Intégrité de la source réduction du jitter Utiliser sur deux parfums différents: SMSL(akm) et Audio-gd(wm8741) pour le casque. L'étage en terme de gain est tout...
Câbles remarquables. Branchés sur mon Drive CD Atoll 400 SE, les détails et la précision des timbres sont remarquables. Câbles étonnants, à brancher...
The Ext90 is a device to be associated exclusively with the Topping Pre90 and A90 Discrete, allowing these to enjoy more inputs. Thus, by combining the devices, you have two unbalanced RCA inputs and four balanced XLR inputs. Ideal for integrating an audio system with multiple sources.
Topping unveils its L30 II, evolution of the very good L30 headphone amplifier and preamplifier. This new version is based on the architecture of the first model, while bringing many improvements to optimize the performance of the device and its sound reproduction.
With the L70, Topping offers a highly engineered balanced NFCA headphone amplifier and preamplifier combo that delivers excellent sonic performance and is suitable for a wide range of use scenarios. Whether you are using demanding headphones, high sensitivity IEMs, or pairing with a power amplifier, the L70 is the ideal ally for pure, rich, dynamic...
Topping's Pre90 is a high-performance preamplifier based on a fully balanced circuit and high-performance NFCA modules. It also benefits from a high quality volume attenuator and easy control, thanks to its front panel display.
This unity gain buffer offers dual connectivity, both unbalanced with stereo RCA input and output and balanced with 3-pole XLR input and output. In addition, it also takes on the functions of a symmetrizer and desymmetrizer since it is possible to enter XLR to exit in RCA and vice versa.
Particularly versatile, xDuoo's MH-02 is a tube preamplifier, headphone amplifier and USB DAC in one. Its preamplifier stage is equipped with a pair of 6J1 tubes for a warm, musical sound. The device's Class A buffer uses transistors to deliver high power output and greater sonic precision and dynamics.
With its TA-66, Xduoo presents a headphone amplifier/preamplifier with tubes. The TA-66 features two tubes, a 6N2 tube for the preamplifier and a 6N5P tube for the buffer. These tubes amplify and process the signal, producing a final sound with smooth vocals and a round, colorful tone.
With the XD05 Pro, xDuoo unveils a high-performance, robust and versatile portable DAC / headphone amplifier. It features high-quality components such as an ESS ES9039SPRO DAC chip and two dual TI OPA1612A. The XD05 Pro's design allows these components to be replaced to provide a listening experience tailored to your preferences. Thanks to its Class A...
