IFI AUDIO SUPANOVA Power Cable OFHC Copper Gold Plated Shielded with Active Noise Cancellation Technology 1.8m
The impressive iFi Audio SupaNova power cable delivers incredible performance to provide your audio system with a clean and stable electrical signal. The cable features Active Noise Cancellation2 technology, which effectively eliminates noise throughout the frequency range.
4.0 / 5
Reference : 15317
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 06-06-2025.
iFi Audio SupaNova
iFi Audio SupaNova Câble secteur Cuivre OFHC plaqué Or blindé avec Technologie d'annulation de bruit
The structure of the cable is totally symmetrical. It uses the brand's Ground Zero design, creating a central core that is completely free of magnetic fields.
The unbraided center ground wire is surrounded by conductors positioned in a double helix, protecting the ground wire from magnetic fields and therefore reducing ground noise. Each conductor is shielded to effectively reject internal and external RFI interference. The double helix design also achieves low inductance and capacitance, as well as constant impedance.
The cable is insulated with polymeric materials, including a high-performance thermoplastic that is moisture resistant and RoHS compliant.
The SupaNova also incorporates air-filled separator wires, an excellent dielectric that provides perfect separation between the neutral and phase conductor pairs.
Each conductor of the cable is made of high purity OFHC copper for excellent conductivity. The connector contacts are also made of copper with gold plating for optimal transmission. The cable is finally covered with an impact resistant polymeric sheath for increased durability.
Finally, great feature of this SupaNova, it is equipped with a module to control your connection with a polarity and ground indicator.
Product typePower cable
Length1.8m
Connectors1x Schuko
1x IEC C15
Conductors materialOFHC Copper
Shielding
TechnologyActive Noise Cancellation2
Noise reduction> 40dB (> 100x)
Surge protectionMax. 10000A @ 775V / 8/20uS
Weight690g
Cable diameterØ14mm
Length (m)1.8
ShieldingYes
Section (mm²)N/A
ConnectorSchuko
ConnectorIEC C15
L'effet est là
Installé en amont de la multiprise sur laquelle sont branchés mon préampli et mon ampli, le son est plus propre, plus précis.
En revanche sur mon DAC Denafrips Venus II je n'ai ressenti aucune amélioration. A voir avec d'autres DACs peut-être.
This review has been posted for IFI AUDIO SUPANOVA Power Cable OFHC Copper Gold Plated Shielded with Active Noise Cancellation Technology 1.8m
The impressive iFi Audio SupaNova power cable delivers incredible performance to provide your audio system with a clean and stable electrical...
