AUDIOPHONICS HPA-DM500NIL Power Amplifier
Hand-assembled in our workshop in France, the Audiophonics HPA-DM500NIL power amplifier is a high-performance Class D dual-mono model, based on the new Hypex Nilai500DIY amplification solution. This delivers high power output with very low noise and distortion, for precise, clear sound reproduction. These modules are combined with two specially designed power supplies, the Hypex PS500DIY, providing audio circuits with a clean, stable electrical signal. The whole unit is housed in a solid, sand-blasted aluminum case, revealing both a massive, modern design and perfect heat dissipation.
By buying this product you get 219 loyalty points
Reference : 19233
2 190,00 €tax incl.
1 825,00 € tax excl.
Shipping date: 09-07-2025.
Audiophonics Workshop amplifiers range
Audiophonics HPA-DM500NIL Power Amplifier Class D Dual Mono Nilai500DIY 2x300W 4 Ohm
Audiophonics HPA-DM500NIL: Front view
Audiophonics HPA-DM500NIL: Key features
Audiophonics HPA-DM500NIL: Dual Amplifier Module Nilai500DIY
Each channel of the Audiophonics HPA-DM500NIL features its own Class D Hypex Nilai500DIY amplifier module. These, integrated in a dual-mono architecture, ensure exceptional sonic performance, and enable the development of significant power, with no less than 500W per channel at 4Ω. Each module features high-end components, including a totally discrete buffer stage and high-quality voltage regulators, as well as a brand-new control loop technology. The result is a drastic reduction in distortion, noise and output impedance, enabling the HPA-DM500NIL to reveal a rich, precise sound with a wide soundstage.
Audiophonics HPA-DM500NIL: dual Nilay500DIY amplifier modules
Audiophonics HPA-DM500NIL: two Hypex PS500DIY power supply modules
Audiophonics HPA-DM500NIL: One Hypex PS500DIY power supply per channel
The two Nilai500DIY amplifier modules are each associated with their own Hypex PS500DIY switched-mode power supply module, specially designed to power them. These incorporate audiophile-grade components and PFC (Power Factor Correction) to ensure high power density and a significant reduction in EMI interference conductivity. The modules also incorporate a complete protection system for enhanced device durability. What's more, with one power module per channel, you benefit from true dual-mono architecture, effectively eliminating interference between each channel.
Audiophonics HPA-DM500NIL: Selectable RCA and XLR inputs
The HPA-DM500NIL features dual input connectors with two RCA ports (double mono unbalanced) and two XLR ports (double mono balanced). The RCA connectors are 24k gold-plated, with heat-resistant plastic caps. The XLR connectors are from Neutrik, and feature a high-quality design with metal locking latch.
A two-position selector switch makes it easy to alternate between XLR and RCA inputs. So you can connect two different preamplifiers and alternate input sources.
Audiophonics HPA-DM500NIL: XLR and RCA inputs
Audiophonics HPA-DM500NIL: speaker terminals
Audiophonics HPA-DM500NIL: High-quality speaker terminals
The Audiophonics HPA-DM500NIL features two pairs of 24-carat gold-plated speaker terminals on the rear panel. These terminals are designed to accept banana plugs up to Ø4mm in diameter. They can also accommodate bare conductors, thanks to a screw-lockable slot.
Audiophonics HPA-DM500NIL: Déclencheur 5-12V
A double trigger socket (input and output) brings the convenience of an automated and particularly practical ignition sequence to your entire audio system. Power input is via an IEC C14 socket. This is fitted with a 5x20mm 6.3A fuse (supplied and pre-installed).
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
Audiophonics HPA-DM500NIL: trigger connectors
Audiophonics HPA-DM500NIL: case designed for heat dissipation
Audiophonics HPA-DM500NIL: A stylish and robust case
As a high-power amplifier, the HPA-DM500NIL is, quite naturally, subject to thermal stress during use. Heat management is therefore of prime importance, not only to maintain amplification performance, but also to ensure the unit's excellent durability.
For example, the chassis, made entirely of sand-blasted aluminum, has recesses on the sides to increase the heat dissipation surface. Carefully placed ventilation holes promote air circulation and heat dissipation. The heatsinks also contribute to the amplifier's solid, modern aesthetic.
Audiophonics HPA-DM500NIL : schéma de présentation
1ON/OFF button
2Right channel XLR input
3Right channel input switch
4Right channel RCA input
5Right channel speaker output
6Power fuse
7Power input
8Trigger input
9Trigger output
10Left channel speaker output
11Left channel XLR input
12Left channel input switch
13Left channel RCA input
Product typePower amplifier
Amplification typeClass D
Amplification modules2x Hypex Nilai500DIY
ChannelsDual mono
Inputs2x Single-ended RCA
2x Balanced XLR
Amplification technologyNilai
Output power2x500W @ 4Ω
2x250W @ 8Ω
THD+N0.00015%
SNR134dB
Output noise9µV
Frequency response0Hz - 70kHz
TriggerInput / Output
5-12V
Gain21.75db
Supply voltage110-240V AC
Housing materialsSandblasted aluminum
Total dimensions (WxDxH)435 x 355 x 73mm
Weight6.1kg
Idle power0.1W
Package1x Audiophonics HPA-DM500NIL
1x Power cable
InputXLR
OutputSpeaker terminal
ChannelDual Mono
Channel2 (Stereo)
Amplifier chipHypex Nilai500DIY
Power (W)500.0
2 reviews
Ampli nilai
Tenue de grave impressionnante , spatialisation excellente , rapport qualité prix incroyable fonctionne avec un ampli préamplificateur moonriver 404 référence sur des grosses enceintes elipson Legacy 3230
This review has been posted for AUDIOPHONICS HPA-DM500NIL Power Amplifier Class D Dual Mono Nilai500DIY 2x500W 4 Ohm
Surprisingly good
Drives my loudspeakers with ease and precision. Better than expected experience.
Hand-assembled in our workshop in France, the Audiophonics HPA-DM500NIL power amplifier is a high-performance Class D dual-mono model, based on the...
