FOSI AUDIO V3 MONO COMBO Pack 2x Mono Amplifiers + Power Noise Reducer + Power Adapter
With the Mono Combo Pack, Fosi Audio offers a product pack tailor-made for a dual mono installation. It consists of two V3 Mono amplifiers, a power supply noise reducer, a 48V 10A mains adaptor and a dual DC jack to power your two amplifiers.
4.8 / 5
By buying this product you get 28 loyalty points
Reference : 20935
289,00 €tax incl.
240,83 € tax excl.
Shipping date: 28-04-2026.
Fosi Audio V3 Mono ComboPack 2x Fosi Audio V3 Mono Amplifier + Fosi Audio Power Noise Filter + Power Adapter 48V DC 10A Fosi Audio + Fosi Audio Jack DC Doubler
FOSI AUDIO V3 MONO COMBO Pack : View of the pack contents
With the Mono Combo Pack, Fosi Audio offers a product pack tailor-made for a dual mono installation. It consists of two V3 Mono amplifiers, a power supply noise reducer, a 48V 10A mains adapter and a dual DC jack to power your two amplifiers.
Fosi Audio V3 Mono: Class D amplifier TPA3255 240W 4 Ohm
The Fosi Audio V3 MONO is a compact and powerful mono amplifier at an affordable price. It is based on a TI TPA3255 amplifier chip and can deliver 240W of power at 4Ω. In addition to its amplification chip, this amplifier is equipped with a number of audiophile components such as Japanese ELNA and German WIMA capacitors and a pair of TI NE5532 DIP8-mounted AOPs, so you can replace them if you want a specific sound coloration. In terms of connectors, the Fosi Ausio V3 Mono offers an XLR/ balanced 6.35mm jack combo input, an RCA input and a speaker terminal block for the output.
View complete product page of Fosi Audio V3 Mono
Fosi Audio V3 Mono one on top of the other
Fosi Audio Power Noise Filter with DC jack doubler
Fosi Audio Power Noise Filter: 12-55V 10A with DC jack doubler
This Fosi Audio power supply noise reducer accepts a voltage range of 12V to 55V and a current of 10A via DC 5.5/2.5mm jack. It reduces power supply noise and protects your equipment from possible electromagnetic interference thanks to capacitors and filter coils. Another advantage of this power supply noise reducer is that it reduces the impact of power surges and current spikes on devices, thereby extending their life.
View complete product page of Power Noise Filter
Fosi Audio AC/DC Switching Power Adapter: 100-240VAC to 48V DC 10A
This Fosi Audio mains adaptor takes a 100-240VAC input voltage and provides a 48V DC output voltage for a maximum current of 10A, i.e. a power of 480W. Its output connector is a 5.5/2.5mm DC jack. This power supply unit uses gallium nitride (GaN) to provide a reliable power supply for your equipment.
View complete product page of Fosi Audio AC/DC Switching Power Adapter
Product typeAmplifiers + Mains adapter + Noise reducer
Contenu du package2x Fosi Audio V3 Mono
1x Fosi Audio Power Noise Filter
1x Fosi Audio AC/DC Switching Power Adapter
1x DC jack doubler
Fosi Audio V3 Mono specifications
Product typeMono class D Amplifier
Inputs1x Balanced XLR/jack 6.35mm combo
1x RCA (choice of 25dB or 31dB gain)
Outputs1x Speaker terminals
Amplification chipTI TPA3255
OPA2x TI NE5532
Output power240W @ 4Ω 48V/5A
160W @ 6Ω 48V/5A
120W @ 8Ω 48V/5A
100W @ 4Ω
32V/5A
65W @ 6Ω 32V/5A
55W @ 8Ω 32V/5A
Speaker impedance2Ω - 8Ω
Frequency response10Hz-30kHz(±0.06dB)
SINADXLR: 101dB
RCA: 93dB
Total harmonic distortion (THD)< 0.006%
Signal-to-noise ratio (SNR)≥ 123dB
Gain setting (RCA input)19dB
25dB
Power supply32-48V DC
Product dimensions142 x 107 x 41mm
Fosi Audio Power Noise Filter specifications
Product typePower supply filter
Operating voltage12-55V DC
Max. operating current10A
ConnectorsJack DC 5.5/2.5mm
AC/DC Switching Power Adapter specifications
Product typePower adapter
Input voltage100-240VAC 50/60Hz
Output voltage48V
Output current10A
Input connectorIEC C14
Power cable included
Output connectorJack DC 5.5/2.5mm (câble 1.5m)
Block dimensions195 x 94 x 42mm
InputXLR
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chipTPA3255
Power (W)240.0
5 reviews
La claque !
Passer d’un ampli NAD 320BEE vieillissant à ce couple de petits blocs mono était un peu un saut dans l’inconnu. Néanmoins, compte-tenu du prix et rassuré par les avis, je n’avais pas grand-chose à perdre et J’étais plutôt confiant.
L’écoute s’est faite à partir d’un lecteur CD branché sur un Dac Sanscrit 10th. Les deux enceintes sont des colonnes Gemme Audio Tanto v2.
Je ne sais pas ce qui m’a surpris le plus à la première écoute: cette incroyable, stéréo (une séparation des canaux dingues) ? Un son détaillé, mais jamais agressif et très naturel ? Un punch incroyable mais jamais d’excès ? Honnêtement, j’ai vraiment du mal à leur trouver un défaut. En plus ils sont discrets, plutôt jolis et bien construit. J’ai dû ajouter des fiches bananes à mes câbles d’enceintes car ils ne rentrait pas dans les borniers qui sont un peu justes (allez, seul défaut).
Côté puissance, rien à redire. Après, mes enceintes possèdent un rendement confortable, j’ai même activé l’atténuateur derrière les amplis car je n’avais pas besoin de tant de puissance. Les amplis chauffent pas mal, mais si vous ne les empilez pas, ça se passe bien.
Bref je rejoins un des autres avis, et je dirais également que c’est un de mes meilleurs achats ces dernières années.
J’envisage même d’en reprendre une paire pour des moniteurs de studio passif.
Conclusion: pour le prix = stupéfiant!
This review has been posted for FOSI AUDIO V3 MONO COMBO Pack 2x V3 Mono Amplifier + Power Noise Filter + Power Adapter 48V DC 10A
Unbelieveable!
If you are on a budged and are looking for a serious upgrade on the power amp side … this is it! You’ll never get closer to the power and sound quality of a reference lass amp for so little money like with these Fosi V3 Monos. Really fantastic! My best buy since years! Go for it!
étonnant
Très bon amplificateur, un chouille généreux vers 100 Hz . Rapport qualité/prix 10 sur 10. Après ,la tenue dans le temps ???.
Petit mais ..... puissant
Proportionnellement aussi puissant et musical que sa taille ne le laisserait penser . Raccordé(s) a mes enceintes Martin gamma 315 dotées d'un 38 cms dans le grave , ce n'est que du bonheur . Quel poids et tension , dans le médium aigu il n'est pas en reste non plus , écoutez du xylophone et savourez . C'est honnêtement le meilleur achat que j'ai fait ces dernières années .
Peter Š.
The sound is very good, with a high heat output.
Very good value for money.
With the Mono Combo Pack, Fosi Audio offers a product pack tailor-made for a dual mono installation. It consists of two V3 Mono amplifiers, a power...
