AUDIOPHONICS HPA-S600NC Power Amplifier Class D Stereo NCore NC500 2x600W 4 Ohm
Audiophonics PA-S500NC Stereo Class D Amplifier 2x500W 4 Ohm NCore
The HPA-S600NC is an impressive stereo amplifier. It is designed to meet power and precision requirements. Based on a duo of Hypex NCORE NC500 modules, this Class D amplifier benefits from a formidable efficiency thanks to a switch mode power supply unit with synchronous regulation.
By buying this product you get 99 loyalty points
Reference : 15456
990,00 €tax incl.
825,00 € tax excl.
Shipping from France
Billing in France
Technical support in France
Stereo Class D Amplifier NCore NC500 2x600W 4 Ohm
Audiophonics HPA-S700NC Amplificateur Stéréo Class D NCore 2x700W 4 Ohm
Like most NCore-based amplifiers, the frequency response is independent of load and electromagnetic interference is tightly controlled, which significantly limits distortion.
The HPA-S600NC will thus be particularly appreciated in all conditions requiring a high power amplification while keeping a great neutrality in the restitution of the signal. It will find its place as well in a professional studio as in a private home.
Two NC500 mono modules
Each channel has its own high efficiency amplification circuit; low output impedance, low distortion and low noise.
Each amplification module is capable of delivering 700W at 1% THD, and the 1200W power supply allows them to simultaneously deliver 600W at 0.01% THD into 4ohm.
The internal connections are neat using large section power wires, CANARE input signal cables, and Teflon insulated speaker cables.
AUDIOPHONICS HPA-S700NC Amplificateur Stéréo Class D NCore 2x700W 4 Ohm
Switchable RCA and XLR inputs
This power amplifier has two RCA input ports (dual mono) and two XLR ports (dual mono balanced).
The RCA plugs are 24k gold plated with heat resistant plastic caps.
The XLR connectors are high quality Neutrik connectors with metal locking latches and gold-plated conductors.
A two-position selector switch allows you to alternate the XLR input and the RCA input with ease. You can thus connect two different preamplifiers and alternate the input sources.
Audiophonics Interface Card
Both modules are driven in opposite phase, to cancel out the «Power-Supply Pumping» effect. This allows greater stability in the power supply by alternately distributing current draws on each rail, thus increasing its overall capacities.
We opted for a two stage voltage regulation in order to optimize the power supply to the OPAs and the auxiliary voltage supplied to the modules.
A Texas Instrument LM4562 OPA per channel is used, these are very low distortion AOPs offering the greatest transparency with a very low THD. They are mounted on socket allowing their replacement if necessary
To suit all uses we opted for 3 gain settings, adjustable by jumper on the interface board.
High quality banana plug compatible terminal blocks
The HPA-S600NC has two pairs of 24 karat gold plated speaker terminals on its rear panel.
These terminal blocks are designed to accept banana plugs which they will accept up to ⌀4mm.
These will also accommodate bare wires thanks to a ⌀5.3mm screw lockable slot.
Trigger 5-12V
A trigger plug provides the convenience of a power-on sequence and allows a very complete integration into your audio installation.
The power input is on an IEC14 socket with gold-plated copper conductors. The latter works with a 5x20mm 3.150A fuse (supplied and already installed).
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
Heat dissipation
Because it is capable of developing considerable power, the HPA-S600NC will be subjected to thermal stresses during use. Heat management is a key issue in achieving a high level of sonic accuracy and keeping distortion below a controlled level.
For this reason, each amplifier module is mounted on a large heat sink that is capable of dissipating heat efficiently. Carefully placed ventilation holes will also promote air circulation and heat removal.
Product typeClass D Power amplifier
Channels2 (Stereo)
Inputs2x Single-ended RCA
2x Balanced 3 poles XLR
TechnologyNcore
Output power2x500W under 2Ω @ 1kHz THD=0.01%
2x600W under 4Ω @ 1kHz THD=0.01%
2x300W under 8Ω @ 1kHz THD=0.01%
THD+N @ 20Hz-20kHz, 4ΩTyp : 0.001%
Max : 0.005%
SNR135dB @ Unweighted
Output noise9µV
Frequency response0Hz - 50kHz @ +0/-3dB
Trigger5-12VDC
Power supply115 or 230V
The product must be configured on 115 or 230V before shipping
Gain12.4dB
Input sensitivity @ 600W, 4ΩBypass (12.4dB)
XLR : 11.75Vrms (2x5.87Vrms)
RCA : 11.75Vrms
Gain normal (22dB)
XLR : 3.9Vrms (2x1.95Vrms)
RCA : 3.9Vrms
Gain + (27dB) (by default)
XLR : 2.19Vrms (2x1.1Vrms)
RCA : 2.19Vrms
Max electrical consumption1300W
Efficiency (max power)92%
HousingSandblasted aluminum
Dimensions413mm x 330mm (360 with terminals) x 60mm
Weight5.52kg
Package1x Audiophonics HPA-S600NC
1x Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)600.0
Parfait !
Appareil reçu dans les temps dans un emballage sérieux.
Le boîtier et la connectique sont de qualité, l'éclairage du bouton marche/arrêt gagnerait à être plus discret.
Les performances de cet ampli sont impressionnantes, clarté et puissance sont au rendez-vous, pas le moindre souffle dans les hp et l'ampli ne chauffe pas.
Un grand merci à David et Grégory pour les conseils et leurs patiences face à toutes mes questions.
This review has been posted for AUDIOPHONICS HPA-S600NC Power Amplifier Class D Stereo NCore NC500 2x600W 4 Ohm
The HPA-S600NC is an impressive stereo amplifier. It is designed to meet power and precision requirements. Based on a duo of Hypex NCORE NC500...
