By buying this product you get 139 loyalty points
-61,00 € Viewed products
We offer you an Eversolo product pack consisting of the DAC-Z8, the AMP-F2 amplifier and a pair of Audiophonics Wire XLR interconnect cables for balanced connection. This high-end package is perfect for anyone wishing to benefit from a large power reserve and a system capable of supporting high-resolution streams. Coupled with passive speakers, this combination is capable of reproducing the best of your music.
EverSolo's DAC-Z8 is a high-end DAC that is extremely powerful. It embeds high-end components with notably an ESS ES9038Pro digital/analog conversion chip and a XMOS XU316 USB interface allowing it to support high-resolution audio streams and to provide a clear and detailed sound reproduction. The DAC-Z8 also offers a wide range of features that make it a versatile and efficient device.
View complete product page of EVERSOLO DAC-Z8
The EverSolo AMP-F2, developed in collaboration with the Starke Sound team, is a Class D amplifier based on the integration of the latter's innovative NS600 module. The result is a high power reserve of up to 2x250W RMS power at 4 Ohm (1% THD), great dynamics and extremely accurate sound. The all-new SAPS switch-mode power supply provides the audio circuit with a clean electrical signal, ensuring low noise and distortion. Bridgeable, the AMP-F2 is a versatile model that can be used in stereo or mono.
View complete product page of EverSolo AMP-F2
These balanced XLR modulation cables, assembled in our workshop in France, comprise a Mogami Neglex W2549 cable and Neutrik NC3FXX-B and NC3MXX-B XLR connectors. They feature OFC copper conductors and integral shielding, while the connector contacts are 24K gold-plated for enhanced resistance to corrosion and oxidation.
View complete product page of AUDIOPHONICS WIRE XLR 30 cm
| Specifications | |
| Products type | DAC + Power amplifier + Modulation cables |
| Package contents | 1x Eversolo DAC-Z8 1x EverSolo AMP-F2 1x Audiophonics Wire XLR 30cm (pair) |
| DAC-Z8 Specifications | |
| Product type | DAC |
| Inputs | Bluetooth 5.0 1* USB-B 1* USB-C 1* Optical Toslink 1* Coaxial |
| Outputs | 1* Balanced stereo XLR 1* Single-ended stereo RCA 1* Jack 6.35mm headphone output |
| DAC chip | ES9038Pro |
| USB interface | XMOS XU316 |
| OPA | 10* OPA1612 |
| Bluetooth receiver | Qualcomm QCC5125 |
| Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA Optical / Coaxial : PCM upto 24bit 192kHz, DSD DoP up to DSD64, MQA |
| Supported Bluetooth codecs | SBC AAC aptX aptX LL aptX HD LDAC |
| Screen | LCD 3" |
| Control app | |
| Recommended headphone impedance | 16-300Ω |
| XLR output performances | |
| Output level | 4.1Vrms @ 0dBFS |
| THD+N (A-Weighted) | 0.000062% @ 1kHz (-124dB @ 1kHz) |
| THD+N (No-Weighted) | 0.000069% @ 1kHz (-123dB @ 1kHz) |
| Noise (No-Weighted) | < 1.2µVrms |
| SNR (No-Weighted) | 133dB @ 1kHz |
| Frequency response | 20Hz-20kHz (±0.1dB) |
| Crosstalk | -130dB @ 1kHz |
| DNR (No-Weighted) | 133dB @ 1kHz |
| RCA output performances | |
| Output level | 2.3Vrms @ 0dBFS |
| THD+N (A-Weighted) | 0.000086% @ 1kHz (-121dB @ 1kHz) |
| THD+N (No-Weighted) | 0.000097% @ 1kHz (-120dB @ 1kHz) |
| Dynamic range (No-Weighted) | 133dB @ 1kHz |
| Headphone output performances (Low gain mode) | |
| Output level | 1.2Vrms @ 0dBFS |
| Output power | 45mW @ 32Ω |
| THD+N (A-Weighted) | 0.00015% @ 1kHz (-116dB @ 1kHz) |
| THD+N (No-Weighted) | 0.00018% @ 1kHz (-115dB @ 1kHz) |
| Noise (No-Weighted) | < 2µVrms |
| SNR (No-Weighted) | 124dB @ 1kHz |
| Dynamic range (No-Weighted) | 119dB @ 1kHz |
| Headphone output performances (High gain mode) | |
| Output level | 2.8Vrms @ 0dBFS |
| Output power | 26mW @ 300Ω |
| THD+N (A-Weighted) | 0.00016% @ 1kHz (-116dB @ 1kHz) |
| Dynamic range (No-Weighted) | 124dB @ 1kHz |
| General | |
| Supply voltage | 110~240VAC 50/60Hz |
| Consumption | 9W |
| Dimensions (L*P*H) | 270*187*50mm |
| Color | Black |
| Package | 1* EverSolo DAC-Z8 1* Remote control 1* Power cable 1* USB cable |
| AMP-F2 Specifications | |
| Product type | Amplifier |
| Amplification type | Class D |
| Output power | 2x250W RMS @ 4Ω (1% THD) 2x145W @ 8Ω (1% THD) |
| Output power (BTL) | 280W RMS @ 4Ω (1% THD) 450W RMS @ 2Ω (1% THD) |
| Inputs | Single-ended RCA Balanced XLR |
| Outputs | Speaker terminals (beryllium copper) |
| Gain | 21.5dB |
| Frequency response | 10Hz - 20kHz (-1dB) |
| Max. output current per channel | 16.5A 33A (BTL) |
| THD | 0.003% @ 10W, 1kHz |
| SNR | > 110dBA @ 4Ω, 260W |
| Input impedance | RCA : 11kΩ XLR : 22kΩ |
| Input sensitivity | 2.7V |
| Output impedance | 0.136Ω (5Hz à 100kHz) |
| Minimum load impedance | 0.8Ω |
| Damping factor | 100 |
| Balanced circuit | |
| Trigger 5-12V | Input and output |
| General | |
| Supply voltage | 115VAC - 230VAC (switchable) |
| Heat | 65BTU / hour |
| Consumption | Standby: ≤ 0.5W Idle: ≤ 14W Max: 900W |
| Dimensions | 270 x 228 x 80mm |
| Housing material | Aluminum |
| Weight | 3.65kg |
| Color | Black |
| Audiophonics Wire XLR Specifications | |
| Product type | Stereo XLR cables (pair) |
| Connectors | 2* Male XLR 2* Female XLR |
| Length | 30cm |
| Mogami Neglex W2549 cable characteristics | |
| Conductors material | OFC copper |
| Conductors section | 0.339mm² (22AWG) |
| Conductors diameter | Ø1.9mm |
| Insulation material | XLPE (cross-linked polyethylene) |
| Outer sheath | PVC |
| Neutrik connectors characteristics | |
| Contacts material | Copper alloy |
| Contacts plating | 24k gold |
| Shell material | Polyamide |
