AUDIOPHONICS STEALTH Power Cable Schuko C15 OFC Copper Shielded 3x3.5mm² 1.5m
The power cable is the first element in a HiFi system, so its quality is not to be neglected. We offer you the Audiophonics Stealth, a high-end power cable designed in our workshops in France. It only includes high quality components, selected for their electrical performance and their ability to transmit a clean signal.
4.9 / 5
Reference : 11846
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 16-07-2025.
Audiophonics Stealth Câble Secteur Schuko C13 Cuivre OFC Blindé 3x3.5mm² 1.5m
Elecaudio CS-331B Cable
The Elecaudio CS-331B is a power cable that integrates materials and technologies usually reserved for products with much higher prices. Thus, each conductor consists of 7 strands, themselves composed of 10 strands of OFC Copper with a diameter of 0.25mm each, for a cross-section per conductor of 3.5mm².
These 3 conductors are individually insulated by a PVC sheath and held in place by a Cotton insert providing both flexibility and firmness to the assembly..
The cable also has double shielding. The first one uses an Aluminium strip, while the second one is a screen made of finely braided Copper. Between these two shields, an OFC Copper drain wire runs through the entire cable to ensure a linear grounding to ensure reinforced protection against radio (RFI) and electromagnetic (EMI) interference.
The unit is protected by a thick 3.5mm thick PVC protection sheath, ensuring excellent cable durability. The cable is finally covered by a Viablue braided nylon sheath with the most beautiful effect.
Elecaudio PS-24GC and PI-24GC connectors
The Audiophonics Stealth is equipped with a Schuko Elecaudio PS-24GC connector and a IEC C15 Elecaudio PI-24GC. They have a transparent nylon body, allowing the inside of the connector to appear. All the metal parts and in particular the contact and ground parts are 24k Gold plated on a thickness of 3µ. This plating provides greater resistance to oxidation but also very good signal conductivity. In the Schuko connector, the conductors are placed in a Viablue OFC Copper protective tips and allow better contact with the connector clamping system.
Product typePower cable
Length1.5m
Connectors1x Schuko (Elecaudio PS-24GC)
1x IEC C15 (Elecaudio PI-24GC)
Connectors platingOr 24k 3µ
Cable conductors3x 3.5mm², OFC Copper
Cable shieldingAluminium foil
Copper braid
Cable conductors insulationPVC
Cable fillingCoton
Cable sheathPVC, 3.5mm
Cable covering sheathExtensible braided sheath, Nylon PET, Black (Viablue)
Cable diameterØ16mm
Voltage / Current250V / 16A
ColorsCable: Black
Connectors : Transparent and Black
Weight550g
Length (m)1.5
ShieldingYes
Section (mm²)3.50
ConnectorIEC C13
ConnectorSchuko
27 reviews
My highest recommendations!
Bought it together with the PANGEA IEC to C5 Platinum Gold Plated Crystal Plug Adapter to replace the included standard off the shelf power cord of the KEF LSX ii LT speakers and the result is spectacular!
I expected nothing less, so thank you AUDIOPHONICS.FR!!!
This review has been posted for AUDIOPHONICS STEALTH Power Cable Schuko C15 OFC Copper Shielded 3x3.5mm² 1.5m
Incroyable mais vrai...
Branché à un ampli Taga Harmony 25 B, a permis d'obtenir un son d'une pureté et d'un détail incroyables, et surtout sans AUCUNE dureté à une paire de Focal Aria 906, magnifiques enceintes biblio, mais aux aigus un peu durs pour mes oreilles jusqu'à présent, malgré plusieurs essais de différentes combinaisons ampli/câble de liaison enceintes-ampli/ pièces...
J'étais sur le point de m'en séparer, mais là il n'en est plus question !
Il va de soi que je ne regrette qu'une seule chose : ne pas avoir acheté ce câble secteur plus tôt, le jeu en valant largement la chandelle en l'occurrence...
trés bon cable secteur
Je rejoins les avis sur ce câble secteur,très bon rapport qualité prix.
Câble secteur au top
Ayant testé de ombreux câbles secteur de moyen et haut de gamme, le câble Audiophonics répond à mes attentes après avoir écouté toutes sortes de musique. Il transmet les harmoniques avec un minimum de pertes ou de colorations. A recommander. Merci Audiophonics pour cet excellent travail.
Vraiment bien
Je ne pensais pas avoir une influence sur le son.
Pourtant elle est là. Cela ne va pas améliorer la qualité du courant reçue, en revanche, on va fortement protéger les composants câbles etc. qu’il y a autour. Un câble joue le rôle d’une antenne quasiment et propage des parasites s’il n’est pas correctement blindé. Les câbles courent en général à une distance réduite les uns des autres.
Sans dépenser des milliers d’euros, en achetant chez audiophonics des câbles blindés correctement, avec de bonnes fiches, des câbles secteurs bien isolés on limite fortement le parasitage. Aussi bien en RCA, qu’en XLR.
J’ai une meilleure écoute avec tous ces ingrédients installés je suis ravis.
Merci à Audiophonics également pour leurs conseils avisés très utiles et neutre, leur patience.
The power cable is the first element in a HiFi system, so its quality is not to be neglected. We offer you the Audiophonics Stealth, a high-end...
