AUDIOPHONICS HPA-S500ET Power Amplifier Purifi 1ET7040SA
The Audiophonics HPA-S500ET power amplifier unveils a Class D architecture based on a pair of Purifi 1ET7040SA modules and a custom-designed power supply to enable the amplifier to deliver its full potential. Like all Audiophonics Workshop products, the HPA-S500ET is meticulously designed and assembled by hand in our workshop in France.
By buying this product you get 179 loyalty points
Reference : 18232
1 790,00 €tax incl.
1 491,67 € tax excl.
Shipping date: 09-07-2025.
Audiophonics Workshop amplifiers range
Power Amplifier Class D Stereo Purifi 1ET7040SA 2x500W 4 Ohm
AUDIOPHONICS HPA-S500ET Amplificateur de Puissance Class D Stéréo Purifi 1ET7040SA 2x500W 4 Ohm
With this model, you get a powerful, high-performance amplification solution, capable of powering demanding audio systems while delivering incredibly fine, linear sound reproduction. There's no compromise between power and sonic precision. Purifi modules feature a particularly rigorous design for exceptional measured performance.
All components are housed in a sturdy, solid aluminum enclosure, with openings and heat sinks for efficient heat dissipation. Its design also limits the impact of interference on the signal.
Audiophonics HPA-S500ET: an amplifier to drive complex and difficult speakers
One of the special features of the HPA-S500ET amplifier is that it practically doubles its power under a 2-ohm load. In fact, it can develop up to 2x 950W of power at 2 ohms (1% THD). The PURIFI 1ET7040SA module is exploited to its full potential in the HPA-S500ET, thanks to its custom-designed 2000W power supply delivering 70V. This amplifier is therefore ideal for use with loudspeakers with multiple drivers and crossovers that are often difficult to control.
A pair of Purifi 1ET7040SA modules
Each channel of the amplifier circuit uses its own Purifi 1ET7040SA module. These incorporate a high-performance Class D architecture with an available power of 2x500W into 4Ω or 2x250W into 8Ω and a high efficiency of 94%. They also ensure incredibly low levels of THD, intermodulation distortion and noise, favoring rich, precise and perfectly transparent sound reproduction, respecting the original audio signal to reproduce your music with flawless, coloration-free fidelity. It also guarantees a wide, realistic sound image for perfect immersion.
The main feature of the ET7040SA compared to its little brother the ET400A is its current capacity, making it stable under 2ohm, and bringing its maximum power to 950W. What's more, the frequency response of these modules is totally independent of load, allowing you to take full advantage of the capabilities of this design, even with speakers that are difficult to drive. The circuit also benefits from a high level of rejection (PSRR), reducing the impact of the power supply on audio performance. The two Purifi 1ET7040SA amplifier modules are linked by a specially developed interface board for optimum integration.
A customized power module
The Audiophonics HPA-S500ET features a specially designed, high-efficiency PFC switching power supply. Delivering a power of 2000W and a voltage of 70V, it provides optimum, clean and stable power to the amplifier modules. The modules are thus able to deliver their full potential and develop their full power, without restriction.
This power supply also ensures very low noise levels, and incorporates two stages of EMI filtering. Output voltages are tightly regulated, and the PFC system offers effective power factor correction for a particularly clean signal. This PFC power supply can be operated flexibly from 100 to 240V AC, without switching.
Audiophonics interface card
The two modules are controlled in phase opposition, to cancel the "Power Supply Pumping" effect. This makes for greater power supply stability, distributing current draw alternately on each rail, thus increasing its capacity. We opted for two-level voltage regulation, to optimize the power supply to the AOPs and the auxiliary voltage supplied to the modules. One Audiophonics OPA1656 is used per channel. These are very low-distortion PDUs, offering maximum transparency with very low THD. They are mounted on a socket so they can be replaced if necessary. To suit all applications, we've opted for three gain settings, switchable via jumper on the underside of the unit.
Balanced & Single-ended connectors
Designed for easy integration, the HPA-S500ET features both balanced XLR and single-ended RCA stereo inputs. Bipolar selectors make it easy to change input sources, and even allow independent control of channels. On the output side, insulated Audiophonics terminal blocks (developed in partnership with AEC Connectors) with 24k gold-plated contacts ensure an excellent connection between amplifier and loudspeaker. A dual 5-12V trigger module lets you integrate the amplifier into an automatic on/off chain for your entire audio system.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
1ON/OFF button
2Power input
3Trigger
4Right channel speaker output
5Left channel speaker output
6Right channel XLR input
7Right channel input selector
8Right channel RCA input
9Left channel XLR input
10Left channel input selector
11Left channel RCA input
AUDIOPHONICS HPA-S500ET Amplificateur de Puissance Class D Stéréo Purifi 1ET7040SA 2x500W 4 Ohm AUDIOPHONICS HPA-S500ET Amplificateur de Puissance Class D Stéréo Purifi 1ET7040SA 2x500W 4 Ohm AUDIOPHONICS HPA-S500ET Amplificateur de Puissance Class D Stéréo Purifi 1ET7040SA 2x500W 4 Ohm
Product typePower amplifier
Output power (max)2x950W @ 2Ω, 1% THD
2x800W @ 2Ω, 0.1% THD
2x500W @ 4Ω, 1% THD
2x420W @ 4Ω, 0.1% THD
2x250W @ 8Ω, 1% THD
2x210W @ 8Ω, 0.1% THD
Efficiency94% @ 500W, 4Ω, 1kHz
InputsBalanced stereo XLR
Single-ended stereo RCA
OutputsSpeaker terminals
Trigger2* Trigger 5-12V connectors on Jack 3.5mm
THD+N0.0004% @ 1W, 1kHz
0.00035% @ 10W, 1kHz
0.00035% @ 200W, 1kHz
0.0006% @ 1W, 20Hz-20kHz
0.0009% @ 10W, 20Hz-20kHz
0.0008% @ 200W, 20Hz-20kHz
IMD (CCIF)0.0002% @ 1W, 18kHz+19kHz
0.00015% @ 10W, 18kHz+19kHz
0.0002% @ 200W, 18kHz+19kHz
IMD (DIM)0.002% @ 1W, DIM30
0.0012% @ 10W, DIM30
0.0009% @ 200W, DIM30
Idle noise14µV (A-wt)
Dynamic range129dB(A)
Output noise~14µV(A)
SNR129dB(A)
Frequency response±0.01dB @ 8Ω, 20Hz-20kHz
±0.01dB @ 4Ω, 20Hz-20kHz
±0.01dB @ 2Ω, 20Hz-20kHz
Input impedanceRCA : 47kΩ / XLR 100kΩ
Bypass : 2.2kΩ / 4.4 kΩ
Output impedance< 12µΩ @ 1kHz
Gain / Input sensitivity for max power at 0.1% THD20dB / 4.19Vrms
26dB / 2.07Vrms
32dB / 1.05Vrms
34dB / 0.83Vrms
Supply voltage100-240V AC
Housing materialAluminum
Total dimensions (WxDxH)435 x 355 x 73mm
Weight5.9kg
Package1* Audiophonics HPA-1Et7040SA
1* Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipPurifi 1ET400A
Power (W)400.0
11 reviews
Après neuf mois d écoute, aucun changement. Amplificateur de premier choix
This review has been posted for AUDIOPHONICS HPA-S500ET Power Amplifier Class D Stereo Purifi 1ET7040SA 2x500W 4 Ohm
Excellent
Super amplificateur, très neutre, dynamique enorme, beaucoup de réalisme et transparence, sans jamais fatiguer a l´ écoute.
Je l´ utilise avec mon DMP A8 directement et j'en suis très satisfait.
J'avais dans ma liste des ampli coutant 2 ou 3 fois son prix, de marques très réputées et je le préfère a tous sans regarder au prix.
Je viens de lui changer les AOP audiophonic par des sparkos 3602, mais trop tot pour un avis, mais au premières écoutes il me parait que le son a les basses et dimensions différentes, pas nécessairement mieux, mais je n'ai que 3 heures d'écoute.
Mes audiovector QR7 sont maintenant bien alimenter et son devenus tous ce que je voulait, merci Audiophonic.
Amazing !!
After reading reviews and hearing experiences from friends, I switched to this amplifier.
After connecting I was pleasantly surprised.Amazing!! Lots of power, dynamics and soundsstage. My Audiovector QR7 SE came to life. No more classe A or A/B for me!
Je possède cet appareil depuis plus de deux mois, le son est fabuleux sur toute la bande passante, ce n est pas pas un peu mieux dans les aigus ou autre, mais sur tout le signal sonore.
100 heures de rodage sera nécessaire,
Class A , class ab et les tubes se sont fait dépasser par la class D.
 (3)
Je suis parti pendant trois jours, j ai oublié D éteindre l amplificateur....
La précision sonore de cet appareil est supérieur à un halcro dm66 .
Les dernières écoutes étaient :
- Jazz in thé pawnshop
- Pink Floyd ( meddle)
- Daft punk ( ram )
- Elton John ( lockdown session ) .
Nous connaissons souvent sur nos systèmes hifi , de temps à autre, de petites améliorations. La , c'est sur toute la bande passante. Testé bien-sûr avec une des meilleures paire d'enceintes mondiale. Audiophonics disent avoir testé leurs amplificateurs sur les haut-parleurs qu ils commercialisent.
Vous pouvez brancher tous les types D enceintes.
Des gens se plaignent de certains effets de loupes .
Si vous possédez des enceintes standards, achetées chez hypermedia, les effets indésirables seront bien présents, mais si vous branché du grand haut de gamme comme il existe peu , l ouverture sonore est sans doute la cure de jouvence la plus adaptée que vous pouvez donner à vos haut-parleurs !!!!
Les Wilson Audio sont des enceintes très riches, rapides et avec peu D égal sur le marché, vous me direz : des enceintes aussi chers avec un amplificateur à 1800 € . Non.... Et bien si !!!!
Jamais je n est entendu auparavant .
Le monde hifi a peur de la classD.
Vivre avec son temps.
 (4)
The Audiophonics HPA-S500ET power amplifier unveils a Class D architecture based on a pair of Purifi 1ET7040SA modules and a custom-designed power...
