MATRIX ELEMENT P2 Power Amplifier Class D Stereo 2x230W / Mono 1x850W 4 Ohm
Continuing the Element line's identity, the Matrix Audio Element P2 power amplifier inherits a sleek, modern design that integrates seamlessly with the other models in this family. Thanks to its highly efficient Class D architecture, it can easily be integrated into a system, providing significant power to your speakers.
By buying this product you get 597 loyalty points
Reference : 17504
1 999,00 €tax incl.
1 665,83 € tax excl.
Shipping date: 09-07-2025.
MATRIX Element P2
Power Amplifier Class D Stereo 2x230W / Mono 1x850W 4Ω
Element P2 Amplificateur de puissance Class D stéréo 2x230W / 1x850W 4Ω
Multiple input modes
The Element P2 is equipped with both XLR and RCA inputs. So whether your source device is single-ended or balanced, it can be easily combined with the P2, reproducing the original audio message faithfully and dynamically.
Stereo mode and ICEpower 250ASX2 amplifier module
In stereo mode, the Element P2 provides a power of 230W per channel under 4Ω thanks to its ICEpower 250ASX2 module, allowing it as well and difficulty to accompany bookshelf speakers as columns. It then reveals a beautiful sound image and interprets with great accuracy every detail of the audio signal.
Double the power in mono
Need more power? Two Matrix Audio Elements P2 can be configured and combined in mono mode. In this configuration, each amplifier powers one speaker, delivering no less than 850W on each channel. This is enough to bring out the full potential of your HiFi system in the best possible conditions.
12V Trigger
With a 12V trigger input and output, the Element P2 can be connected to the devices before and after it. This makes it possible to automate the switching on and off of your entire system as soon as a signal is received from one element of the chain.
High quality WBT connectors
The Element P2 is finished to an exemplary standard with WBT-0703 Cu terminals for connecting your speakers. These have copper contacts with gold plating, ensuring excellent conductivity and durability. They also offer optimal contact with your cables.
Anti-vibration feet with ceramic balls
The Matrix Audio Element P2 is also equipped with CBVB feet. The inside of these feet integrates a silicone pad and 6 ceramic balls. They reduce the noise caused by mechanical vibrations. The sound transparency is improved, creating a wide and clear sound image.
Product typePower amplifier
Inputs1* Balanced stereo XLR
1* Single-ended stereo RCA
1* Mono XLR
OutputsSpeaker terminals
12V triggerIn / Out
Output powerStereo: 2*230W @ THD+N 1%, 20Hz-20kHz, 4Ω / 2*110W @ THD+N 1%, 20Hz-20kHz, 8Ω
Mono: 1*500W @ THD+N 1%, 20Hz-20kHz, 8Ω / 1*850W @ THD+N 1%, 20Hz-20kHz, 4Ω
Dynamic rangeStereo: 112dB (A-weighting)
Mono: 121dB (A-weighting)
Frequency response20Hz-20kHz ±0.3dB
THD+NStereo: 0.008% @ 1W
Mono: 0.004% @ 1W
Output impedanceStereo: < 25mΩ
Mono: < 30mΩ
Input impedance47kΩ
GainStereo RCA: 28dB @ 1kHz
Stereo/Mono XLR: 34dB @ 1kHz
Supply voltage100-120VAC 50/60Hz
220-240VAC 50/60Hz
Standby consumption< 5W
Max consumption< 1250W
Dimensions (L*P*H)340*259*58mmmm
Weight3.7kg
ColorSilver
Package1* Matrix Element P2
1* Power cable
InputXLR
OutputSpeaker terminal
ColorSilver
Channel1 (Mono)
Channel2 (Stereo)
Amplifier chipICEpower 250ASX2
Power (W)230.0
Power (W)850.0
3 reviews
Rodage
Il lui faut qq jour de rodage pour avoir plus d'ouverture mais les timbres sont la des le début
Utilisé avec un musician en pre ampli
This review has been posted for MATRIX ELEMENT P2 Power Amplifier Class D Stereo 2x230W / Mono 1x850W 4 Ohm
Ne sonne pas comme un class D
Belle découvert !
sonne comme un a/ab
Merci pour les -20%
I‘ve bought this small Amp via Audiophonics, shipping was very fast with DPD to Germany even in the season with a lot of snow. This little Amp is a jewel in sound and it is well fabricated and my perfect fit to my also new Matrix Audio Element X2 Pure. This combo replaces a old Class A Setup to save space and to be more „wife“ friendly. I could recommend Audiophonics with a unbeatable price offer and Matrix Audio. It‘s perfect for a small high end Audio setup. Enjoy the sound and the optics
Continuing the Element line's identity, the Matrix Audio Element P2 power amplifier inherits a sleek, modern design that integrates seamlessly...
