AUDIOPHONICS AP300-S125NC Power Amplifier Ncore NC122MP
The Audiophonics AP300-S125NC is a stereo amplifier based on an amplification module Hypex Ncore NC122MP. This solution is ideal for anyone who wants to have a large power reserve (2x125W @ 4Ω) without sacrificing sound reproduction quality. This amplifier block will be suitable for example to accompany demanding speakers, to sound large listening rooms or for studio applications requiring a large headroom without compromising the accuracy and richness of the audio message.
By buying this product you get 44 loyalty points
Reference : 18433
449,00 €tax incl.
374,17 € tax excl.
Audiophonics Workshop amplifiers range
Class D Stereo Power Amplifier Ncore NC122MP 2x125W 4 Ohm
AUDIOPHONICS AP300-S125NC Class D Stereo Power Amplifier Ncore NC122MP 2x125W 4 Ohm
All components are integrated in a simple and robust 100% Aluminium housing with openings to facilitate heat dissipation. Its design also allows it to limit the impact of interference on the signal.
Hypex Ncore NC122MP Amplification Board
The Audiophonics MPA-S125NC incorporates a Hypex Ncore NC122MP power amplifier module. This is a solid foundation on which to build a high-performance stereo HiFi system, capable of delivering 2x75W into 8Ω.
On a single double-sided PCB it consists of a low-power power supply for standby, a high-performance switching power supply, but above all an extremely efficient Class D amplifier circuit. The amplifier used on this NC122MP module offers a high efficiency of 92%, enabling it to be used for a wide variety of purposes, from studio use to integration in a hi-fi audio system.
Distinguishing features of this amplifier are its linear frequency response whatever the load impedance, and consequently its faithful reproduction, its very low distortion and also its very low EMI radiation rate.
The amplifier's control is based on a self-oscillating phase-shift loop, taking into account the response only at the loudspeaker output, always with a view to sound transparency.
This amplifier does not have a decoupling capacitor, so it lets the DC component of the signal through. Make sure your source has no DC component present at the output. The DC protection of the module switches on at 12VDC which is very permissive.
NCore Technology
NCore amplifiers are the first Class D amplifiers to approach the performance of operational amplifiers, but also to surpass them in terms of sound quality. As a result, they are able to deliver clear, rich, musical sound while remaining compact. This NCore technology combines the stability of the Hypex UcD series amplifiers with lower distortion and output impedance.
AUDIOPHONICS AP300-S125NC Amplificateur de Puissance Class D Stéréo Ncore NC122MP 2x125W 4 Ohm
SMPS Power Supply
The NC122MP module also integrates the amplification stage. This consists of a regulated half-bridge switching power supply (SMPS) with synchronous rectification on the main output rails. Compact, powerful and efficient, this power supply is particularly suitable for supplying a Class D amplifier cleanly.
In addition, to offer complete compatibility with the voltages delivered by the various electrical networks, the power supply is equipped with an automatic input voltage doubler. The NC122MP module also has an overload protection system.
Connectivity
The AP300-S125NC amplifier features a 2-pole stereo RCA input on gold-plated sockets, plus a 3-pole stereo XLR input for balanced signal processing. The XLR or RCA input source is selected via two switch buttons (right and left channel). The amplifier output is made on Elecaudio BP-209 24k gold-plated speaker terminals. They also accept banana plugs or spades for quick and easy connection. A 5-12V trigger connector in 3.5mm Jack format allows to control the automatic ignition of the amplifier when integrated in a compatible system. Finally, a bistable button is used to switch the unit on and off.
100% Aluminum Case and clean lines
The Hypex NCore NC122MP amplifier is housed in a 100% black brushed aluminum case. The thick walls of this elegantly-finished case are highly resistant, providing the components with the protection they need. The natural conduction of aluminum, together with a carefully designed air flow, helps dissipate the heat generated by the module. In addition, the acrylic front panel is screen-printed with the Audiophonics logo, and the rear with the nomenclature of each input/output. Its compact size makes it easy to integrate into any audiophile installation, offering high performance in a small space.
INDICATIVE COMPATIBILITY TABLE
Product typeAmplifier
ClassD
Number of channelStereo (2)
Max. power (@ 1kHz, THD=1%)2x75W @ 8Ω
2x125W @ 4Ω
2x115W @ 2Ω
Inputs1x RCA Stéréo Asymétrique
1x XLR Stéréo Symétrique
OutputsSpeaker terminals
Trigger5-12V
THD+N0.0015%
SNR118dB
Output noise30µV
Output impedance1.5mΩ
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivity125W 4ohm @ 1.17V RMS
Supply voltage230V / 110V (automatic switch)
Case materialBrusched aluminum
Total dimensions (WxDxH)300 x 248 x 62mm
Weight1930g
Package1x Audiophonics AP300-S125NC
1x Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)125.0
5 reviews
Un MUST-HAVE
Après quelques mois d'utilisation de ce module Ncore S 125NC je souhaite fournir quelques informations supplémentaires et une comparaison avec le petit DOUK AUDIO A5 que je possède. Pour être clair, il n'y a pas photo entre les deux appareils. Certes on ne se situe pas dans la même fourchette de prix mais tout de même l'Audiophonics Ncore domine largement son petit concurrent. Le DOUK n'est pas un mauvais appareil mais il faut reconnaître qu'il a un point faible: les timbres. Il y a une légère distorsion dans l'aigu qui se traduit par des violons manquant de caractérisation et de soyeux, et très bons AOP Sparkos Labs avec une puissante alim 48 V/10 A ne parviennent pas à atténuer ce caractère assez fâcheux. Avec l'Audiophonics Ncore S125 rien de tout cela, les timbres sont superbes, soyeux et variés, l'image stereo à l'avenant. Il ne faut pas hésiter à dépenser quatre centaines d'euros, vos oreilles vous diront merci.
This review has been posted for AUDIOPHONICS AP300-S125NC Class D Stereo Power Amplifier Ncore NC122MP 2x125W 4 Ohm
L'AMPLIFICATION ULTIME (?)
Enfin un amplificateur qui n'est pas ceci ou cela mais qui s'efface devant la musique. Pas de plus beau compliment pour un maillon Hifi. L'amplification classe D est elle entrée dans sa maturité? Avec ce module Hypex Ncore on peut l'affirmer. Tout ce que le mélomane attend d'un amplificateur me semble être ici présent: dynamique capable d'explosivité et de contrôle, sans traînage du grave, nuances fines restituées avec délicatesse, respect des timbres évident, sans aucune acidité dans le registre aigu, image stéréo superbe accompagnée d'une grande transparence. Que dire de la puissance sinon qu'elle est conforme à ce que le constructeur annonce, contrairement à ces multiples amplis chinois à base de TPA 3255, qui sont de bonnes machines, mais dont les puissances annoncées sont fantaisistes. Ce module Ncore va nettement plus loin en puissance comme en musicalité. Sur un plan purement matériel, la qualité de fabrication me semble au dessus de tout soupçon: chassis alu solide, connectique RCA, XLR, ENCEINTES de belle facture, câble d'alimentation de forte section, bref que du sérieux. Un ampli de puissance à associer impérativement à un très bon DAC (pas obligatoirement coûteux) et à des câbles d'une grande transparence. Bravo Audiophonics.
Great product
The amp just arrived. Well packed. Well finished. Very good looking product.
Just out of the box the sound is truly astounding compared to my old ADAU1592 based small amp. No more issues with treble. Good solid bass. A lot more detail. Wider and deeper sound stage.
Thanks to Mr. Putzey for such a good design and thanks to Audiophonics for making it available at such a good price.
Great product for a small system with reasonable power needs.
excellent
couplé a un streamer eversolo sur les liaisons symetriques... tout y est!
puissance , details , profondeur et le tout dans une certaine douceur.
chouette!
Incredible value for money
I normally never write a review but i feel inclined to do so for this product.
I have high sensitivity speakers (Blumenhofer) and thought that only a SET tube amplifier would be a good match, i was wrong.
My 300b died on me and having already put so much money in tubes i thought, time to try something different.
So after consideration and reading on audio science review forum about what makes an amplifier truly good, i choose this amplifier as in blind testing most people couldn’t hear a difference between Ncore and Purify (more expensive) and also between other even much more expensive amplifiers.
So i chose the smallest Ncore as my speakers are very easy to drive.
Listening:
The lower end is much cleaner and more controlled than my 300b was.
Midrange is fine, it hasn’t got the romantic touch of 300b tube but in it’s own right it doesn’t sound worse, just a bit different.
Highs, for class d, where in the past this just wasn’t very good, with Ncore i hear no problems whatsoever.
It just sounds great, and i dare say, for this price INCREDIBLE.
Hats off to Hypex and the original designer Bruno Putzey for making such a great inexpensive amplifier.
In my middle end to high end system it’s no slough.
Highly recommended, if your speakers need more juice, than the NC400 is better i guess.
 (6)
The Audiophonics AP300-S125NC is a stereo amplifier based on an amplification module Hypex Ncore...
