Connector
Max cable diameter (mm)
Rated current (A)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Luboš W.
Rating
I use the power supply as a symmetrical power supply (2 pcs) to a low watt amplifier. It is almost noise free, no problems so far.
Johan v.
Good but small
Good switch but the button is small so not thumb size but more pinky sized
Johan v.
My favorite hook up wire
Easy to strip with a good stripper
Power Plugs & Sockets
Power Plugs & SocketsDiscover our wide range of power plugs, IEC, Schuko or other formats, to design your HiFi power cables.
  • IEC Connectors
    IEC Connectors
    Discover our range of IEC connectors of all sizes, for the design of your HiFi power cables.
  • Schuko Connectors
    Schuko Connectors
    Discover our range of Schuko power connectors, for the design of your HiFi power cables.
  • Various Internationals
    Various InternationalsDiscover our range of sector connectors in international formats, for the design of your HiFi power cables.
  • Schuko Inlets
    Schuko Inlets
    Discover our range of Schuko plugs, for the installation of your wall sockets.
  • IEC Inlets
    IEC Inlets
    Discover our range of IEC plugs of all sizes, for the integration of a power connector on your HiFi devices.
