By buying this product you get 379 loyalty points
We offer you a Shanling and Dan Clark Audio product pack consisting of the DAP M9 Plus and the Aeon 2 Black headphones. This pack is made up of two high-performance products in their respective fields. Shanling's DAP M9 Plus is at the cutting edge of technology, while the Aeon 2 Noir headphones are capable of enhancing the sound reproduction of any recording.
The long-awaited new version of the Shanling M9 player, the M9 PLUS, is finally here, bringing not only a modernized Android platform, but above all marking the return of AKM DACs! Thus, the M9 PLUS is the brand's first DAP to integrate the latest generation of AKM DACs, with four AK4499EX chips within a unique balanced architecture. The amplifier design has been adjusted for this Quad-DAC design, achieving higher power output.
For the rest, the M9 PLUS adopts the design implemented by Shanling for their digital music players. It therefore works with a Snapdragon 665 processor, an Android 10 system as well as with the Android Global Losless Output (AGLO) technology developed by the brand for optimal performance. In addition, the 8GB of RAM as well as 256GB of internal memory will allow you to enjoy your audio files via energy-hungry applications or high-quality files stored internally.
These high-fidelity AEON 2 CLOSED NOIRE closed-back headphones from Dan Clark Audio (formerly Mr. Speakers) are an updated version of the AEON 2. This version features a bold, metallic black paint job and perforated ear cushions for new sound reproduction. Overall, its settings are aligned with the "Harman curve" for enhanced bass and treble, and light midrange offering a wide soundstage. It features a "planar magnetic" diaphragm and True-Flow technology to improve airflow and bring out the details and texture of the sound. The AEON 2 CLOSED NOIRE features Hirose connectors and is supplied with a DUMMER cable featuring a 3.5mm jack termination and a 6.35mm jack adapter.
View complete product page of DAN CLARK AUDIO AEON 2 CLOSED NOIRETechnical characteristics
Products type | DAP + Headphones |
Package content | 1x Shanling M9 Plus 1x Dan Clark Audio Aeon 2 Closed Noire |
M9 PLUS SPECIFICATIONS | |
Product type | DIgital music player (DAP) |
Touch screen | 6" 2K 2160*1080px |
OS | Open Android 10 |
Inputs | Bluetooth 5.0 Internal storage 1* Micro SD Slot 1* USB-C (XMOS XU316) |
Outputs | Bluetooth 5.0 1* Balanced heaphone output Jack 4.4mm 1* Single-endedheaphone output Jack 3.5mm |
WiFi connectivity | WiFi 2.4G/5G |
Supported sample rates | PCM 32bit 768kHz DSD512 MQA 16X |
RAM | 8Go |
Internal storage | 256Go |
DAC | 4x AKM AK4499EX |
OPA | ADA45253 BUF364A OPA1612 |
Bluetooth version | 5.0 |
Supported bluetooth codecs | Transmission: LDAC / LHDC 5.0 / aptX HD / aptX / SBC Reception: SBC, LDAC |
PERFORMANCE UNBALANCED 3.5MM JACK OUTPUT | |
Power | 4.08V @ 32Ω (520mW) |
Frequency response | 20Hz - 40kHz (0.2dB) |
THD+N | 0.0008% |
Channel separation | 75dB @ 32Ω |
Dynamic range | 123dB |
SNR | 123dB |
Noise | > 115dB (< 1.7µV) (low gain) |
Output impedance | < 1Ω |
PERFORMANCE BALANCED 4.4MM JACK OUTPUT | |
Power | 6.0V @ 32Ω (1125mW) |
Frequency response | 20Hz - 40kHz (-0.2dB) |
THD+N | 0.0007% |
Channel separation | 115dB @ 32Ω |
Dynamic range | 126dB |
SNR | 126dB |
Noise | > 113dB (< 2.3µV) (low gain) |
Output power | < 1Ω |
Dimensions | 147*82*22mm |
Weight | 379g |
Color | Noir |
AEON 2 CLOSED NOIR SPECIFICATIONS | |
Product type | Headphones |
Headphones type | Closed circum-aural |
Speakers type | Planar magnetic |
Speaker dimensions | 62 x 34mm |
Headphone material | Aluminum, titanium and carbon fiber |
Earpads material | Japanese synthetic protein leather |
Sensitivity | 92dB |
Impedance | 13 Ohms |
Headphones connectors | Hirose |
Cable length | 2m |
Cable termination | 3.5mm |
THD | Less than 0.3% (@ 20Hz-20KHz) 0.1% (@ 100Hz-8KHz) |
Driver matching | +/-2dB to target curve, channel matched to 0.5dB (weighted 30Hz-8KHz) |
Color | Black |
Weight | 328g |
Package | 1x AEON 2 Closed Headphones Black 1x Hirose x2 to Jack 3.5mm termination cable 1x Adapter Jack 6.35mm |
