Nicolas B.
une vraie montée en gamme par rapport au P4
Après avoir utilisé le Fosi Audio P4 pendant plusieurs mois, j’étais curieux de découvrir ce que le nouveau ZP3 avait à offrir....
Steve D.
Dayton spa300-D
Ampli mis en place dans mon caisson de basse fabriqué maison , fonctionne très bien.
Merci beaucoup livraison rapide .
Pavel M.
Genalex
I let the tubes burn in for about 100 hours and they work great for me, the bass is dense, the mids are brilliant, the treble...
VIABLUE NF-B Subwoofer LFE RCA Interconnect Cable 5m - reviews - There is 1 review.
SA R.
a solid choice
If you have an active subwoofer, the best thing you can do is to replace the stock interconnect cable. For bass, accurate and clean signal transmission is critical, as lower frequencies are reflected and multiplied within the room; therefore any defects, impurities or losses in the transmitted signal can easily result in uncontrolled and muffled sound, and the longer distance of cable that is common in this case, is not helping.
When I purchased my subwoofer (paradigm servo 15), almost immediately, I changed interconnect from stock, with a simple (lets say level 1 cable) upgrade (under half the price of this), with the additional shielding, I was really impressed and satisfied, so I did not prioritize this upgrade. I purchased this interconnect as simple level upgrade, without checking reviews and doing deep research, as I only anticipated small improvements from my already shielded cable; boy I was wrong, I cannot in the life of me believe the transformation - mostly because now the link with my speakers (bw 603s2) is even more fluid and the bass way more natural, as if coming from the main speakers, rather than the sub! (and the cable not even burned-in yet)! I think that the increased accuracy and control was indeed needed and the final result impressive.
I have no benchmark in the price range, nor knowledge from reviews to share any comparisons from my findings. All I can say is, that it works great for me and definitely I feel that it sounds the price (or higher) - as noted in the title I feel it is a solid choice for the price and that I believe you cannot go wrong by choosing this cable for your sub.
As it is with all hi-fi equipment and accessories, spending and return in listening experience is always the case, but it is almost never a proportional relationship. From my experience on this item, I recommend that, if you haven't already, revisit your subwoofer interconnect; and if in doubt, buy this cable, I don't believe that you will regret it.
