TINYSINE TSA1110 DIY Bluetooth Volume control module Android / iOS Compatible
15%
This TinySine TSA1110 module will allow you to control the volume of your audio system remotely directly via your smartphone via Bluetooth or by using the potentiometer on the back of the module.
Reduced price!
Reference : 13172
Limited time offer:
24,90 €tax incl.
-15%
21,17 €tax incl.
17,64 € tax excl.
Last items in stock !
Shipping date: 16-07-2025.
TINYSINE TSA1110
DIY Bluetooth Volume Control Module Android / iOS Compatible
TINYSINE Module Contrôleur de volume Bluetooth compatible Android / iOS
Caution to use this item, your amplifier must have capacitors on its input.
This TinySine TSA1110 module will allow you to control the volume of your audio system remotely directly via your smartphone via Bluetooth or by using the potentiometer on the back of the module. For remote control, Tinysine proposes a dedicated application allowing to act on the sound volume thanks to a digital potentiometer and this up to a distance of 30m. The internal potentiometer value will change automatically when you change the volume via the application. It is available under Android and iOS.
The TAS1110 is very simple to install. It has 3 ports at the rear: an audio input, an audio output and a 5V DC Jack power plug (not supplied).
Note : The TSA1110 is not a Bluetooth receiver. It simply allows remote volume control via this technology.
The TSA1110 also exists in a version with a box.
TinySine TSA1110 schéma de connexion
How to use the smartphone app ?
  1. Download and install the smartphone application. Android device users can download the.apk file and install it. For iOS users, the application is available in the AppStore by searching Lazybone Dimmer BLE".
  2. Open the application and activate Bluetooth on your phone.
  3. Go to the Bluetooth menu and click "Connect device". The phone will search for available Bluetooth devices. The "TSA1110" should then be displayed. Select it.
  4. You can now adjust the volume of your system directly from the screen of your smartphone by turning the knob displayed. The button at the top left activates the "Mute" mode.
Application Lazybone Dimmer BLE
Max bluetooth distance30m
Bluetooth standard4.0
CompatibilityAndroid V2.2 or more
iPhone 4S or more recent
Power supply12V DC via Jack DC 5.5/2.5mm (not included)
Dimensions96 x 41 x 20mm
InputJack 3.5mm
OutputJack 3.5mm
Channel2 (Stereo)
This TinySine TSA1110 module will allow you to control the volume of your audio system remotely directly via your smartphone via Bluetooth or by...
