WONDOM PS-BC12111 BCPB2 Battery BMS Power Supply / Charger Module Lithium 18650 with Protections
This Battery Management System (BMS) functions as both a power supply and a Li-Ion battery charger type 18650 and has 3 slots and a complete protection system. Very compact, it can power small systems or become a real portable battery. With its MPPT regulators, this module can therefore also operate as a charger, once powered by a voltage of 15-24V. The module has 4-level indicators to display the battery charge level.
Reference : 13079
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 06-10-2026.
Wondom BCPB2
Wondom BCPB2 Chargeur de Batterie Lithium 18650 avec Protections
This Battery Management System (BMS) functions as both a power supply and a Li-Ion battery charger type 18650 and has 3 slots and a complete protection system. The module provides an output voltage of 12V DC. Very compact, it can power small systems or become a real portable battery. With its MPPT regulators, this module can therefore also operate as a charger, once powered by a voltage of 15-24V. The module has 4-level indicators to display the battery charge level.
The integrated protection system operates constantly and monitors each cell voltage, load and discharge current, and environmental temperature to provide protection against overloads, overcurrents and excessive temperatures.
Wondom explains how the product works
In this video, the Wondom brand presents the product as well as its features and protections but also its possible applications. In the middle of the video, a series of tests allows to highlight the values measured on this charger.
Module operation
Output voltage12V DC
Supported batteriesLi-Ion 18650
ProtectionsOvercharge / Over-discharge
Overcurrent
Over temperatures
Solar charging compatibilityYes
Number of battery slot3
Charging indicatorsYes
Power supply15-24V DC via Jack DC 5.5/2.1mm or 2 poles connector
Max discharge current10A
Max charge current1.5A
PackagePower supply module / 1x Cable XH 4 PIN
Electrical characteristics
ParameterConditionsMin.Typ.Max.Unit
Charging voltage-151924VDC
Standby powerV1=V2=V3=2V--10uA
Max discharge current---10A
Charge current--1.5-A
Overcharge detection voltageSingle cell-4.235-V
Overcharge release voltageSingle cell-4.18-V
Overdischarge detection voltageSingle cell-2.8-V
Overdischarge release voltageSingle cell-3-V
Operating temperature--2050°C
Min and max temperature--2020105°C
InputPCB Connector
OutputPCB Connector
Output voltage (V)12.0
Output current (A)10.0
Input voltage (V)N/A
Power SupplyBattery
Akkus werden einwandfrei geladen
Die Kompatibilität zu den JAB2 und JAB3 ist gegeben, mehr wollte ich nicht. Es ist aber ein eigenständiges Ladeboard und kann nicht kaskadiert werden.
This review has been posted for WONDOM PS-BC12111 BCPB2 Battery BMS Power Supply / Charger Module Lithium 18650 with Protections
This Battery Management System (BMS) functions as both a power supply and a Li-Ion battery charger type 18650 and has 3 slots and a complete...
