AUDIOPHONICS AP310-PREAMP Balanced Preamplifier MUSES72320
Audiophonics is proud to present the AP310-PREAMP, a pure analogue balanced preamplifier. Combining comfortable power with a MUSES72320 volume control and full connectivity, this preamplifier is a sure bet for anyone wishing for a quality sound system.
By buying this product you get 34 loyalty points
Reference : 19540
349,00 €tax incl.
290,83 € tax excl.
Audiophonics AP310-PREAMP Balanced Preamplifier MUSES72320
AUDIOPHONICS AP310-PREAMP : 3/4 view
Audiophonics AP310-PREAMP : An exhaustive range of connectors
The AP310-PREAMP has a full range of connectors to integrate easily into your audio system and adapt to your needs. Its rear panel features a stereo 3-pin XLR input and four stereo RCA inputs, one of which bypasses the volume control. On the output side, you'll find two outputs, one stereo RCA and one 3-pin XLR, also on the rear panel.
AUDIOPHONICS AP310-PREAMP : Connectors
AUDIOPHONICS AP310-PREAMP : MUSES72320 chip
Audiophonics AP310-PREAMP : MUSES72320 volume control
The volume control built into the Audiophonics AP310-PREAMP features a high-quality MUSES72320 chip. This stereo electronic volume controller offers excellent performance with a very low level of noise and distortion, thanks in particular to its resistor ladder circuit.
Audiophonics AP310-PREAMP : Modern, sober design
The Audiophonics AP310-PREAMP is housed in an aluminium shell that perfectly protects its components. Optimum heat dissipation is ensured by a series of openings in the cover and rear panel, allowing air to circulate freely. The front of the AP310-PREAMP features a magnificent black acrylic panel, a modern and elegant aesthetic touch. Behind this panel is a beautiful OLED screen, which displays the volume level, the active input and the type of signal received by the device. It also lets you navigate the menus and access all the AP310-PREAMP's options.
Audiophonics AP310-PREAMP : Great practicality
The AP310-PREAMP is also designed to be as user-friendly as possible. It incorporates a trigger input and output, so you can integrate it into a complex sound system without having to switch it on independently of the rest. Furthermore, a remote control is included, allowing you to control your AP310-PREAMP entirely from a distance.
AUDIOPHONICS AP310-PREAMP : remote controle
Audiophonics AP310-PREAMP : Volume control bypass
Line input 4 bypasses the volume control stage completely. When this input is active, no compensation or attenuation is applied to the audio signal before it is sent to the amplifier. Therefore, the source used with line input 4 must have its own volume control.
This input has been designed to insert another preamplifier or source with its own volume into the system. For example, a home cinema amplifier or a network player.
The default Trigger IN selects this input. This makes it possible for another device to switch on and select this input automatically. But it is also possible to change the input that the trigger will control in the device options to suit your use.
Never use line input 4 without first connecting it to a source with a volume control. Otherwise, the fully amplified signal could damage your equipment.
Entrée Bypass
Audiophonics AP310-PREAMP : Connectors
AUDIOPHONICS AP310-PREAMP : numbered connection diagram
1Balanced XLR male stereo output
2Single-ended stereo female RCA output
3Stereo balanced XLR female input
4Single-ended female stereo RCA inputs
5RCA bypass input (max fixed volume)
6Trigger input
7Trigger output
8Power input
9Fuse
10Power switch
Product typePreamplifier
Inputs1x Balanced 3 pins stereo XLR
4x Single-ended stereos RCA
Outputs1x Balanced 3-pin stereo male XLR
1x Single-ended stereos RCA
Volume range-90dB - +12dB
Gain settingsAdjustable up to +6dB
OLED screenBrightness not adjustable, but switches off after 40 seconds
Input impedance10kΩ
Output impedanceSingle-ended : 100Ω
Balanced : 200Ω
Output levelSingle-ended : 9.5V RMS
Balanced : 19V RMS
Amplification chipLM4562
Output levelSingle-ended: 9.5Vrms
Balanced: 19Vrms
Impédance de sortieSingle-ended: 100 Ohms
Balanced: 200 Ohms
Power supply100-240V AC
Stanby power consumption0.1W
ColorNoir
Dimensions295 x 220 x 65mm
Weight1.560kg
HousingAll brushed aluminium / Black acrylic front
Package1x Audiophonics AP310-PREAMP
1x Remote control (batteries included)
1x Power cable
InputXLR
ClassN/A
Remote ControlYes
8 reviews
outstanding cost-performance!
Purchased together with the Audiophonics LPA-S450ET. Since the power amplifier has a balanced architecture, when used with older CD players or DACs that only have RCA outputs, an unbalanced-to-balanced conversion via electrical circuitry is necessary. In that regard, this device is essential for bringing out the full performance of the Purifi module and offers outstanding cost-performance.
The sound quality is warm, with the high frequencies extending naturally into the air range. The MUSES electronic volume control is also truly excellent!
However, for those who especially prefer a tight and direct sound, directly connecting a source device with built-in preamp functionality to the power amp via XLR may be more in line with their preferences.
This review has been posted for AUDIOPHONICS AP310-PREAMP Balanced Preamplifier MUSES72320
5 STARS PREAMP!!!!
Worth every cent!
Straightforward excellent pre-amplifier
Initially I bought this pre-amp for use with active speakers. Excellent at that. Shortly after that, I bought the accompanying Audiophonics Hypex nCore power amplifier. The combination has now replaced my integrated A/B class amplifier, costing only a fraction of the integrated amplifier. Wish I would have known earlier.
The pre-amplifier has a solid build, with equally solid RCA, XLR and power connections at the back. It's a simple layout, very well executed. The trigger option makes me happy and lazy at the same time.
The sound is, well, indistinguishable. Like there is no pre-amplifier in the signal chain. I really dig that.
If you're looking for a straightforward pre-amplifier or for the combination with a power amplifier, then do not hesitate. Very reasonably priced and very well executed. Listen to your ears, regardless of the price. Recommended!
Just great
I had been using a Schiit Saga 2 preamp before purchasing the Audiophonics AP310. The latter is in my opinion way better insofar as it is silent (no pops, no noise at all when turning it on/off), it has a 12v trigger that works fine and a stand by mode you can set from the remote. It also has an xlr input and no issues at all when symmetrizing a single ended incoming signal. Build quality looks really good and the price is lower that other preamps (e.g. the above mentioned shit costs approximately 400€).
Très musical et techniquement très performant
Au prix où il est proposé, ce AP310 est une véritable aubaine. Parfaitement silencieux, doté d’une bande passante stratosphérique et d’une dynamique sans faille, beaucoup de détails et de profondeurs s’expriment à travers une palette de timbres très enjoués. C’est un appareil à la fois très musical et très performant sur le plan technique ; Les entrées et sorties symétriques sont rares sur cette gamme de produits. Et que dire de la possibilité du réglage de gain, de la commande de volume numérique précise et sans aucun bruit parasite ? Je suis comblé. Seule ombre au tableau, étant possesseur d’un ampli casque, je regrette la cruelle absence d’une sortie fixe (rec-out) qui m’obligera à utiliser un doubleur RCA ou un câble adaptateur XLR-RCA en sortie pré-out, solution peu élégante...
Audiophonics is proud to present the AP310-PREAMP, a pure analogue balanced preamplifier. Combining comfortable power with a MUSES72320 volume...
