AUDIOPHONICS AP300-M450ET Power Amplifier Mono Purifi 1ET6525SA
We're proud to present the Audiophonics AP300-M450ET, a Class D mono power amplifier based on a Purifi 1ET6525SA module. This ready-to-install and ready-to-use version is aimed at audiophiles who want a foolproof amplification solution, with considerable power reserve and impeccable linearity. The PURIFI 1ET6525SA is one of the most rigorous Class D amplification solutions on the market, with measured performance that is simply outstanding.
By buying this product you get 71 loyalty points
Reference : 20210
719,00 €tax incl.
599,17 € tax excl.
Shipping date: 29-08-2025.
Audiophonics Workshop amplifiers range
Audiophonics AP300-M450ET Power Amplifier Class D Mono PURIFI 1ET6525SA 1x450W 4 Ohm
Audiophonics AP300-M450ET : Front view
The result is a high level of sound reproduction, suitable for use with demanding speakers, large listening rooms or studio applications requiring considerable headroom without compromising on the precision and richness of the audio message.
All components are housed in a sober, robust and compact 100% aluminum case. It features openings to facilitate heat dissipation. Its design also limits the impact of interference on the signal.
Audiophonics AP300-M450ET : PURIFI 1ET6525SA Module
Audiophonics AP300-M450ET : PURIFI 1ET6525SA module
  • For its single amplifier channel, the AP300-M450ET uses a PURIFI 1ET6525SA module. This high-performance Class D amplifier circuit delivers a very comfortable output power of 450W at 4Ω or 230W at 8Ω, while benefiting from the tremendous efficiency of Class D amplifiers.
  • The 1ET6525SA module features a high-gain loop of over 85dB across the entire frequency band, providing high performance across the entire spectrum, surpassing any amplifier of any class.
  • Highly effective in terms of intermodulation distortion (IMD), these modules enable the AP300-M450ET to deliver a stereophonic image of formidable precision across the entire spectrum, for redoubled clarity, even during the most complex musical works.
  • Total Harmonic Distortion (THD) is kept extremely low at all power levels. This translates into an absence of sound signature and the ability to reproduce all types of music without coloration.
  • Output noise is negligible, allowing deep silences and favoring the appearance of detail when listening at low volume.
  • The circuit benefits from a high level of rejection (PSRR) that minimizes the impact of the power supply on audio performance.
  • The load-independent frequency response makes it possible to enjoy all the qualities of this amplification technology, even with the most difficult-to-drive speakers.
  • Low quiescent power consumption and electromagnetic radiation (EMI). The high-gain loop considerably relieves the workload on MOSFETs, enabling them to operate under optimum conditions, reducing losses and EMI emissions.
  • The AP300-M450ET's amplifier module are linked by a specially developed interface board for optimum integration.
Audiophonics AP300-M450ET : HYPEX SMPS600N400 Power Supply Module
The SMPS600N400 switched-mode power supply is an ultra-high-efficiency model capable of delivering 600 Watts of rated power in an extremely compact package. It has been specifically designed and developed by HYPEX to supply the 2 x 65V voltage required to operate the most demanding amplifier modules.
This high-quality, low-noise power supply meets the power requirements of the amplifier modules in every respect. What's more, the amplifier modules themselves have an excellent ability to reject power supply noise. As a result, the AP300-M450ET is extremely insensitive to mains imperfections and voltage/current variations that can cause parasitic noise.
Audiophonics AP300-M450ET : Hypex SMPS600N400 power supply module
Audiophonics AP300-M450ET : Audiophonics interface card
The amplifier module is controlled by an interface board of our own design.
An Audiophonics OPA1656 OPA is used, a very low distortion OPA offering the highest transparency with very low THD. It is socket-mounted, allowing replacement if necessary.
To suit all uses, we have opted for 4 gain settings, selectable by jumper on the underside of the unit: 12.5dB, 20dB (default), 25dB and 29dB.
Audiophonics AP300-M450ET : Connectivity
Designed for easy integration, the AP300-M450ET features both balanced (XLR) and single-ended (RCA) mono inputs. A bipolar selector switch makes it easy to change the input source.
At the output, BP-207 carbon / 24k gold insulated terminal blocks Ø5.5mm ensure an excellent connection with the loudspeakers.
Audiophonics AP300-M450ET : Rear view
Audiophonics AP300-M450ET : Trigger
The AP300-M450ET features a 5-12V trigger input integrated into a low-power circuit (5 mA). This means your amplifier blocks can easily join your Hi-Fi installations with remote-controlled switch-on.
Audiophonics AP300-M450ET : trigger
Audiophonics AP300-M450ET : THD vs Freq
Audiophonics AP300-M450ET : THD+N
Audiophonics AP300-M450ET : Frequency response
Product typePower amplifier
Inputs1x Balanced mono XLR
1x Single-ended mono RCA
Output1x Speaker terminal
Power1x230W @ 8Ω, 1%THD
1x450W @ 4Ω, 1%THD
1x510W @ 2Ω, 1%THD
Total harmonic distortion more noise (THD+N)0.00035% @ PO=1W, f=1kHz
0.0001% @ PO=10W, f=1kHz
0.00005% @ PO=100W, f=1kHz
0.00035% @ PO=1W, f=20Hz-20kHz
0.00029% @ PO=10W, f=20Hz-20kHz
0.0001% @ PO=100W, f=20Hz-20kHz
IMD (CCIF)0.0000003% @ PO=1W, f=18.5kHz+19.5kHz
0.0000006% @ PO=10W, f=18.5kHz+19.5kHz
0.0000005 % @ PO=100W, f=18.5kHz+19.5kHz
IMD (DIM)0.002% @ PO=1W, DIM30
0.002% @ PO=10W, DIM30
0.009% @ PO=100W, DIM30
Idle noise6.6µV (A-Weighted)
Dynamic range137dB @ 4Ω (A-Weighted)
SNR137dB @ 4Ω (A-Weighted)
Frequency response20Hz - 20kHz ±0.01dB @ RL=8Ω
20Hz - 20kHz ±0.01dB @ RL=4Ω
20Hz - 20kHz ±0.01dB @ RL=2Ω
Output impedanceIout = 1A @ 0.03mΩ, 1kHz
Iout = 1A @ < 0.35mΩ, 20Hz-20kHz
Input impedanceRCA : 10kΩ
XLR : 20kΩ
XLR Gain / Input sensitivity for max power at 1% THD12.5dB / 10.06Vrms
20dB / 4.24Vrms
25dB / 2.39Vrms
29dB / 1.51Vrms
RCA Gain / Input sensitivity for max power at 1% THD12.5dB / 5.03Vrms
20dB / 2.12Vrms
25dB / 1.24Vrms
29dB / 0.75Vrms
Power supply100-240V AC
Total dimensions (WxDxH)300 x 248 x 62mm
Weight1.98kg
Housing materialAluminum
Package1x Audiophonics AP300-M450ET
1x Power cable
InputXLR
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chip1ET6525SA
Power (W)450.0
6 reviews
Simply outstanding!
I have bought the Purifi to use for my Monitor Audio Silver C350 center, which before was powered by the receiver (Marantz SR6015), i wasnt expecting much, but to be honest the difference is big, much clearer voices/effects in movies, and for music... everything is better - voices, highs, even bass is tighter. Now a new problem - the rest of the speakers are lacking, heh. I Recommend it for center speaker with two hands!
This review has been posted for AUDIOPHONICS AP300-M450ET Power Amplifier Class D Mono Purifi 1ET6525SA 1x450W 4 Ohm
FIVE STARS IF YOU GO IN BALANCED BYPASSING THE OPAMP
It is a real pleasure to deal with audiophonics. Questions are answered immediately. Problems are solved quickly in favor of the customer. Here and there you can find some items a few euros cheaper elsewhere in the net but it is not worth the hassle if something goes wrong.
Now about the amps:
Coming from a UCD400hxr and a purifi ET400 this is my third iteration of a class d amp. It is driven as part of an full range system in a professional environment with dedicated studio acoustics. The mains are cleaned and have private electrical neutral and savety earth lines for the audio gear to bring ground loop noise down.
I always drive class d amps balanced without input buffer using high current preamps that can drive low input impedance gear with ease.
Some comments about the implementation of the modules:
1. When i got the amp I pulled out the opamp and plugged in the dummy opamp hooked it up and let it play while. Coming back i compared it to the ET400 and was surprised that the audiophonics sounded quite veiled in comparison. The quick fix was to pull out the power supply cable going from the input buffer board to the xlr and cinch connector board. Audiophonics decided to make the unbalanced input balanced by using an active circuitry at the xlr and cinch connector board. Obviously the circuitry polluted the signal. Now I got clean sound. (Btw the previous model didn´t use this circuity).
The better fix is to pull out the xlr and cinch board entirely, to buy a xlr connector and solder it directly to the input board using a high quality shielded balanced cable .
2. Opamp implementation: the opamp is introducing more color than I expected. (I compared the op amp level matched in low gain setting to the unbuffered input.) I am convinced that a top notch implementation using a dedicated high end power supply for the opamp would bring down opamp noise down a bit...and price up obviously...As I don´use it I don´t care.
3. To have an opamp socket is nice to have for those customers who like playing around with different thd profiles of different opamps. But with time resistance is building up at the contact points. So plug the opamp in and out from time to time. More important for the same reason: toggle the xlr cinch input switch from time to time (it is not a gas tight relay) and plug in and out the signal cable at the buffer input board. I would like to have these things soldered, including the speaker cables at the buffer board.
4.The power supply is getting quite hot. For better heat dissipation I would prefer that it makes contact with the metal case. The purifi modules itself are running very cool.
5. I can´t comment on the quality of the single ended input in comparison to the balanced one as I have no use for it.
6. I do like the binding posts. They allow for cranking down the calble super tight.
Final words:
The purifi modules are ment to be driven balanced. To provide single ended inputs in my opinion is mainly a marketing decision. Unfortunatly here this decision impacts the purity of the signal when going in balanced.
Fortunately pulling out the power supply cable of the symmetry circuitry is an easy solution as long as you don´t need the single ended input.
In this implementation the modules should be driven without input buffer opamp as they color the sound too much for my taste. You miss out how beautifully clean these modules can sound when the opamp is not installed.
If you like uncolored amps, have an great room with great speakers, great upstream electronics and clean mains power you can enjoy absolutely truth telling amplification for little money. Therefore it is also excellent in revealing minuscule differences when you shoot out upstream gear.
If you are a mixing or mastering engineer these modules tell you everything to make the right decisions, especially in the top end where many amps lack accuracy. If it sounds harsh on these it is harsh and needs to be adressed.
Price of the amps is excellent. It is not worth building one youself. I can whole heartly recommend this purifi build if you go in balanced bypassing the opamp.
Perfect
Perfect service, fast delivery from Audiophonics: High-End Sound for less money, the Putifi Technology is fantastic
Super ampli
Bonjour,
Ces amplis de puissance drivent parfaitement mes Revival Audio Atalante 5 dans toutes les situations d'écoute.
J'ai opté pour ces amplis car je peux les cacher dans un meuble.
Purifi
Je me suis lancé avec courage pour acquérir deux PURIFi mono, ne croyant pas beaucoup à une nouvelle classe D pour la HIFI. Et bien, ils sont incroyables ses petits amplificateur. Tout le spectre est parfaitement reproduit avec une belle image stéréo avec de la puissance et sans distorsion. Mes HP 38cm sont maintenus avec une main de fer dans un gant de velour normal, puisque j'ai aussi aqueri le DAC Topping E70 VELVET. Aucun regret pour cet achat.
Merci à Audiophonics pour cette très belle réalisation ainsi qu'à Bruno PUTZEYS pour avoir réalisé PURIFi .
We're proud to present the Audiophonics AP300-M450ET, a Class D mono power amplifier based on a Purifi 1ET6525SA module. This ready-to-install...
