Unity Gain Buffer Symmetrizer / Desymmetrizer XLR RCA 2x AOP LM4562 2x LM317
This unity gain buffer offers dual connectivity, both unbalanced with stereo RCA input and output and balanced with 3-pole XLR input and output. In addition, it also takes on the functions of a symmetrizer and desymmetrizer since it is possible to enter XLR to exit in RCA and vice versa.
Reference : 13184
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 05-08-2025.
Buffer / Symmetrizer / Desymmetrizer
Buffer Fixe Désymétriseur XLR / RCA 2x AOP LM4562 2x LM317
This unity gain buffer offers dual connectivity, both unbalanced with stereo RCA input and output and balanced with 3-pole XLR input and output. In addition, it also takes on the functions of a symmetrizer and desymmetrizer since it is possible to enter XLR to exit in RCA and vice versa. The following connections are therefore possible:
  • Balanced XLR input to Balanced XLR output
  • Balanced XLR input to Single-Ended RCA output
  • Singled-Ended RCA input to Balanced XLR output
  • Single-Ended RCA input to Singled-Ended RCA output
Buffer AOP
Buffer
This buffer is composed of two PCB one for the power supply, and one dedicated to the buffer function and output stage. This last module integrates a TI AOP LM4562NA for each channel. They are ultra low distortion (THD+N : 0.00003%), low noise and high scanning speed operational amplifiers, specially designed for high fidelity audio applications. They also offer a good dynamic range and excellent electrical capabilities for excellent audio performance. Note that the sAOP are mounted on DIP8 and can therefore be easily replaced to adapt the playback to its listening.
Power supply & regulation
The power supply module is composed of a molded transformer mounted on PCB associated with two rectifier bridges 2A 100V, 2 electrolytic capacitors 3900µF 35V, 2 regulators TI LM317 and finally 2 adjustable resistors for a precise voltage adjustment. Voltage regulators provide overload and overheat protection to protect the unit. This provides the buffer module with a clean and adapted power supply.
Buffer alimentation et régulation
Housing & Connectic
All components are integrated in a sober but robust housing, made entirely of thick brushed aluminium, with a silver-coloured front and the rest of the chassis black.
At the rear of the unit is the complete balanced and unbalanced connection system: one RCA input and one RCA output, as well as one balanced XLR input and one 3-pin XLR output. The connectors are gold plated, as are the PCB circuits for optimum conductivity and good oxidation resistance.
Buffer connectique
Device typeUnity Gain Buffer
Symmetrizer
Desymmetrizer
Inputs1x Stereo RCA
1x 3 poles XLR
Outputs1x Stereo RCA
1x 3 poles XLR
Input impedance10Kohms
Output impedance600 ohms
AOP2x TI LM4562NA (mounted on DIP8 support)
Voltage regulator2x LM317
Power supplyAC 220V 50Hz via IEC (cable not included) - Fuse
Dimensions172 x 203 x 74mm
Weight1660g
InputXLR
ColorSilver
ClassN/A
2 reviews
Vraiment bon
Je viens de tester l'appareil au banc d'essais, j'utilise un analyseur de distorsion Hp333A qui date un peu mais qui reste fiable.
Le test porte sur la chaîne complète càd symétriseur, transport du signal via 50m de câble, désymétrisation et mesure. C'est très bon! Le niveau d'entrée max est de +18dbu, la sortie est à +24dbu, ce qui est normal car si le gain du désymétriseur est unitaire le fait de passer d'un signal symétrique vers asymétrique va augmenter le niveau de 6dbu (pour que ce ne soit pas le cas le gain de cet étage devrait être de 0.5). La distorsion est faible, limite de la mesure de mon analyseur, 0.015%, en réalité elle doit encore être bien en dessous. Le rapport signal bruit est plus grand que 100db et j'ai oublié de faire la bande passante mais ce n'est pas bien grave. En conclusion je dirais que l'appareil convient pour des applications professionnelles, vu le niveau qu'il accepte et les performances mesurées. Si vous êtes passionné de hifi il sera aussi du plus bel effet parmi les autres pièces de votre installation.
 (5)
This review has been posted for Unity Gain Buffer Symmetrizer / Desymmetrizer XLR RCA 2x AOP LM4562 2x LM317
Belle pièce
Magnifique boîtier en alu, un peu gros pour la fonction mais qui inspire confiance. Je l'utilise pour alimenter deux enceintes de monitoring actives Quested dont les entrées sont symétriques, le signal provenant de la sortie monitoring auxiliaire, asymétrique, de la console. Ce symétriseur remplace deux transfos dont les rapports de transformation n'étaient pas tout à fait adaptés. Le son est excellent, meilleur qu'avec les transfos. Je n'ai pas encore eu l'occasion de passer l'engin au banc d'essais mais je prévois que le test sera positif. L'appareil est un peu cher, j'en ai construit un du même genre dans un volume moitié, pour la moitié du prix, il est moins beau, pas moins bon, et c'est sans compter les heures de travail. L'appareil est utile pour les liaisons de grande longueur, si on veut bénéficier de la réjection du mode commun dans les liaisons symétriques. Si ce problème ne se pose pas, ça marche très bien en mettant le point froid à la masse, on peut faire des économies.
Un engin utile pour résoudre le" hum & buzz" dans les installations sérieuses. Autre bon point: sa réversibilité.
This unity gain buffer offers dual connectivity, both unbalanced with stereo RCA input and output and balanced with 3-pole XLR input and output. In...
