais à un ampli de puissance, de cette gamme de prix, un Burson, contre lequel le Precision3 pourrait se mesurer techniquement sans complexe selon moi.
Autrement dit, son ramage ne peut se comparer à son plumage.
Ceci dit, c'est la force d'Audio-gd de ne pas recourir au marketing ni au campagne promotionnelle, et de pratiquer la vente directe... Leur seuil de rentabilité est ainsi sensiblement plus bas que la moyenne du marché. L'exceptionnel de leur produit est à l'intérieur. Il s'entend avant qu'il ne se voit ! Et merci bien entendu à Audiophonics qui sait contenir ses marges !
 (3)
The PRECISION 3 of Audio-GD is a power amplifier with a balanced Class A input and gain stage with a neat design that offers excellent audio...
