AUDIOPHONICS MPA-S250NCX RCA Power Amplifier Class D Stereo Ncore NCx252MP 2x250W 4 Ohm
The Audiophonics MPA-S250NCX RCA is a stereo amplifier based on an amplification module Hypex NcoreX NCx252MP. This solution is ideal for anyone who wants to have a large power reserve (2x250W) without sacrificing sound reproduction quality.
4.8 / 5
By buying this product you get 47 loyalty points
Reference : 14278
479,00 €tax incl.
399,17 € tax excl.
Audiophonics Workshop amplifiers range
Class D Stereo Amplifier NcoreX NCx252MP 2x250W 4 Ohm
Audiophonics MPA-S252NCX RCA Amplificateur Stéréo Class D NcoreX 2x150W 8 Ohm
The Audiophonics MPA-S250NCX RCA is a stereo amplifier based on an amplification module Hypex NcoreX NCx252MP. This solution is ideal for anyone who wants to have a large power reserve (2x250W) without sacrificing sound reproduction quality. This amplifier block will be suitable for example to accompany demanding speakers, to sound large listening rooms or for studio applications requiring a large headroom without compromising the accuracy and richness of the audio message.
All components are integrated in a simple and robust 100% Aluminium housing with openings to facilitate heat dissipation. Its design also allows it to limit the impact of interference on the signal.
Hypex NcoreX NCx252MP Amplification Board
The amplification circuit uses a module Hypex NcoreX NCx252MP. It is a versatile, high-performance Class D amplifier. It offers a very comfortable power of 2x150W at 8Ω while taking advantage of the high efficiency of Class D amplifiers.
Its main characteristics are its flat frequency response regardless of load impedance, its almost frequency-independent level of distortion and its ability to reject EMI interference. Its operation is based on a self-oscillating loop controlled by phase shift and taking into account feedback only at the speaker output.
This amplifier does not have a decoupling capacitor, so it lets the DC component of the signal through. Make sure your source has no DC component present at the output. The DC protection of the module switches on at 12VDC which is very permissive.
NCoreX Technology
NCoreX amplifiers are the first Class D amplifiers to approach the performance of operational amplifiers, but also to surpass them in terms of sound quality. As a result, they are able to deliver clear, rich, musical sound while remaining compact. This NCoreX technology combines the stability of the Hypex UcD series amplifiers with lower distortion and output impedance.
Audiophonics MPA-S250NC RCA Amplificateur Stéréo Class D NCore 2x250W 4 Ohm
SMPS Power Supply
The NCx252MP module also integrates the amplification stage. This consists of a regulated half-bridge switching power supply (SMPS) with synchronous rectification on the main output rails. Compact, powerful and efficient, this power supply is particularly suitable for supplying a Class D amplifier cleanly.
In addition, to offer complete compatibility with the voltages delivered by the various electrical networks, the power supply is equipped with an automatic input voltage doubler. The NCx252MP module also has an overload protection system.
Connectivity
The MPA-S250NCX amplifier has a stereo unbalanced RCA input with gold-plated connectors. The amplifier output is made on Elecaudio BP-209 24k gold-plated speaker terminals. They also accept banana plugs or forks for quick and easy connections. A 5-12V trigger connector in 3.5mm Jack format allows to control the automatic ignition of the amplifier when integrated in a compatible system. Finally, a bistable button allows the device to be switched on.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
100% Aluminum case
We integrate this Hypex NCoreX NCx252MP amplifier in a 100% black brushed aluminum case. This case offers an elegant finish, the thick walls giving it a great resistance, allowing to protect the components as it should. The natural conduction of the aluminum, as well as a studied air flow, allow to dissipate the heat produced by the module. In addition, the case is silk-screened on the front with the NCore logo and on the back with the nomenclature of each input/output.
Its very compact size, with a small width, allows to reduce the footprint to a minimum, offering high performance in a small space.
Test du Audiophonics MPA-S250NC par AudioScienceReview (Amir)
Audiophonics has produced one adorable stereo amplifier! I just want to sit there and look at it. :) Fortunately beauty goes beyond the skin, sporting a performance Hypex class D amplifier, producing top class results in all the measurements. You get near state of the art performance at bargain prices with scant space needed to dedicate to the amplifier. "
Product typeAmplifier
ClassD
Number of channelStereo (2)
Max. power (@ 1kHz, THD=1%)2x150W @ 8Ω
2x250W @ 4Ω
2x180W @ 2Ω
Input1x Unbalanced Stereo RCA
OutputSpeaker terminals
Trigger5-12V
THD+N0.0015%
SNR121dB
Output noise30µV
Output impedance1.5mΩ
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivityMax Power at 1.66V RMS
Supply voltage230V / 110V (automatic switch)
Case materialBrushed Aluminium
Total dimensions (WxDxH)145 x 355 x 64mm
Weight1860g
Package1x Audiophonics MPA-S250NCX RCA
1x Power cable
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)150.0
30 reviews
My EndGame amp
Salut, am cumparat acest amplificator dintr'un impuls de moment de pe OLX. Stiam despre modulele Hypex dar am ezitat achizitia.
Dupa aproape o luna de la achizitie pot sa spun urmatoarele:
Constructia este robusta, cutia aparatului arata bine, materiale si comectica de calitate.
Prin dimensiuni poate fi pozitionat si vertical ocupind foarte putin loc.
Cuplat la iesirea unui WIIM Ultra produce un sunet dinamic, echilibrat si foarte detaliat. Puterea este pe masura.
Boxele pe care le'am ascultat pe aceast setup sunt Monitor Audio Bronze 100 si Monitor Audio Silver 100 7G. Pot sa spun ca MPA250ncx la aduce la "viata", sunetul produs s'a transformat major fata de Denon PMA30 sau chiar WIIM AMP Ultra. Se simte imediat un control mai bun al boxelor si un sunet mai "aerist" si mai bine conturat.
Cu boxele Focal Theva No.1 si Heco Aurora 300, aflate in dotare, practic se obtine cel mai bun sunet pe care aceste boxe il poate produce. Toate boxele suna mai bine acum.
Cu acest amp se poate diferentia clar caracterul fiecarui set de boxe. Super!
Conexiunea dintre WIIM Ultra si MPA-S250ncx am facut'o cu cablu Sommer Cable Spirit LLX (0,8m) iar de la MPA-S250ncx la boxe cu Sommer Cable Orbit 225 MK2(2,5m), cu rezultate foarte bune .
Totusi utilizand si alte cabluri RCA-RCA de interconexiune intre WIIM Ultra si MPA-S250ncx pe canalul din dreapta, in repaus, se aude un foarte usor riplu, abea sesizabil dar se aude.
Ramane sa depistez de unde apare acest riplu.
Datorita sunetului excelent, performantelor superioare si pretului accesibil recomand acest amplificator.
This review has been posted for AUDIOPHONICS MPA-S250NCX RCA Power Amplifier Class D Stereo Ncore NCx252MP 2x250W 4 Ohm
Excellent
Très bon ampli qui vient remplacer un vieux dinosaure Akai et me fait redécouvrir ma paire de Borea BR04, couplé à un Wiim Ultra. Les basses sont précises et claires, les autres fréquences sont bien à leur place. Du bonheur. Je reprocherai juste la forme tout en longueur de l’ampli, pas forcément simple à placer. Expédition rapide et envoi soigné.
Best choice for this money
This amplifier is simply a sensation compared to my Marantz PM5003! Paired with the WIIM Ultra and KEF C7X, it delivers a truly mind-blowing musical experience. The entire soundstage has opened up, everything is clearly separated, the bass is tight and punchy, and the clarity is incredible. I’m listening to lossless and FLAC formats from a USB drive. Highly recommended — great job, guys!
Another masterstroke by Audiophonics
The power amplifier is exceptional. I bought it to drive my two JBL LS120P subwoofers converted to passive, replacing my TRANSAUDIO D5PRO, which is another excellent amplifier but does not have the technical specifications suitable to drive those subs. The Audiophonics proved to be extremely brilliant, balanced, precise, dynamic as it should be, perfect in every circumstance, both in a 2.2 and a 5.2.4 configuration. The bass is noticeable, definitely, but you never perceive its source: the subs "disappear," a sign of excellent integration into the system. Moreover, I purchased it on Friday afternoon, it was shipped on Monday afternoon, and on Wednesday morning it had already arrived in Rome. Another masterstroke by Audiophonics. Truly, thank you again.
Really really good - but capacitators are not Japanese like in pic
Truly fantastic amp - but am a bit disappointed: the capacitators in the picture are top Japanese ones - what I actually got were very average Chinese ones (Aishi). Will probably never make a big difference IRL but please update the pictures, it is a bit misleading.
 (3)
The Audiophonics MPA-S250NCX RCA is a stereo amplifier based on an amplification module Hypex NcoreX NCx252MP. This solution is ideal for anyone...
