didier N.
ok
Benoit d.
Robert C.
It is difficult to...
Customers reviews - There are 19629 reviews.
Florent L.
Regulateurs Parfait pour reglage volume du preamplie
Parfait pour réglage du volume de mon pre amplie phono, gros soucis c'est que ça bourdonne très fort si on touche les régulateur mais si on laisse comme c'est, c'est parfait.
Mats L.
Amazing cable!
I was very curious about this cable since it got such good reviews.
Bought it to test against my current Furutech FS Alpha cable.
I'm shocked how good it sounds, absolutely amazing!!
My furutech FS Alpha sounds a little warmer BUT not nearly as high resolution as LUDIC SILENOS!
LUDIC SILENOS is much tighter in the bass and more accurate than my Furutech FS Alpha,
I also think that the midrange is clearer and much more open !
It sounds very neutral and high resolution with a large 3D soundstage, yes it has everything you could wish for!
will probably replace the internal wiring in my speakers in the future as it will surely make the sound even better.
GUSTARD N18 PRO Network Switch 5x RJ45 1x Optical Fiber Black The Gustard N18 PRO network switch features 5 RJ45 Ethernet ports as well as an SFP fiber optic connector and a BNC connector for external 10Mhz clock. The RJ45 Ethernet ports...
La suite
A mon avis EtherREGEN plus bonne alimentation+ bonne horloge supérieur mais plus cher aussi vu le Gustard
Horloge et signal
Bonjour j'ai aussi une horloge Gustard et un EtherREGEN et je préfère le signal sinusoïdale
Janez R.
Second one
I bought already the second one for same system. This amp is amazing. And it helped me identify and then improve other system imperfections. 'We are almost ''there.'' Many thanks to M. Sav. The on/off button light is slightly different as with first amp so if this is your second amp ask Audiophonics to send you an amp with matching one. Thank you Audiophonics!!!
Bruno V.
Gros câble aux multiples possiblités
J'ai acheté ce câble pour sa modularité. Je l'ai pris non monté pour pouvoir choisir le nombre de brin de cuivre OCC que je voulais et de cette manière l'adapter à mon système audio pour ne pas avoir un son où les basses ne seraient pas maitrisées. Contrat rempli !
Un son ample, des médiums présents mais non criard, des aigus détaillés et des basses qui ne bavent pas.
A titre d'exemple, la totalité des brin, chez moi, donne des basses trop présentes et non maitrisées. Avec un reclocker, 4 brin de cuivre et sans clock 3 brin de cuivre. Je sais que lorsque je changerai mon ampli, je pourrai changer la connexion du câble. C'est donc vraiment bien.
Jean-Louis G.
PSVANE 2A3-Z Power Tubes Triode (Matched Pair) PSVANE's 2A3-Z power tube offers a warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than...
Great tubes!
These are very high quality tubes. They’re in fact on the same level as the Psvane 300B Z, at a much lower price. If you don’t need a lot of watts, they’re great.
... pour un appareil qui fonctionne mal !
... car lorsque je l'ai mis en marche, le canal de sortie droit ne fonctionnait pas ! Dommage, car sinon, la qualité du produit est bien présente, sans coloration du son décelable...
Qu'à cela ne tienne, ce problème m'a permis de tester la qualité de service d'Audiophonics et, comme beaucoup d'autres, j'ai pu apprécier leur réactivité : ça n'a pas traîné du tout, dès le surlendemain du signalement de l'incident, j'ai récupéré un autre appareil... qui fonctionne très bien !
En conséquence de quoi je recommande et le sélecteur de source, et Audiophonics !
Tjalling B.
Best quality price RCA to date
Awesome plugs, soundwise, looks and pricing
From now on, I will only use these
Cannot be beaten for the price and they look gorgeous
OGUZHAN O.
Quality piece for price
I use it for mogami 3103, but it was too difficult for me to pas 4 mm section, 14 mm is perfect but 4 mm too tight. I had to use grease,soap, pull-push. use knittin needles to enlarge that section. Finally did it.
Pascal F.
Pas cool …
…De me gratter 10 cms sur les 25 metres. Un câble prévu d’1,5m sera réduit .
Pas hyper grave mais généralement les vendeurs comptent plus large pour assurer.
Laurent M.
GE JAN5725 / 6AS6W Tubes Pentode (Pair) The JAN5725 / 6AS6W / 6187 is a robust, compact pentode tube amplifier. It features 7-pin connectors and offers excellent performance.
Excellents petits tubes
Echange des 2 tubes d'un petit DOUK AUDIO ST01 PRO par ces GE JAN5725. Le gain en musicalité est assez significatif. Livraison rapide et bon emballage par Audiophonics comme toujours.
Frederic C.
Construction robuste
C'est le jour et la nuit. Rien à voir avec les connecteurs BNC à bas prix que l'on peut trouver un peu partout. Le cable RCA tient fermement une fois inseré. Dommage que les bouchons de charge 75 Ohm de la même marque ne soient pas disponibles sur le site.
Eric K.
ampli casque
excellent appareil; très belle sonorité; on peut aussi changer les OP AMP selon ses goûts; très bien !
Jean-Louis P.
J'ai commandé un transformateur sur mesure Il est 100% conforme en tensions et en dimensions, les enroulements sont bien repérés et les fils sortant du transfo sont suffisamment long.
Fabriqué en Chine bien entendu. Il y a un délai somme toute très raisonnable pour du "sur mesure".
Nos transformateurs sur mesure ne proviennent pas de Chine mais d'Europe.
Cyril L.
Compact
Ce modèle est très compact pour sa valeur et sa tension de 160V. Je reviendrais sur ces modèles pour mes prochains montages qui manqueront de place.
Cyril L.
JANTZEN AUDIO COMPACT MKT 001-8100 Axial MKT Capacitor 160V 10µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Compact
Pour les montages sérés, ce modèle est très compact pour sa valeur et sa tension de 160V. Je reviendrais sur ces modèles pour mes prochains montages.
Cyril L.
MUNDORF L071 Air Core Coil 0.71mm 2.7mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
Toujours parfait
Comme toujours simplicité et qualité de fabrication.
J'adore car il est très facile d'ajuster la valeur en enlevant quelque spires puis recoller le sparadrap qui maintient la bobine.
Cyril L.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 5.6µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Utilisation // sur les médiums en guise d'un nouveau filtrage pour une paire de 3A vintage.
Très correcte pour remplacer d'anciens condensateurs hifi
Cyril L.
Très bon rapport qualité prix, en utilisation série sur les tweeters en guise d'un nouveau filtrage pour une paire de 3A vintage.
Un gros gain sur le rendu plus doux comme j'aime.
Xavier R.
FIIO BTR3K Heaphone Amplifier Bluetooth 5.0 HD CSR8675 DAC 2xAK4377A The BTR3K is a portable bluetooth receiver with DAC circuit & balanced headphone amplifier. It works thanks to a Qualcomm CSR8675 24-bit Bluetooth 5.0 chip, which gives it all...
Very low output
I bought this in the hope to improve my listening experience when using mobile devices and to be able to use wired earphones with devices that have only bluetooth (and no more jack plug). The output is at best limited to low volume, which makes it unusable in any even slightly noisy environment like a train. Metro ? just forget about it.
Basically, I found this purchase just a loss of money.
Stephane I.
Remplacement AOP CONSTRUCTEUR
J'ai procédé à l'échange des condensateurs audio ELNA BLEU (remplacé par des PANASONIC FC 50V 4,7 uf ) sur le circuit du Aiyiama A07 MAX , j'ai changé l'AOP d'origine par celui-ci,la sonorité me convient mieux , il fonctionne encore mieux avec le LME 49860, pour ma part ,c'est musical ,aéré et pas fatiguant ,un excellent TPA 3255 accessible qui mérite du cablage et des composants de qualité , que du bonheur.
Stephane I.
AOP SUPPORT
Parfait pour changer les AOP facilement , sur certaines carte , l'accés est serré, moins on touche au pattes de ces composants, moins on les abime.
Stephane I.
cablage interne Aiyiama A07 MAX
Remplace avantageusement le cablage carte vers bornes HP de mon A07 MAX , son naturel et détails révélés , basse nette et propre.
Jose Luis A.
mmm preamp
I just received the preamplifier and at first glance it has some differences from the description.
The potentiometers are not 100K but are the B 50K by the Alpha brand (Taiwan).
At first I'm going to try it but I'm left wanting to try the one with the Alps RK27 potentiometer
arnaud f.
Vs xpads plus?
Semble très proche des xpads plus, un peu moins haut et pas de couche de liège en contact surface.
Je les ai mis sous mon ampli tubes de 38kg.
Perso pour enceintes, je suis plus convaincu à minima par les plus.
Sylvain L.
AUDIOPHONICS Trigger 5V 110V/230V Slave Power Supply Device This accessory, made in France in our workshops, makes it easy to add an automatic ignition (trigger) function to your devices that don't have this feature natively.
Aucune remarque négative, il réagit bien et se comporte comme décrit. Du bon boulot, merci Audiophonics !
Sylvain L.
Male Jack 3.5mm to Male Jack 3.5mm Mono Cable Gold Plated 1.8m This 1.8m long mono 3.5mm jack cable is gold plated, giving it both good conductivity and durability. It will be ideal to connect mono audio devices or triggers.
Tout bon
Bon câble, simple mais il fait ce qu'on lui demande. Que demander de plus ;) ?
Sylvain L.
ATOHM Adaptation Plate for S500 / S250 This adapter plate allows an S500 or S250 Atohm amplifier module to be installed in an existing cabinet with larger opening dimensions than these modules.
Cette platine fait le job, un peu chère pour un bout de métal, mais c'est bien usiné, propre et s'adapte parfaitement au S250 MKII.
Sylvain L.
ATOHM S250-MK2-X ICE POWER Class D Amplifier Module Subwoofer 220W 4Ω The Atohm S250-MK2-X Ice Power is a Class D amplifier module for subwoofers offering excellent technical performance and great musicality. It is capable of delivering a power of...
Utilisé en remplacement de l'ampli cramé de mon caisson de basse.
Acheté en parallèle avec sa platine d'adaptation disponible ici même sur Audiophonics, il s'avère bien complet avec ses réglages sur la platine arrière et sur le circuit imprimé (pouvant s'adapter à tout caisson de basses). La notice est claire et j'ai même demandé au support Atohm quelques conseils compte tenu des caractéristiques de mon caisson et ils sont réactifs et clairs dans leur réponse.
Au niveau du son, cet ampli Atohm est à l'aise au niveau puissance (si adapté à la taille de la salle bien sûr) et est très nuancé dans les graves, ça ne bave pas, c'est plutôt sec. Pour la musique il s'en sort bien également.
Pas déçu de mon achat ! Le caisson est reparti pour encore une décennie ;)
arnaud f.
Pas assez cher mon fils
Rapport qualité / apport / prix imbattable !
Sous des Martins Logan ESL9, le grave prend de la tension et de la profondeur, les détails jaillissent sur les autres fréquences.
À recommander sans modération !
Ihaja R.
Holy moly!
Wow!!! Upgraded from dual V6 vivid pro to these, holy moly! Almost night and day! More definition, more precision and more details!!! But a little bit more brillant too, may be they need more running-in.
Edouard d.
Ca défie les lois de la physique
Comment cela fait il que des fiches qui sont censées au mieux preserver le son, parviennent à la rendre la musique plus réaliste: Au point d'avoir parfois la sensation d'avoir les musiciens qui jouent dans mon living
Edouard d.
Belle sonorité harmonieuse
Comparé à d'autres prises montées, le son me semble plus riche.
Par contre, c'est dommage que la bague de serrage ne maintienne pas en place le cable dans la prise.
SMPS300RS Switching Power Supply Module 300W 36V The Connex SMPS300RS is a half-bridge resonant switched-mode power supply (SMPS) capable of delivering 300W continuous and up to 360W peak. It is configured for a 36V output...
Connex SMPS 300RE 36V
Cette alimentation est utilisée avec une amplificateur Fosi BT20A Pro en replacement de la 32V/5A d’origine.
Pas de différence notable à l’écoute, peut être un rendu poil plus douce dans le médium aigu.
Concerant le bruit de fond impossible de dire si elle fait mieux ou moins bien que celle d’origine, sur des pavillons midbass + compression de 105db/w, le souffle dans l’aigu est toujours présent même si plus lissé, le léger tiktiktiktik du hachage également, les deux étant donc définitivement imputables à l’ampli qui ne bat pas des records de rapport de recul de bruit de fond.
Cette alim ne mesure que 30mm de haut au lieu des 40mm annoncés, un boitier Galaxy 40 plutôt qu’un Galaxy 80 aurait pu suffire, au moins elle respire et reste totalement froide.
Olivier D.
SMSL DO100 PRO Balanced DAC 2xES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL DO100 PRO balanced DAC is an evolution of the DO100 offered by the brand. The DO100 PRO benefits from numerous improvements. It features two ES9039Q2M DAC chips and a...
Composants de choix et finition impeccable
La fiche produit parle d'elle-même avec des composants très qualitatifs. La finition du produit est irréprochable.
Je n'ai testé que l'entrée USB et les 2 sorties XLR, le DAC a été automatiquement reconnu par mon Mac. J'y ai raccordé une paire d'enceintes de monitoring ADAM Audio T8V.
Le son est très clair, avec de très nombreux détails dans les médiums et les aigües, c'est très rafraichissant.
Le bouton à l'avant sert de volume, ce qui n'était pas très clairement mentionné dans la description produit, et qui est hyper pratique sur mon bureau, sous mon écran. Cerise sur le gâteau, tous les réglages en cours (source, volume, etc...) sont sauvegardés même en cas de coupure électrique.
Seul bémol, mais à ce prix, on ne peut pas trop en demander, il n'y a pas de sortie casque.
Frank j.
pure battery voltage
using supercapacitor and ultra low mosfet
using it for my singxer su2
gives 5% better sound
and better most high-end power supply
Problème connecteur femelle
le connecteur femelle ne rentre pas suffisamment dans la prise du filtre secteur (DYNAVOX X acheté également chez Audiophonics) donc la liaison n'est pas franche.
par ailleurs l'inversion de phase (bizarre) me pose problème car de prise Schuko au mur donc je ne peux inverser.
Sinon Parfaite réaction du SAV qui a répondu très rapidement à ma demande de retour
Stanislav M.
LINDY CROMO LINE Digital Cable Coaxial SPDIF Copper Gold Plated 3m The Lindy Cromo Line SPDIF Coaxial cable benefits from a beautiful design quality. Its conductors are made of Copper for a very good conductivity and its connectors are plated...
Good build quality, excellent value!
Julien M.
Très beaux tubes
De très beaux tubes, soyeux, précis et naturels
Ils demandent effectivement beaucoup de temps pour s'ouvrir mais quel bonheur
Giannis K.
DAYTON BST -1
You must placed it firmly with a flat plate to feel all the frequencies. Also you have to isolate the sofa or your sim rig from the floor to have “louder feeling”
Peter R.
MUNDORF ACW115BK Wiring Cable Copper / Silver / Gold PTFE 1.8mm² This top-of-the-range Mundorf ACW115BK cabling wire offers excellent manufacturing quality for maximum conductivity. Its conductors are made of high-purity copper, silver and...
A great sounding wiring cable
I have implemented and tested a large number of jumper wires between my speakers and the SPEC real sound processors which I use. Different brands of silver and copper wires with different dimensions and designs by several brands have been tested, including all the various Neotech OCC-types available. The Mundorf ACW115BK wiring cable provides a large step forward regarding resolution, 3D dimesionality, organic presentation and low to high frequency response. This is the most musical jumper wire I have used for this purpose in my system. I am really impressed with the excellent resolution and silence offered by this Mundorf product.
Patrick D.
ATOHM WT-96123-G Isolated Built-in Terminal Block for Bi-Wiring Speakers Gold plated 123x96mm (Unit) The WT-96123-G terminal block, like all models offered by Atohm, is equipped with large terminals made of lead-free brass with 24k gold plating. It accepts cables with large...
Excellent, produit de qualité je recommande
Josef S.
Rapport qualité-prix TOP
Le déroulement de l'achat ainsi que l'envoi en Allemagne se sont déroulés sans problème.
Le sélecteur audio fonctionne très bien, on ne peut que le recommander.
Dommage que ce commutateur ne soit pas disponible sur le marché allemand.
Jean-Pierre D.
Transparent, détendu et superbement ouvert, à la fois bon en PCM et en DSD
Ce DAC excelle à tous les niveaux, la musique coule naturellement avec la vigueur nécessaire sur les temps forts des enregistrements. La spatialisation est excellente, beaucoup de largeur et de profondeur, les hautes fréquences sont sans dureté et bien étendues, belle restitution des timbres des instruments et voix. J’ai eu un Gustard R26, R2R comme ce Holo, c’est une progression en tous points, la musicalité est plus grande, cela me parait plus précis et hautement transparent, tout en conservant le caractère émotionnel. L’investissement vaut le coup, c’est un DAC qui s’insère parfaitement dans un ensemble haut de gamme, j’apprécie ses performances en termes de restitution sur tous les styles musicaux. J’utilise en coaxial pour la lecture de CD et en USB pour la musique dématérialisée jusqu’aux DSD, satisfait sur les différents formats.
Remerciements à Monsieur Aubert qui m’a permis de le sélectionner par rapport à d’autres options que j’envisageais. Je trouve que ce DAC a un excellent rapport prix qualité sonore vraiment bien, pour quelqu’un qui écoute tous les formats et souhaite écouter ses albums tant en format original que sur des fréquences plus élevées après suréchantillonnage jusqu’aux DSD.
yves R.
SIVGA ROBIN Dynamic Closed-Back Over-Ear Headphone Ø50mm 32Ω 105dB 20Hz-20kHz Rosewood Sivga offers with its Robin headphones a model that is both elegant and efficient, revealing a musical and dynamic sound reproduction within an ergonomic and modern design. The...
beau mais son catastrophique
beau casque
mais alors le son est mauvais
grave venant d'une mauvaise sono et aiguë qui fait saigner les oreilles
entre les 2 rien pas de medium.
je me suis fait avoir par les fameux testeurs influenceurs de YouTube .
passer votre chemin --
Antoine G.
L'affaire du siècle !
Ancien cablo-sceptique j'ai commençé mon éducation CS avec ce formidable câble.
Aujourd'hui j'ai des câbles plus chers, mieux "côtés", mais j'affirme haut et fort qu'il fait mieux que certains, que d'ailleurs je revends au fur et à mesure.
Bref c'est un mètre-étalon, et à ce prix il ne faut vraiment pas s'en priver.
testé sur des sources, sur des pré-amplis et des blocs de puissance, c'est bon partout !
Pour débuter, et même après pour continuer, c'est vraiment un produit terrible; Dynamique, ouvert, aéré, percutant, il à tout bon.
Merci Audiophonics, ne changez pas la recette svp !!!!!!!!!
Miguel O.
Après avoir fait jeu égal avec d'autres modèles valant plusieurs fois son prix, il a remplacé avec maestria, un câble USB haut-de-gamme, présent depuis des années, dans mon système...
Silence et propreté du signal font de lui un allié exceptionnel pour écouter la musique avec sérénité et plaisir !!!
Très hautement recommandable !
Frédéric B.
Du DMP-A6 au DMP-A8
Le DMP-A6 est un excellent produit et le DMP-A8 ...aussi... Est-ce que je regrette d'avoir vendu mon DMP-A6 pour acheter le A8?
En terme de qualité c'est dur à dire, le A8 est un peu plus "poli" un peu moins "dur" que le A6. Un peu plus équilibré aussi. Sans EQ, la réponse en fréquence est plus linéaire, il sort, me semble-t-il, un peu moins de grave. Mon avis reste subjectif car je n'ai pas eu les deux lecteurs en parallèle mais à quelques semaines d'écart.
En terme financier, entre la perte liée à la revente du DMP-A6 et le prix plus élevé du DMP-A8, cette dépense ne devrait pas être une priorité dans un système. Les plus de 1000 EUR de différence seront peut être mieux investis dans un changement d'enceintes. À vous de voir en fonction de votre système...
Les 5 étoiles ne se réfèrent pas cependant à Colissimo! Le colis est resté bloqué plus de 3 semaines au dédouanement! De nombreux emails avec Audiophonics ont été nécessaires pour débloquer la situation. Petit bémol pour Audiophonics tout de même car, aucun contact téléphonique n'a été possible et aucun dédommagement consenti. Audiophonics est resté cependant très actif par emails.
Le bon vieux "service à la clientèle" devient, en général, la possibilité d'intégré de l'IA dans l'entreprise plutôt que de gagner la satisfaction des ...humains.. qui restent des clients (ou l'inverse).
ABE
Sandy G.
TANG BAND W8-1772 Speaker Driver Full Range 30W 8Ω 95dB Ø22.38cm Tang Bang's W8-1772 full-range driver offers extensive sound reproduction thanks to its 22.38cm-diameter diaphragm. It has a power handling capacity of 30W, a paper diaphragm...
Très joli " TANG BAND"
Ce joli petit HP large bande donne envie de l'écouter, sur baffle plan pour le début. Après, je verrai : TQWT, Pavillon Arrière...voire Bass Reflex avec double résonnateur ?
belle finition en tous cas, et du plaisir avec ce Tang Band...
