AUDIOPHONICS AP300-S250NCX Power Amplifier NcoreX NCx252MP
The Audiophonics AP300-S250NCX is a stereo amplifier based on an amplification module Hypex NcoreX NCx252MP. This solution is ideal for anyone who wants to have a large power reserve (2x250W @ 4Ω) without sacrificing sound reproduction quality.
4.9 / 5
By buying this product you get 54 loyalty points
Reference : 18419
549,00 €tax incl.
457,50 € tax excl.
Audiophonics Workshop amplifiers range
Class D Stereo Power Amplifier NcoreX NCx252MP 2x250W 4 Ohm
AUDIOPHONICS AP300-S250NCX Class D Stereo Power Amplifier NcoreX NCx252MP 2x250W 4 Ohm
The Audiophonics AP300-S250NCX is a stereo amplifier based on an amplification module Hypex NcoreX NCx252MP. This solution is ideal for anyone who wants to have a large power reserve (2x250W @ 4Ω) without sacrificing sound reproduction quality. This amplifier block will be suitable for example to accompany demanding speakers, to sound large listening rooms or for studio applications requiring a large headroom without compromising the accuracy and richness of the audio message.
All components are integrated in a simple and robust 100% Aluminium housing with openings to facilitate heat dissipation. Its design also allows it to limit the impact of interference on the signal.
Hypex NcoreX NCx252MP Amplification Board
The amplification circuit uses a module Hypex NcoreX NCx252MP. It is a versatile, high-performance Class D amplifier. It offers a very comfortable power of 2x150W at 8Ω while taking advantage of the high efficiency of Class D amplifiers.
Its main characteristics are its flat frequency response regardless of load impedance, its almost frequency-independent level of distortion and its ability to reject EMI interference. Its operation is based on a self-oscillating loop controlled by phase shift and taking into account feedback only at the speaker output.
This amplifier does not have a decoupling capacitor, so it lets the DC component of the signal through. Make sure your source has no DC component present at the output. The DC protection of the module switches on at 12VDC which is very permissive.
NCore Technology
NCore amplifiers are the first Class D amplifiers to approach the performance of operational amplifiers, but also to surpass them in terms of sound quality. As a result, they are able to deliver clear, rich, musical sound while remaining compact. This NCore technology combines the stability of the Hypex UcD series amplifiers with lower distortion and output impedance.
AUDIOPHONICS AP300-S250NC Class D Stereo Power Amplifier Ncore NC252MP 2x250W 4 Ohm
SMPS Power Supply
The NCx252MP module also integrates the amplification stage. This consists of a regulated half-bridge switching power supply (SMPS) with synchronous rectification on the main output rails. Compact, powerful and efficient, this power supply is particularly suitable for supplying a Class D amplifier cleanly.
In addition, to offer complete compatibility with the voltages delivered by the various electrical networks, the power supply is equipped with an automatic input voltage doubler. The NCx252MP module also has an overload protection system.
Connectivity
The AP300-S250NCX amplifier features a 2-pole stereo RCA input on gold-plated sockets, plus a 3-pole stereo XLR input for balanced signal processing. The XLR or RCA input source is selected via two switch buttons (right and left channel). The amplifier output is made on Elecaudio BP-209 24k gold-plated speaker terminals. They also accept banana plugs or spades for quick and easy connection. A 5-12V trigger connector in 3.5mm Jack format allows to control the automatic ignition of the amplifier when integrated in a compatible system. Finally, a bistable button is used to switch the unit on and off.
100% Aluminum Case and clean lines
The Hypex NCoreX NCx252MP amplifier is housed in a 100% black brushed aluminum case. The thick walls of this elegantly-finished case are highly resistant, providing the components with the protection they need. The natural conduction of aluminum, together with a carefully designed air flow, helps dissipate the heat generated by the module. In addition, the acrylic front panel is screen-printed with the Audiophonics logo, and the rear with the nomenclature of each input/output. Its compact size makes it easy to integrate into any audiophile installation, offering high performance in a small space.
Product typeAmplifier
ClassD
Number of channelStereo (2)
Max. power (@ 1kHz, THD=1%)2x150W @ 8Ω
2x250W @ 4Ω
2x180W @ 2Ω
Input1x Unbalanced Stereo RCA
1x Balanced Stereo XLR
OutputSpeaker terminals
Trigger5-12V
THD+N0.0015%
SNR121dB
Output noise30µV
Output impedance1.5mΩ
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivityMax Power at 1.66V RMS
Supply voltage230V / 110V (automatic switch)
Case materialBrushed Aluminium
Total dimensions (WxDxH)300 x 248 x 62mm
Weight2080g
Package1x Audiophonics AP300-S250NC
1x Power cable
InputXLR
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)250.0
19 reviews
Audiophonics-ap300-s250ncx : Le Graal ?
Cet amplificateur remplace un SMSL-AD18 dont l'alimentation venait de rendre l'âme. J'avais toujours comme ressenti avec une paire de Elipson P4I un manque d'assise dans les mediums. Apres un petit rodage, le son est apparu plus fidèle que jamais, bien présent dans les mediums, l'impact des bass était bien plus dynamique qu'auparavant .... bref cet ampli est incroyable, je regrette de pas l'avoir acheté bien plus tot ....
This review has been posted for AUDIOPHONICS AP300-S250NCX Class D Stereo Power Amplifier NcoreX NCx252MP 2x250W 4 Ohm
Audiophonics rocks
When Archimago of Archimago's Musings and Amirm of Audio Science Review, two of the most respected measurement bloggers, posted rave reviews of the Hypex nCore NC252MP Amplifier, the precursor of the current NCx252MP amplifier, a few years ago, I knew I had to have this amp to drive my 15-inch System 15 DMT II Tannoys driven by the mighty Rotel RBH-10 Michi till then and boy oh boy did this small Class D marvel deliver, it equals the Michi in every area that counts, control, transparency, imaging, and a seemingly limitless power reserve to wade through the most difficult of passages and all the above with a fraction of the electrical power, just compare the 550W needed to power the Rotel to the 25W for the AP300. The Audiophonics implementation is fantastic, the enclosure oozes quality, speaker terminals and RCA/XLR inputs are top notch. So in a nutshell I am very satisfied returning customer, Audiophonics has assembled a very fairly priced, top quality European product...
 (4)
pleased
Very pleased with delivery and the product. i have combined it with a Wiim Ultra and a pair of DALI Suite 2.5. My previous amp was a HK 980 that i didn't like paired with my speakers. This amp sound much better!
Audiophonics AP300-s250NCX
ABSOLUTELY LOVE IT!
I've been using a Marantz SR-6006 for almost a decade without realizing I have been starving my B&W Matrix 801s3! As the receiver died a month ago I got myself a Cinema 50. While the sound in direct mode was decent I couldn't help wondering what would happen if I could properly feed those power-hungry 801s. Consulted Gemini (yes I actually consulted an AI) and by suggesting Class-D to the AI a Class-D amp the Audiophonics name came up. Read up on a few reviews online and I thought why not give it a try, it's less than what I had spend on an AC cable!
A few days after ordering the amp is with me and low and behold it turns out I have never heard the incredible bass these 801s are capable of!
Soundstage is huge and holographic, vocals is sweet (I'm guessing from the Cinema 50's voicing and bass is lightening fast!
At the moment I couldn't be happier with my purchase.
 (3)
Beaucoup de puissance, bon son
Note : Traduit de l'allemand par IA.
Amplificateur très puissant, on ressent immédiatement les 2 x 250 watts dès qu'on tourne le bouton de volume, contrairement au Fosi Audio V3, c'est une grande différence. Un super appareil, très bien fini avec des connecteurs de haute qualité.
J'utilise l'AP300 comme amplificateur de puissance (bloc de puissance) relié au préamplificateur Nubert nuXinema avec deux enceintes Elac BS283.2, principalement pour écouter de la musique en mode stéréo et en mode home cinéma avec une simple voie centrale fantôme. Je n'ai pas besoin d'enceintes arrière, cela ne ferait que réveiller le chien.
Pour éviter d'avoir à allumer ou éteindre l'AP300 manuellement, j'ai combiné un câble USB vers jack CC (5V vers 12V) sur le nuXinema avec un adaptateur CC vers jack mono, et je l'ai connecté à l'entrée trigger 12V de l'AP300. Cela fonctionne à merveille.
Son : Comme on pouvait s'y attendre, très linéaire et clair, analytique, avec un bon contrôle des basses.
Détails mineurs et question de goût :
La façade en acrylique n'a aucune utilité fonctionnelle ; elle rend peut-être l'appareil plus esthétique, mais j'aurais préféré de l'aluminium, qui est moins fragile. C'est pourquoi j'ai laissé le film de protection. Le bouton d'alimentation brille un peu trop fort à mon goût.
Le processus d'achat ainsi que la livraison de la France vers l'Allemagne ont été simples et rapides. Je suis ravi de posséder un appareil fabriqué en Europe. Salutations à la France !
The Audiophonics AP300-S250NCX is a stereo amplifier based on an amplification module Hypex NcoreX NCx252MP....
