TOPPING NX1 Ultra flat Headphone Amplifier 100mW 32 Ohm
Reference : 10173
44,90 €tax incl.
37,42 € tax excl.
Shipping from France
Billing in France
Technical support in France
This small nomad helmet amplifier NX1 stands out thanks to an ergonomics particularly well thought out and a sound signature very pleasant.
Warm and robust, it can drive a wide variety of headphones and in-ear with the greatest efficiency.
The NX1 comes with a mini USB to A USB cable, a 3.5mm Jack to 3.5mm stereo cable to connect to a DAP, Smartphone, etc. as well as 2 rubber bands and 5 pairs of adhesive velcros to connect it to your devices.
Characteristics :
  • Frequency response: 20Hz - 20kHz to +/- 0.2dB
  • Noise Ratio: 105dB
  • THD + N: 0.009% to 50mW under 32 Ohm
  • Output Power: 100mW at 32 Ohm
  • Supported Impedance: 16 - 300 Ohm
  • Input Sensitivity: 900mVrms (Gain Low), 300mVrms (Gain High)
  • Output voltage max. : 8.2Vpp
  • Noise level: <10μV
  • Gain: + 6dB (Low), + 15dB (High) to 1kHz
  • Input line 3.5mm jack
  • Mini USB port for charging
  • Headphones Jack 3.5mm
  • Lithium-Po Battery
  • Battery life: 100 hours
  • LED status indication
  • Volume control via ALPS potentiometer
  • Chassis Anodized Aluminum Black
  • Dimensions: 90x58x13.5mm
  • Weight: 93g
[Img-12230-left-thickbox_default]
[Img-12231-left-thickbox_default]
[Img-12232-left-thickbox_default]
[Img-12233-left-thickbox_default]
[Img-12234-left-thickbox_default]
[Img-12235-left-thickbox_default]
