Passive preamplificateur with Volume Control & desymetrizer XLR RCA
This passive preamplifier offers both balanced and unbalanced connectivity, with desymmetrization function and extremely effective volume control, all integrated into a rugged yet unobtrusive housing.
This passive preamplifier offers dual connectivity, both unbalanced with stereo RCA input and output and balanced with 3-pole XLR input and output. In addition, it also takes the function of desymmetrization since it is possible to enter XLR for output in RCA. The following connections are therefore possible:
This device is not a controller, so it is not possible to use the RCA input to output in XLR.
This preamplifier also incorporates a highly efficient 256 position switched resistor volume control. This system allows a much more efficient sound power adjustment than a conventional potentiometer. It generates less noise and offers a more transparent sound. The attenuator is based on a series of 16 Takamisawa NA12W-K relays.
All components are integrated in a simple but robust housing, entirely made of brushed aluminium, with a silver front and the rest of the housing in black. On the front panel there is simply the volume knob offering a good grip and an LED indicating if the device is on (turning the volume knob to the right turns the device on).
At the rear are simply the RCA and XLR connectors with associated silkscreens to simply locate inputs and outputs. You will also find the power connector in IEC format as well as the presence of a fuse holder.
Device type | Passive preamplifier with volume control |
Volume control type | Relay attenuator |
Inputs | 1x RCA 1x XLR |
Outputs | 1x RCA 1x XLR |
Housing material | 100% Brushed Aluminium |
Power supply | 220V 50Hz via IEC (cable not included) - Fuse |
Dimensions | 165 x 190 x 75mm |
Weight | 1.8kg |
Colors | Silver and black |
