ARYLIC BP50 Preamplifier DAC ES9023P Bluetooth 5.2 aptX HD aptX Adaptive 24bit 192kHz
Arylic proposes with its S50 Pro+ a connected stereo preamplifier, having the particularity to take advantage of a complete connectivity with WiFi and Bluetooth 5.0 reception. It also has a connectivity allowing an integration in the majority of the systems. It has stereo RCA and Toslink optical inputs and outputs. A USB-A (USB Host) and Ethernet RJ45 input are also available, as well as a subwoofer output, coaxial and a 12V trigger output.
4.3 / 5
Reference : 18385
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 02-04-2026.
Arylic BP50
Arylic BP50 Préamplificateur DAC ES9023P Bluetooth 5.2 aptX HD aptX Adaptive 24bit 192kHz
The Arylic BP50 is an extremely practical preamplifier with Bluetooth 5.2 functionality, capable of delivering superb sound quality. It incorporates a Sabre ESS9023P DAC and benefits from a meticulous design. What's more, it offers a particularly comprehensive range of connectors, in addition to its practical wireless connectivity.
ESS ES9023P DAC
The Arylic BP50 uses an ESS Sabre ES9023P DAC chip, supporting PCM audio streams up to 24bit 192kHz and offering a dynamic range of 112dB. Thanks to its high resolution and high dynamic range, the BP50 can reproduce all the details of your music and deliver enhanced sound performance.
Enhance your TV experience
The BP50 features an HDMI ARC input supporting CEC protocol. It supports PCM decoding up to 24bit 192kHz. It lets you enjoy a high-quality audio experience from your TV.
Wireless without compromising on sound
Thanks to the BP50's Qualcomm QCC3040 Bluetooth 5.2 chip, you can stream your music directly from your phone, tablet or computer to your audio system, wirelessly. This Bluetooth connection ensures low latency and a range of up to 15m. What's more, the BP50 supports the high-resolution transmission codecs aptX, aptX HD, aptX LL and aptX Adaptive for high-quality wireless sound reproduction.
Transmit to two headphones at the same time
Whether it's the sound of a movie playing on your TV, your music playing from a vinyl or CD player, or the sound of your computer, the BP50 lets you easily transmit these sources to two Bluetooth headphones at the same time.
An all-in-one preamplifier
The Arylic BP50 boasts a wealth of physical connectivity, in addition to its function as a Bluetooth transmitter and receiver. Inputs include HDMI ARC, phono input, stereo RCA, optical and USB. Outputs include USB-C (USB DAC), optical, coaxial and a subwoofer output.
Control app
Arylic provides a mobile application for simple remote control of the BP50, via a graphical interface. In addition to playback control, the app provides access to various parameters such as parametric equalizer, source selection, pairing and playlist management.
Personalize your sound experience
The ACPWorkbench tuning tool lets you customize your audio experience. With this tool, you can adjust frequency on each channel, adjust channel balance, customize deep EQ settings and more.
ACPWorkbench software sold separately. You can buy it on Arylic website.
Which wireless preamplifier is made for you?
Arylic BP50
Arylic B50
Arylic S50 Pro+
Wireless capability
Bluetooth 5.2 (SBC, AAC, aptX, aptX LL, aptX HD, aptX Adaptive)
Transmission and reception
WiFi, AirPlay, Bluetooth 5.2 (SBC, AAC, aptX, aptX HD, aptX Adaptive)
Analog inputs
RCA
Phono
RCA
Phono
RCA
Analog outputs
RCA
Subwoofer output
Subwoofer output
Speaker output
RCA
Subwoofer output
Digital inputs
Optical
HDMI ARC
USB-C
Optical
HDMI ARC
USB-C
Optical
Digital outputs
Coaxial
Optical
No
Coaxial
Optical
Trigger output
No
No
Yes
Multiroom
Non
No
Yes
Max sampling rates
16bit 48kHz
16bit 48kHz
16bit 44.1kHz
USB Playback
Yes
Yes
Yes
Control app
GO CONTROL
GO CONTROL
4STREAM
ACPWorkbench
Yes
Yes
Yes
Web control
No
No
Yes
Remote control
Yes
Yes
Yes
Control knob
Yes
Yes
No
Product typePreamplifier
DAC
Bluetooth receiver
DAC cipESS ES9023P
Bluetooth chipQCC3040
Bluetooth version5.2
InputsBluetooth 5.2
1x Stereo RCA line input
1* Phono RCA input (MM/MC)
1x Optical Toslink
1x HDMI ARC
1* USB-A (USB Host)
1* USB-C (USB DAC)
OutputsBluetooth 5.2
1x Stereo RCA line output
1x Coaxial
1x Optical Toslink
1x Subwoofer output (RCA)
Bluetooth range15m
Supported Bluetooth codecsTransmission: SBC, AAC, aptX, aptX LL, aptX HD, aptX Adaptive
Reception: SBC, AAC, aptX, aptX HD, aptX Adaptive
Frequency repsonse20Hz - 20kHz
THD+N0.05%
SNR> 95dB
Supported samplinbg ratesOptical input: PCM up to 24bit 192kHz
USB-C input: PCM up to 16bit 48kHz
Optical output: PCM up to 16bit 48kHz
Coaxial output: PCM up to 16bit 48kHz
HDMI CEC
USB HostSupported file systems: FAT16, FAT32, exFAT, up to  128Go
Supported formats: MP3, MP4, WMA, MOV, M4A, AAC, FLAC, APE
Subwoofer output levelMax 3Vrms
Subwoofer output cutoff frequency250Hz
Line out levelMax 2Vrms
Suply voltage12V 1A (power adapter included)
Dimensions185*155*50mm
Weight750g
Package1x Arylic BP50
1x Power adapter 12V 1A DC
2x Antenna (3dbi)
1x Remote control
InputPhono
InputHDMI ARC
OutputSubwoofer
OutputOptical Toslink
OutputCoaxial SPDIF
OutputBluetooth
DAC / ADC ChipES9023
Max sampling rate192kHz
ClassN/A
Remote ControlYes
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsSBC
Supported Bluetooth codecsAAC
3 reviews
Indispensable mais que 16 bits ?
bon sur le site du fabricant on vois 16 bits en sortie aussi https://www.arylic.com/products/bp50-bluetooth-preamplifier
et ? branché a l'optique de ma TV en entrée et au système 5.1 en sortie le son qui sort est plus riche que si je branche juste le système 5.1 a la TV
pour avoir écouter les même concerts deux fois avec et sans je n entends pas de compression du au 16 bits
testé sur le concert de Mika a Nimes
et une version Française de Carmina Burana
et un concert de Jean Michel Jarre en Espagne
et un concert de AC/DC
moi je suis fan de ce produit en plus l'app du téléphone est un peu plus rapide pour 100 euros j'en suis très content sur des forums beaucoup de personnes se plaignent que le bouton de commutation entre les différentes entrées casse ou ne fonctionne plus bon ben moi ce n est pas le cas vu que je n'y touche pas et que la télécommande fourni avec fait pareil
et surtout que je n'ais pas envie de me baisser au bas du meuble
le seul truc qui était pénible c'est l'appairage téléphoné boitier BP50 ou j'ai du batailler et installer des app pour forcer d autres langage Bluetooth
si je devais y voir 2 évolution c'est d avoir une entré et une sortie HDMI et de passer en 24 bits même si ce que j'entends est déjà meilleur que mon 5.1 de base
This review has been posted for ARYLIC BP50 Preamplifier DAC ES9023P Bluetooth 5.2 aptX HD aptX Adaptive 24bit 192kHz
Génial
Parfaite musicalité à tous points de vue. Ne démérite pas mê dans un système haut de gamme. Seul problème: l'appli ne reconnait pas mon
Surprenant
Connecte sur Chromecast audio pour alimenter mc intosh2205je préfère utiliser le dac du Chromecast plutôt que celui de arilic que je trouve agressif.
Arylic proposes with its S50 Pro+ a connected stereo preamplifier, having the particularity to take advantage of a complete connectivity with WiFi...
