Ian Canada's UcPure is a supercapacitor power module. It uses large supercapacitors of 3000F to provide a high-performance power supply. It is a totally passive module, with no feedback and no active components. In pure output mode, only the set of pre-charged supercapacitors is applied to the load.
The UcPure is equipped with a synchronous charging function (SYNC) to enable the supercapacitors to be recharged when music playback stops.
The Ian Canada UcPure Quad is an improved version of the UcPure. It uses a new architecture to run four 3000F supercapacitors in parallel (two groups), to deliver exceptional performance. It is thus capable of delivering a current of up to 4800A with an internal ESR of just 0.23mΩ (continuous output mode). The UcPure Quad therefore represents a high-quality, low-noise, high-dynamic power supply system for enhancing the sound quality of sensitive audio peripherals such as low-jitter clocks, DACs, FIFO buffers and many other types of circuitry.
Supercapacitors are sold separately.
Key features:
| Specifications | |
| Product type | Supercapacitor power supply module |
| Output voltage | 5V DC (default) or 3.3V |
| Input voltage | 12V AC or 15-20V DC |
| Input | Screw terminals |
| Output | Screw terminals |
| Output voltage (V) | 3.3 |
| Output voltage (V) | 5.0 |
| Output current (A) | 4800 |
| Input voltage (V) | 15.0 |
| Input voltage (V) | 12.0 |
| Input voltage (V) | 20.0 |
| Power Supply | Ultracapacitor power supply |
