Parfaite musicalité à tous points de vue. Ne démérite pas mê dans un système haut de gamme. Seul problème: l'appli ne reconnait pas mon
The Arylic BP50 is an extremely practical preamplifier with Bluetooth 5.2 functionality, capable of delivering superb sound quality. It incorporates a Sabre ESS9023P DAC and benefits from a meticulous design. What's more, it offers a particularly comprehensive range of connectors, in addition to its practical wireless connectivity.
The Arylic BP50 uses an ESS Sabre ES9023P DAC chip, supporting PCM audio streams up to 24bit 192kHz and offering a dynamic range of 112dB. Thanks to its high resolution and high dynamic range, the BP50 can reproduce all the details of your music and deliver enhanced sound performance.
The BP50 features an HDMI ARC input supporting CEC protocol. It supports PCM decoding up to 24bit 192kHz. It lets you enjoy a high-quality audio experience from your TV.
Thanks to the BP50's Qualcomm QCC3040 Bluetooth 5.2 chip, you can stream your music directly from your phone, tablet or computer to your audio system, wirelessly. This Bluetooth connection ensures low latency and a range of up to 15m. What's more, the BP50 supports the high-resolution transmission codecs aptX, aptX HD, aptX LL and aptX Adaptive for high-quality wireless sound reproduction.
Whether it's the sound of a movie playing on your TV, your music playing from a vinyl or CD player, or the sound of your computer, the BP50 lets you easily transmit these sources to two Bluetooth headphones at the same time.
The Arylic BP50 boasts a wealth of physical connectivity, in addition to its function as a Bluetooth transmitter and receiver. Inputs include HDMI ARC, phono input, stereo RCA, optical and USB. Outputs include USB-C (USB DAC), optical, coaxial and a subwoofer output.
Arylic provides a mobile application for simple remote control of the BP50, via a graphical interface. In addition to playback control, the app provides access to various parameters such as parametric equalizer, source selection, pairing and playlist management.
The ACPWorkbench tuning tool lets you customize your audio experience. With this tool, you can adjust frequency on each channel, adjust channel balance, customize deep EQ settings and more.
ACPWorkbench software sold separately. You can buy it on Arylic website.
Arylic BP50
Arylic B50
Arylic S50 Pro+
Wireless capability
Bluetooth 5.2 (SBC, AAC, aptX, aptX LL, aptX HD, aptX Adaptive)
Transmission and reception
WiFi, AirPlay, Bluetooth 5.2 (SBC, AAC, aptX, aptX HD, aptX Adaptive)
Analog inputs
RCA
Phono
RCA
Phono
RCA
Analog outputs
RCA
Subwoofer output
Subwoofer output
Speaker output
RCA
Subwoofer output
Digital inputs
Optical
HDMI ARC
USB-C
Optical
HDMI ARC
USB-C
Optical
Digital outputs
Coaxial
Optical
No
Coaxial
Optical
Trigger output
No
No
Yes
Multiroom
Non
No
Yes
Max sampling rates
16bit 48kHz
16bit 48kHz
16bit 44.1kHz
USB Playback
Yes
Yes
Yes
Control app
GO CONTROL
GO CONTROL
4STREAM
ACPWorkbench
Yes
Yes
Yes
Web control
No
No
Yes
Remote control
Yes
Yes
Yes
Control knob
Yes
Yes
No
Product type | Preamplifier DAC Bluetooth receiver |
DAC cip | ESS ES9023P |
Bluetooth chip | QCC3040 |
Bluetooth version | 5.2 |
Inputs | Bluetooth 5.2 1x Stereo RCA line input 1* Phono RCA input (MM/MC) 1x Optical Toslink 1x HDMI ARC 1* USB-A (USB Host) 1* USB-C (USB DAC) |
Outputs | Bluetooth 5.2 1x Stereo RCA line output 1x Coaxial 1x Optical Toslink 1x Subwoofer output (RCA) |
Bluetooth range | 15m |
Supported Bluetooth codecs | Transmission: SBC, AAC, aptX, aptX LL, aptX HD, aptX Adaptive Reception: SBC, AAC, aptX, aptX HD, aptX Adaptive |
Frequency repsonse | 20Hz - 20kHz |
THD+N | 0.05% |
SNR | > 95dB |
Supported samplinbg rates | Optical input: PCM up to 24bit 192kHz USB-C input: PCM up to 16bit 48kHz Optical output: PCM up to 16bit 48kHz Coaxial output: PCM up to 16bit 48kHz |
HDMI CEC | |
USB Host | Supported file systems: FAT16, FAT32, exFAT, up to 128Go Supported formats: MP3, MP4, WMA, MOV, M4A, AAC, FLAC, APE |
Subwoofer output level | Max 3Vrms |
Subwoofer output cutoff frequency | 250Hz |
Line out level | Max 2Vrms |
Suply voltage | 12V 1A (power adapter included) |
Dimensions | 185*155*50mm |
Weight | 750g |
Package | 1x Arylic BP50 1x Power adapter 12V 1A DC 2x Antenna (3dbi) 1x Remote control |
Input | RCA |
Input | Bluetooth |
Input | HDMI ARC |
Input | USB |
Input | Optical |
Input | Phono |
Output | Coaxial SPDIF |
Output | Bluetooth |
Output | RCA |
Output | Subwoofer |
Output | Optical Toslink |
DAC / ADC Chip | ES9023 |
Max sampling rate | 192kHz |
Color | Black |
Class | N/A |
Networking | No |
Remote Control | Yes |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
Supported Bluetooth codecs | aptX Adaptive |
Supported Bluetooth codecs | SBC |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX LL |
Average votes 4.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Sylvain d.
Richard C.
