The Ampapa A1 is a phono preamplifier specially designed for compatibility with MM cells, based on the use of two JAN5654 tubes for a warm, vintage sound, no less clear and precise. Added to this are 3 potentiometers for tone and volume control, allowing you to adapt the sound reproduction to your individual tastes. As an attractive touch, green or red LEDs illuminate the tubes and the perimeter of the unit. On the connectivity side, you'll find a phono input, as well as an RCA input and a 3.5mm headphone output in addition to the RCA output. The aesthetic uniqueness and versatility of this little phono preamplifier will delight many a music lover.
| 1 | Power ON-OFF |
| 2 | Input selector |
| 3 | LED selector (green / orange) |
| 4 | 3.5mm jack headphones output |
| 5 | Volume control |
| 6 | Treble control |
| 7 | Bass control |
| 8 | RCA phono input |
| 9 | RCA input |
| 10 | RCA output |
| 11 | 12V DC power supply via DC jack |
| Specifications | |
| Product type | Phono preamplifier Headphones amplifier |
| Tubes | JAN5654 |
| Headphones amplifier | 2x NE5532 |
| Inputs | 1x RCA Phono (MM) 1x Steroe RCA |
| Outputs | 1x Stereo RCA 1x 3.5mm jack headphones output |
| Input level | 0.005Vrms (Phono) 0.775Vrms (RCA) |
| Frequency response | 20Hz-20KHz (±0.5dB) (RCA) / Ref to RIAA +/-2dB (Phono) |
| Headphones output power | 125mW (32Ω) 62.5mW (64Ω) 30mW (128Ω) |
| Recommended headphones impedance | 16-300Ω |
| THD | ≤ 0.1% |
| Output level | 1.5V RMS (RCA) 0.6V RMS (Phono) |
| SNR | ≥ 106dB (RCA) ≥ 80dB(Phono) |
| Compatible replacement tubes | 6J1, 6K4, 6J5, GE5654W, 6*1N, 6*2N, 6J5, 6A2, etc. |
| General | |
| Power supply | DC 12V (≥1.5A) via jack DC |
| Weight | 384g |
| Dimensions | 153 x 92 x 25mm |
| Package | 1x Ampapa A1 2x Tubes 5654 1x RCA interconnect cable 1x Mains adapter |
