The Singxer SA-90 class A/B mono power amplifier delivers ultra-low-noise, ultra-low-distortion performance while offering no less than 200W output power at 4 ohms. Like most power amplifiers on the market, it adopts a monoblock design with a simple, minimalist look.
On the interface side, there's a balanced input on an XLR connector, as well as an RCA input with a GND terminal and, of course, a speaker terminal for the output. This amplifier also features audiophile components such as a toroidal transformer rated at 300W, 20,000uF electrolytic capacitors and no less than 4 low-noise discrete power supplies, as well as full speaker protection functions: power on/off, overtemperature, short circuit, overload and much more. A further feature is the ability to adjust its gain to two levels, 16dB or 23dB, enabling it to adapt to different input signals if required.
1 | GND |
2 | RCA input |
3 | XLR output |
4 | Input selection switch |
5 | Speaker terminal block |
5 | IEC power supply / Power switch |
Product type | Power amplifier |
Amplification | A/B class |
Channel | Mono |
Inputs | 1x Single-ended RCA 1x Balanced XLR GND terminal |
Output | Speaker terminal |
Max. output power | 200W @ 4 ohm (THD+N=1%) 120W @ 8 ohm (THD+N=1%) |
Rated output power | 180W @ 4 ohm 90W @ 8 ohm |
Noise level | < 2.3uv (A-weighted, RCA input, Low gain) |
SNR | > 140dB (A-weighted, RCA input, Low gain) |
THD+N | -110dB (A-weighted, 20W, 8 ohm) |
Gain adjustment | Low : 16dB High : 23dB |
Power supply | 115-230V AC |
Dimensions | 216 x 320 x 80mm |
Weight | 7.5kg |
Package | 1x Mono power amplifier Singxer SA-90 1x Power supply cable |
Input | RCA |
Input | XLR |
Color | Black |
Channel | 1 (Mono) |
Class | Class A / AB |
Amplifier chip | N/A |
Power (W) | 200.0 |
Remote Control | No |
