AUNE SC1 EVO Clock OXCO Black
The Aune SC1 EVO is the brand's new high-performance external clock. This clock features an OXCO crystal oscillator designed in collaboration with Titan Audio Lab for extremely precise rendering. The device also features a new Vivid UI color interface for real-time monitoring of device performance.
Reference : 20823
699,00 €tax incl.
582,50 € tax excl.
Aune SC1 EVO Clock OXCO 10MHz Sine / Square wave signal Black
Aune SC1 EVO picture
The Aune SC1 EVO is the brand's new high-performance master clock. This clock features an OXCO crystal oscillator designed in collaboration with Titan Audio Lab for extremely precise rendering. The device also features a new Vivid UI color interface for real-time monitoring of device performance. The Aune SC1 EVO features two 10M sine wave outputs and two 10M square wave outputs with phase synchronization of less than 0.00001°, ideal for connecting multiple devices. It can also be supplied from either DC or AC sources. Its power supply stage incorporates a low-noise, high-current LDO to provide a clean, stable electrical signal to the OCXO clock. This clock is ideal, for example, for use with the brand's S9C Pro headphone amplifier DAC.
Aune SC1 EVO benefits
Aune SC1 EVO overview
1Screen
2Multifunction button
32x 10Mhz sine signal output
42x 10Mhz square wave output
5DC9V power connector
6Power on / Mains supply
Product typeClock
Outputs2x 10Mhz sine signal output
2x 10Mhz square wave signal output
Frequency accuracy+/- 50ppb
Frequency stability< 0.01ppb
Output amplitudeSquare wave signal ≥ 9dBm
Sine wave signal ≥ 5dBm
Output impedance50 ohm
Close phase noise-100dBc
Short-term stability2E-12
Heating timeBasic 10min
Power supply100-240VAC
9VDC 2A
Operating temperatureNormal operation: 0°C-50°C
Optimum operation: 15°C-35°C
Dimensions288*211*63mm
Weight2kg
Package1x Aune SC1 Evo Black
1x Power cable
AUNE SC1 EVO Clock OXCO 10MHz Sine / Square wave signal Black
The Aune SC1 EVO is the brand's new high-performance external clock. This clock features an OXCO crystal oscillator designed in collaboration...
