NF ACOUS NH20 Headphones
The NF ACOUS NH20 is a closed-back dynamic headphone designed to deliver high-fidelity sound. It features a 40mm dynamic driver that delivers a wide frequency response. It is designed to provide optimal comfort thanks to its ear cushions made of cashmere microfiber and PU leather, as well as its adjustable headband, and to ensure long-lasting durability with its nylon carrying case.
Reference : 21747
199,00 €tax incl.
165,83 € tax excl.
NF ACOUS NH20 Closed-Back Dynamic Monitoring Headphones 40mm 50Ω 110dB 5-50kHz
Photo of the NF ACOUS NH20
NF ACOUS NH20: 40mm Speaker
The NH20 is equipped with a 40mm NF ACOUS MC2L-400 dynamic driver featuring a beryllium-coated polymer diaphragm that enables an ultra-high magnetic flux density exceeding 1.5 Tesla in the air gap. The zone damping system ensures an extended frequency response from 5Hz to 50 kHz, an ultra-wide dynamic range, and low distortion.
To optimize the low-frequency response (below 100Hz), adjustments were made to improve the perception of bass and harmonies.
Graph showing the frequency response curve of the NH20
Image showing the internal structure of the NH20 earpiece
Photo représentant les casque NH20 porté
NF ACOUS NH20: Comfort and Ergonomics
To enhance listening comfort, the NH20 features earcups designed to align with the ear thanks to a two-axis tilt mechanism, making it easier to position them parallel to the ear and delivering superior acoustic performance without compromising comfort. The earcup shells, made of cashmere microfiber and hydrolysis-resistant PU leather, are combined with high-density memory foam, providing excellent sound isolation and extended durability.
In addition, to accommodate different user setups, the headset features left and right ports for connecting the cable. Its specialized circuitry supports a standard 4-pole 3.5mm jack, ensuring optimal sound quality regardless of the connection method.
To ensure optimal protection for the helmet, it comes with a stylish and durable nylon storage case featuring a high-strength EVA-lined interior.
Product typeHeadphones
Headphone typeClosed dynamic
Frequency response5Hz-50kHz
Impedance50Ω
Sensitivity110dB
Headphone jacks2x 3.5mm single-ended Jack
Cable conductorOFC Copper
Cable length3m and 1.2m
THD< 1%
Dimensions265 x 290 x 80mm
Weight270g (without cable)
Package1x NF ACOUS NH20
1x Carrying case
1x 3.5mm to 6.35mm jack adapter
1x 1.2m cable
1x 3m cable
Lowest frequency (Hz)5
Highest frequency (Hz)50000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
NF ACOUS NH20 Closed-Back Dynamic Monitoring Headphones 40mm 50Ω 110dB 5Hz-50kHz
The NF ACOUS NH20 is a closed-back dynamic headphone designed to deliver high-fidelity sound. It features a 40mm dynamic driver that delivers a...
