works perfectly with the volumio audiophonics on/off plugin.
just a question, there is a connection for an infrared sensor, how does this work? can't find anything about it.
Power Management / Power Supply for Raspberry Pi
This power management module with integrated linear regulation for Raspberry Pi allows you to deliver 5V from a voltage source ranging from 7V to 12V and thus to properly switch your Raspberry Pi on and off like a family ATX PC. Once the button is pressed, the Raspberry Pi is powered and your software solution starts in a classic way. For the shutdown, an order is sent to the system to shut down, before the module cuts off the power supply. An LED output to connect to the button is available to monitor the progress of the different steps of switching the Raspberry Pi on and off.
Push button functions :
Power LED State :
You will find on our github page the indications concerning the manual installation of the script on our forum:
INSTALLATION SCRIPT POWER SUPPLY PI SPC INSTALLATION
This module must be mounted on a chassis. If no chassis is available, use a heatsink sink to prevent circuit overheating.
This is particularly true whith higher voltage input (12V).
We recommend using such a dissipator (or equivalent in terms of heat dissipation). You can also mount a 4x5cm aluminum plate (7V) or 15x15cm (12V) to stabilize the system temperature.
The functions of this card are natively supported by the following software solutions: DietPi, Max2Play, piCorePlayer.
Be sure to put thermal paste between the tension regulator and the chassis for better heat dissipation.
Product type | Power Management / Power supply for Raspberry Pi |
Software | Supplied flashed with start and stop management |
Power supply | Via Jack DC 5.5/2.1mm or XH 2.54mm connector |
LED Output | Yes |
State LED on PCB | Yes |
Outputs | Up to 4 outputs on XH 2.54mm |
Supply voltage | 7V - 9V (Max 12V with good thermal dissipation) |
Fixation hole diameter | 2.5mm |
Dimensions | 50 x 35 x 20mm |
Average votes 4.4 / 5 7 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
M A.
M A.
Lorant V.
Hans-Peter S.
Christian S.
