DAYTON AUDIO DAX66 Multiroom Amplifier 12 Cchannel
The Dayton Audio DAX66 is a 12-channel Class D multiroom amplifier. It offers considerable output power for a wide range of spaces, with 12x 50W under 4 ohm and up to 100W under 8 ohm in bridged mono mode.
By buying this product you get 119 loyalty points
Reference : 21006
1 199,01 €tax incl.
999,17 € tax excl.
Dayton Audio DAX66 Multiroom Amplifier 12-channel Class D 12x50W @ 4 Ohm
DAYTON AUDIO DAX66 picture
The Dayton Audio DAX66 is a 12-channel Class D multiroom amplifier. It offers considerable output power for a wide range of spaces, with 12x 50W under 4 ohm and up to 100W under 8 ohm in bridged mono mode. This amplifier also boasts numerous advantages, such as a high expansion capacity thanks to 6 preamplified RCA outputs and connectors offering the possibility of adding 2 additional interfaces for amplification of up to 18 zones in stereo. An IR remote control allows the DAX66 to be controlled remotely, but it also comes with 6 wall-mounted controllers for ultimate convenience. The Dayton Audio DAX66 is therefore ideal for multiroom use or, more simply, home cinema use.
The Dayton Audio DAX66 package
Dayton Audio DAX66 overview
1ON / OFF / Standby button
2LED indicators per channel
36x Stereo RCA line output (preamp)
4Bridge / Stereo mode switch
56x Stereo speaker output on terminal block
64x RCA stereo input
73.5mm stereo jack input
83.5mm stereo jack or Toslink optical input
9IN / OUT expansion connectors
106x Trigger out 12VDC
117x IR output (1 per channel and 1 global)
12Trigger IN 12VDC
13Trigger IN 12VDC for Mute function
14RS-232 port
15Automatic gain control
16Connectors for wall-mounted control hub
17110V/220V mains power selector switch
18Power supply port
Product typeMultiroom amplifier
Number of channels12
Bridgeable
Inputs4x RCA stereo
1x 3.5mm stereo input
1x 3.5mm stereo or optical Toslink input
Outputs6x Stereo speaker terminal output
Output power12x 25Wrms @ 8 ohm
12x 50Wrms @ 4 ohm
6x 100Wrms @ 8 ohm (bridge mode)
SNR> 85dB (A-WT)
THD< 0.1%
Frequency response20Hz-20kHz
Input impedance> 47Kohms
INput sensitivity250mv
Trigger voltage12V DC
Infrared frequency38kHz
Power supply115VAC/60Hz or 220VAC/50Hz selectable via switch
Dimensions43 x 9 x 41.7cm
Weight10.8kg
Package1x Dayton Audio DAX66
1x IR remote control
6x Wall-mounted remote control
1x Hub for connecting wall-mounted remote controls
1x Expansion cable
1x Mounting rack kit
1x Mains power cable
InputJack 3.5mm
OutputSpeaker terminal
Channel12
Amplifier chipN/A
Power (W)50.0
Remote ControlYes
DAYTON AUDIO DAX66 Multiroom Amplifier 12 Channel Class D 12x50W 4 Ohm
The Dayton Audio DAX66 is a 12-channel Class D multiroom amplifier. It offers considerable output power for a wide range of spaces, with 12x 50W...
