AUDIOPHONICS GREYHOUND Power Cable Schuko IEC C15 OCC / OFC Copper Shielded 3x2.5mm² 1.5m
Hand-assembled in our workshops in France, the Audiophonics Greyhound Schuko to IEC C15 power cable offers an excellent solution for electrically connecting your HiFi equipment, ensuring clean and stable signal transmission. Based on Elecaudio and Viborg components using quality materials, the cable ensures that the electrical signal arriving at your audio equipment does not add unwanted noise.
Reference : 17996
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 06-05-2025.
Audiophonics Greyhound Power Cable Schuko IEC C15 OCC / OFC Copper Shielded 3x2.5mm² 1.5m
Elecaudio CS-361B cable
The Audiophonics Greyhound is based on an Elecaudio CS-361B cable. It features three conductors made of OCC and OFC copper Litz wires and an OFC copper ground drain wire, ensuring excellent electrical conductivity. Each conductor is insulated with a PTFE sheath and the whole cable is double-shielded with aluminium foil and copper braid, effectively repelling interference.
Viborg VE502G & VF502G connectors
The cable is terminated on the one hand with a male Viborg VE502G Schuko connector (Type E/F) and on the other hand with an Viborg VF502G IEC C15 connector. Both are high quality, with pure copper contacts and triple plating in OFC copper, silver and 24k gold for perfect conductivity and resistance to oxidation.
Product typePower cable
Connectors1* Male Schuko (Type E/F)
1* IEC C15
Length1.5m
Cable conductors materialOCC / OFC copper
Cable conductors section3x2.5mm²
Cable conductors insulationPTFE
Cable double shieldingAluminum foil
Copper braid
Cable outer sheathPVC
Cable diameterØ18mm
Connectors contacts materialPure copper
Connectors contacts platingOFC copper
Silver
Gold 24k
Connectors diameterØ39mm
ColorCable: Silver
Connectors: Silver and black
Length (m)1.5
ShieldingYes
Section (mm²)2.5
ConnectorType F (CEE 7/3 - CEE 7/4)
ConnectorIEC C15
ConnectorType E (CEE 7/5 - CEE 7/6)
ConnectorSchuko
2 reviews
Déroutant
dans les basses fréquences.
J'apporte une nouvelle fois mon avis sur ce câble mais cette fois-ci sur la version montée par audiophonics.
Dès la première écoute, on retrouve toutes les qualités du câble d'elecaudio, c'est à dire un éclaircissement de tout le spectre, un aigu beaucoup plus précis et plus riche, un médium remarquable et des basses tendues avec de la définition.
Ce câble me plaisant énormément, j'ai décidé d'harmoniser mon système, mon ampli ainsi que l'alim du pré-phono sont alimentés par ce câble secteur. Les câbles de modulation sont des sommercable Epilogue.
Après un petit rodage de quatre cinq après-midi/matinées, je suis assez stupéfait du résultat. C'est même d'ailleurs un peu déroutant. Sur la trompette de Jon Hassel, les montées dans les aigus sont enrichis d'énormément de matières et de détails ! Pareil, sur le disque de la planète sauvage (BO d'Alain Goraguer), j'ai jamais entendu autant de maîtrise et de définition dans les basses fréquences. La basse est d'une propretée et pourtant elle garde tout son côté organique. Bluffant. De même sur le disque d'illustration sonore Guy Pedersen - contrebasse, ce dernier instrument n'a jamais sonné aussi réaliste et vivant.
Ce qu'on peut retenir sur ce câble est qu'il apporte beaucoup de définition et de maîtrise sur tout le spectre audible et cela sans artifices !
Bravo à audiophonics, car pour le prix proposé, ce câble est stupéfiant.
 (3)
This review has been posted for AUDIOPHONICS GREYHOUND Power Cable Schuko IEC C15 OCC / OFC Copper Shielded 3x2.5mm² 1.5m
Bon résultat sur les gros amplificateurs Home Cinéma
A un prix contenu, ce câble offre une alimentation de qualité à mon amplificateur Denon 8500 HA qui a une consommation électrique élevée (900 Watts). A l'écoute, bonne amélioration du son, c'est neutre et apporte un son puissant à l'installation, cela me semble fidèle notamment en utilisation musicale, pas de coloration. Autrement, malgré sa grosse section, le câble peut se plier aisément donc permettre un branchement quand on a peu d'espace ce qui est mon cas. Cela respire la qualité de fabrication notamment au niveau des prises. Audiophonics me l'a conseillé pour alimenter les grosses centrales électriques en classe AB du type de mon Denon.
Hand-assembled in our workshops in France, the Audiophonics Greyhound Schuko to IEC C15 power cable offers an excellent solution for electrically...
