IAN CANADA UCDUMPER Smart Ultracapacitors Discharger
The Ian Canada UcDumper enables ultracapacitors to be safely discharged for the purpose of removing or replacing them from the supply circuit in which they are used. This small discharge module features an intelligent current-limiting function, and is simply operated via wire connection with the cables supplied.
Reference : 20905
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 01-12-2026.
Ian Canada UcDumper Smart Ultracapacitor Discharger
IanCanada 63A UcDumper
Take care not to touch any hot surfaces when the UcDumper is in use.
The heat sink is isolated from the circuit. But make sure that the rest of the circuit is not short-circuited.
The recommended voltage range is 0V to 5V. A higher voltage is acceptable, but the discharge time will be longer. Never exceed 15V. If the voltage is higher than 8V, there may be some smoke for a very short time, but there's nothing to worry about.
Branchement du IanCanada 63A UcDumper
When will the discharge be complete?
When the voltage of the supercapacitors drops below 0.1V, or one hour after the UcDumper LED has gone out. But you can also simply discharge them overnight.
If the voltage of a single supercapacitor is still above 0.1V after it has been fully discharged, what should I do?
You need to discharge the remaining voltage by connecting the two pins of each supercapacitor to T1 and T2 of the UcDumper, using the cable with alligator clips.
Product typeUltracapacitors discharger
Indicator LEDLights up when current exceeds 1.5V
Rated power10W
Nominal resistance3.3 ohms @ 25°C
Max. discharge voltage15V
Discharge current1A @ 3.3V
1.5A @ 5V
Current limitation3A (Once the limit is reached, the discharge current will be automatically reduced to a lower level to keep power consumption and UcDumper temperature within a safe range).
Package1x Ian Canada UcDumper
1x Molex cable 2 pins
1x Cable PH2.0 2 pins
Tolerance (%)N/A
Capacitor capacitance (µF)N/A
Rated voltage (V)N/A
Capacitor typeN/A
Capacitor formatNC
The Ian Canada UcDumper enables ultracapacitors to be safely discharged for the purpose of removing or replacing them from the supply circuit in...
