By buying this product you get 98 loyalty points
This Topping pack, composed of the PA7 Plus Class D amplifier, the E70 Velvet DAC and the TCX1 XLR cables, represents an excellent set, very efficient and coherent both from a technical and aesthetic point of view. It will allow you to have a complete audio system, powerful, efficient and capable of a precise and rich sound restitution, to which it will be enough to add speakers (sold separately) to enjoy your music in ideal conditions.
The Topping PA7 Plus is a powerful amplifier, based on a Class D architecture and benefiting from an intelligent and particularly careful design. It is thus capable of developing a significant power while maintaining a very low level of distortion. The technologies used ensure a clear, precise and deep sound reproduction. In addition, the balanced structure of the PA7 provides effective transmission noise reduction.
Key features:
With the E70 Velvet, Topping offers a new version of the excellent E70 DAC featuring the new AKM AK4499EX high-end DAC chip. For the rest, it takes the excellent technical base of its elder, combining a careful design and high-end components for exceptional sound performance with smart and practical features, such as Bluetooth, a 12V trigger or an adaptable output level.
Key features:
Topping's high quality TCX1 XLR cables feature 6N copper and silver-plated 6N copper conductors, ensuring perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable is covered with a beautiful and robust black and red braided nylon sheath.
Key features:
Topping PA7 Plus specifications | |
Product type | Amplifier |
Inputs | 1* Balanced XLR/Jack 6.35mm TRS combo 1* Single-ended stereo RCA |
Output | Speaker terminals |
Amplification type | Class D |
Dimensions | 200*155*41mm |
Color | Silver |
Topping E70 Velvet specifications | |
Product type | DAC |
Inputs | Bluetooth 5.1 1* USB-B 1* Coaxial 1* Optical Toslink |
Outputs | 1* Single-ended stereo RCA 1* Balanced stereo XLR |
DAC Chip | AKM AK449EX |
USB interface | XMOS XU316 |
Supported Bluetooth codecs | AAC, SBC, aptX, aptX LL, aptX HD, aptX Adaptive, LDAC |
Supported sample rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256 Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
Dimensions | 200*138*44mm |
Color | Silver |
Topping TCX1 specifications | |
Product type | Male/female XLR cables |
Length | 25cm |
Conductors material | 6N copper Silver plated 6N copper |
Conductors section | 0.533mm² (19AWG) |
Cable outer diameter | Ø8mm |
Connectors contacts plating | Gold |
Outer sheath | Braided nylon |
Cable colo | Black and red |
