AUDIOPHONICS JC2-FET Preamplifier Volume Control Source Selection
This neatly designed preamplifier & source selector (4 inputs) has two separate circuits for each channel of the stereo signal. Each of these circuits operates in pure Class A and is powered by its own regulated linear power supply to provide extremely clean channel separation and maintain full signal precision.
4.6 / 5
By buying this product you get 41 loyalty points
Reference : 14774
419,00 €tax incl.
349,17 € tax excl.
Shipping date: 19-11-2026.
Preamplifier - Volume control - 4x input source selector - Class A double linear power supply
This neatly designed preamplifier & source selector (4 inputs) has two separate circuits for each channel of the stereo signal. Each of these circuits operates in pure Class A and is powered by its own regulated linear power supply to provide extremely clean channel separation and maintain full signal precision. Each of the channels is driven by JFET K170BL / J74BL.
The JC2-FET has an elaborate analog circuit with separate  pre-amplified channels fed separately with a combo of toroidal transformers. It offers volume control via a rotary potentiometer located on the front panel.
The device also offers a source selection function on its 4x stereo inputs (RCA connectors) mounted on its rear panel.
The source selection is made using a rotary selector located on the front panel.
The rear panel includes all input and output connectors to allow clean and tidy wiring. The analog output is available on a stereo RCA connector and will thus be able to work with most of your amplifier models.
There is also the power connector (IEC) designed for 220V voltages.
TypePreamplifier
Source selector
Inputs4x RCA stéréo
Outputs1x RCA stéréo
Frequency response20Hz-45kHz
Input sensitivity2V RMS
Output level9V RMS
Output impedance100 Ohm
Gain13dB
SNR103dB
Dimensions330 x 62x 308mm
Weight4.2kg
Power SupplyLinear regulated
AC220V (Power cable NOT included)
ColorSilver
ClassClass A / AB
10 reviews
du haut de gamme à petit prix
J’ai acheté le JC2-FET pour relier mes sources à mon amplificateur de puissance. Mes sources n’ayant pas de réglage de volume, il me fallait un préampli. L’insertion d’un préamplificateur actif me permet aussi d’augmenter le rapport signal sur bruit de mon système.
La finition est à la fois spartiate et soignée. Le boîtier en aluminium brossé est solide. La face avant a une épaisseur de 8 mm. Même les boutons de réglage de volume et de sélection d’entrée sont en aluminium. Les bornes d’entrée et de sortie sont plaquées or. Le JC2-FET est conçu et produit en Chine.
Les concepteurs du JC2-FET se sont inspirés par le JC-2 que John Curl a réalisé pour Mark Levinson. Le JC2-FET a un montage en double mono et fonctionne en classe A. Chaque canal est pourvu d’une alimentation régulée (15 VA) : cela est très important pour les électroniques qui doivent gérer des signaux électriques très faibles. Les transistors utilisés sont de type JFET (Toshiba) qui ont la réputation d’être particulièrement musicaux. Il n’y a pas de condensateurs d'entrée et de sortie. Bizarrement, les concepteurs paraissent avoir ajouté un étage de sortie offrant un courant important. Cela n’est pas très ‘courant’ sur un préampli, la première fonction d’un préampli étant d’augmenter la tension (c’est l’ampli de puissance qui ajoute un courant). Le JC2-FET a un niveau de sortie de max. 9 volt, ce qui est un peu la norme pour les préamplificateurs ayant des sorties non-symétriques. Cela suffit largement pour piloter n’importe quel amplificateur de puissance.
Rappelons que la qualité des électroniques en amont de l’amplificateur de puissance est de prime importance. Le préamplificateur permet d’augmenter le ratio signal sur bruit du système puisqu’il n’amplifie que le signal de la source (musique, parole …) et non pas le bruit résiduel, contrairement à l’amplificateur de puissance qui amplifie la totalité du signal, donc aussi le bruit. Un préampli puissant (tension de sortie suffisante) permet donc de réduire le gain de l’amplificateur de puissance pour éviter que ce dernier amplifie trop le bruit. Chaque imperfection en amont de l’ampli de puissance sera littéralement ‘amplifiée’ par ce dernier. Voilà pourquoi la qualité des électroniques en amont de l’ampli de puissance est un facteur plus décisif que la qualité de l’ampli de puissance même (cf. théorème de Friis). Signalons aussi que la séparation du préamplificateur de l’amplificateur de puissance fait que les deux étages disposent d’une alimentation spécifique adaptée à leurs besoins et qu’ils sont moins sujets à des interférences mutuelles.
Contrairement aux autres avis, j’ai trouvé que le JC2-FET ne nécessite pas de rodage intensif : il dévoile assez vite son potentiel.
Voulant éviter les commentaires dithyrambiques, je vais me limiter à dire que l’insertion du JC2-FET dans mon système ne mène à aucune dégradation sonore. Bien au contraire : j’ai l’impression que le son est un peu plus grand. Les concepteurs du JC2-FET ont réussi le tour de force de créer un préamplificateur abordable qui offre une grande musicalité et une transparence totale. Je m’attendais à de légères dégradations (comme une transparence et une scène sonore réduites), mais heureusement ce n’est pas le cas. Il est clair que le JC2-FET joue dans la cour des grands: au tarif proposé, cela est un peu déconcertant …
Certains regretteront l’absence de sorties et d’entrées symétriques et de télécommande. Je signale aussi que le JC2-FET est livré sans câble d’alimentation.
Conclusion : du haut de gamme à un prix abordable.
This review has been posted for AUDIOPHONICS JC2-FET Preamplifier Volume Control Source Selection 4x RCA
Expectations confirmed.
I.m founding this preamp excellent in order quality construction and sound. It's very close and somewhat superior respect to my EC1 pre Electrocompaniet.
Quality sound improves noticeably after at least 100 hour and more burn-in (in the beginning is not too great).
I'm gonna replace output solen caps with better Janzten z cap superior.
Item arrived quickly in a few days, thanks to Audiophonics.
I took about 100hour.
From the begining this preamp work and sounded well, but after approximately 100hour it was blooming. The sound widened, instruments found there right places on the recording. Paring it with audiophonics purifi, sparkos power amplifier.
Excellent
Je recherchais un préampli aux fonctionnalités simples (volume et sélecteur de source point barre), neutre, musical, de (très) bonne qualité de fabrication, à un prix très accessible pour driver un ampli DIY LFA-50 Optim-A dont je viens de faire l'acquisition. Ce préampli remplit parfaitement ce cahier des charges.
Ce préampli, preuve de sa neutralité, est très sensible aux câbles de modulation utilisés. en possédant plusieurs non utilisés, je me suis amusé à faire différents essais : les différences sont clairement audibles (couleur, définition, équilibre général, largeur et profondeur de la scène sonore).
J'ai donc fait le choix de lui associer des câbles de modulation et d'alimentation de qualité. En entrée du préampli j'utilise un câble argent de chez Audiocadabra (relié à un dac Gustard 20H) et en sortie du préampli un câble OYAIDE TUNAMI TERZO RR (vendu sur ce site). Pour l'alimentation, je n'ai pas hésité également à lui associé un câble FURUTECH The Empire E (également vendu sur ce site).
Les résultats à l'écoute dépassent largement mes attentes. Le rapport / qualité de ce préampli est imbattable. Il mérite des câbles de qualité.
Merci à Audiophonics pour la qualité des produits proposés et à l'efficacité et gentillesse de son équipe.
Excellent préampli solid state.
Ce JC2-FET semble remplacer l'ancien préampli Audiophonics solid state, noir, appelé JC2 par beaucoup et doté seulement de 3 entrées et qui a d'ailleurs récemment disparu du catalogue Audiophonics.
Et bien que dire du nouveau JC2-FET, de ce nouvel arrivé?
Il chauffe un peu, plus que l'ancien préampli noir, ce qui n'est pas un mauvais signe.
Tout d'abord, que les qualités du nouveau venu semblent bien supérieures à l'ancien, lequel en donnait déjà beaucoup pour 170€. Ici la différence de prix s'entend clairement. Plus de précision, de matière, de relief, les timbres sont d'une plus grande richesse, la transparence fait un bond étonnant. Mais cela ne serait rien si la musicalité, l'expressivité n'avait pas suivi cette progression. Et bien, elle est clairement plus évidente, les voix d'un opéra de Rameau, par exemple, nous interpellent, elles ne sont pas que de simples exercices stériles de style, leur humanité nous bouleverse tout simplement.
Ce préampli m'a conquis mais cela a pris du temps.
Tout d'abord, il réclame un rodage de plusieurs semaines, donc trés long, je préviens les pressés.
Ensuite, il est très sensible aux câbles de modulation, en amont j'ai mis un Van den Hul First qui lui va trés bien, en mettant en valeur la délicatesse du rendu sonore qui nous est offert, pour un prix assez démocratique.
Et puis il est trés sensible à l'ampli de puissance placé en aval: un Quad 606 est servi aux petits oignons avec ce JC2-FET alors qu'un Goldmund n'y fait pas des étincelles, mais cela ne m'étonne pas, Goldmund a toujours été un peu atypique.
Bref ce préampli offre une transparence assez incroyable mais il sert aussi vraiment la musique et ne fait absolument aucune chirurgie sonore.
Je cherchais un préampli solid state pouvant atteindre les qualités musicales d'un bon ampli à tubes et je crois bien avoir atteint mon but.
This neatly designed preamplifier & source selector (4 inputs) has two separate circuits for each channel of the stereo signal. Each of these...
