O-NOORUS D3 PRO Amplifier
The O-Noorus D3 Pro is a powerful integrated amplifier based on numerous audiophile components. Its amplification stage features a TPA3255 chip and a PFFB structure with NJW1194 volume control, while its digital-to-analog conversion stage features an XMOS XU316 USB interface coupled with an AKM AK4493SEQ chip. The D3 Pro is therefore capable of supporting sampling rates up to PCM 32bit 768kHz and DSD512 while maintaining an SNR of 105dB and delivering up to 2x225 under 4 Ohms.
By buying this product you get 25 loyalty points
Reference : 21070
255,00 €tax incl.
212,50 € tax excl.
Shipping date: 19-11-2026.
O-Noorus D3 Pro Amplifier PFFB TPA3255 DAC AK4493SEQ HDMI ARC Bluetooth 5.4 2x225W 4 Ohm
Photo of the O-Noorus D3 Pro
The O-Noorus D3 Pro is a powerful integrated amplifier based on numerous audiophile components. Its amplification stage features a TPA3255 chip and a PFFB structure with NJW1194 volume control, while its digital-to-analog conversion stage features an XMOS XU316 USB interface coupled with an AKM AK4493SEQ chip. The D3 Pro is therefore capable of supporting sampling rates up to PCM 32bit 768kHz and DSD512 while maintaining an SNR of 105dB and delivering up to 2x225 under 4 Ohms. This small amplifier can therefore fill a large space with sound from a high-definition source, much to the delight of pure audio enthusiasts. Added to this is a QCC3084 Bluetooth chip for stable reception of aptX Lossless, LDAC, and LC3 codecs. In terms of connectivity, it is not to be underestimated, with two USB-C inputs (USB Audio and USB Host), an HDMI ARC input, two coaxial and optical Toslink SPDIF inputs, an RCA line input/output, and a subwoofer output to top it all off. The D3 therefore offers the possibility of setting up a 2.1-channel home theater system to enjoy your favorite movies in addition to its HiFi functionality.
The components of the O-Noorus D3 Pro
XMOS XU-316
XMOS XU-316
For high efficiency, low power consumption, and high signal processing capabilities.
AK4493SEQ
AK4493SEQ
Offers low-distortion signal processing with excellent dynamics and an SNR of up to 125dB.
NJW1194
NJW1194
Allows volume control while avoiding excessive distortion or noise.
TPA3255
TPA3255
Offers high power output up to 2x225W sous 4 ohms.
O-Noorus D3 Pro: Bluetooth 5.4
The D3 Pro features a QCC3084 Bluetooth receiver chip that supports high-definition codecs up to aptX Lossless, LDAC, and LC3 for reliable and stable wireless transmission. This allows you to enjoy high-resolution files via a streaming platform, for example.
Bluetooth 5.4 functionality of the O-Noorus D3 Pro
Home cinema function of the O-Noorus D3 Pro
O-Noorus D3 Pro: Home theater option
In terms of connectivity, an HDMI ARC input and a subwoofer output with low-pass filter (adjustable from 40-200Hz) allow the O-Noorus D3 Pro to set up a 2.1-channel system. This means you can enjoy powerful, immersive bass for both HiFi and home theater use.
O-Noorus D3 Pro: Multiplex RCA line input/output
The RCA line input is converted to an RCA line output when not in use thanks to the source sharing mode. This can be very useful for connecting another amplifier, for example.
O-NOORUS D3 PRO: multiplex RCA line input/output
The operating modes of the O-Noorus D3 Pro
  • D-F mode: The audio signal is output from the DAC without passing through the NJW1194 chip, and the volume cannot be adjusted. (Decoding mode)
  • D-B mode: The sound source is emitted by the DAC, passes through the NJW1194, and the volume is adjustable. (Decoding mode)
  • A-F mode: The audio signal is output from the DAC without passing through the NJW1194 chip, and the volume cannot be adjusted. (Amplifier mode)
  • A-B mode: The sound source is emitted by the DAC, passes through the NJW1194, and the volume is adjustable. (Amplifier mode)
O-Noorus D3 Pro overview
1RCA multiplex line input/output
2Subwoofer output
3Coaxial input
4USB-C Input (USB Audio)
5HDMI ARC input
6USB-C input (USB Host)
7Bluetooth antenna
8Toslink optical input
9Speaker terminal output
10Power supply via 24V-48V DC jack
O-Noorus D3 Pro review by Audio Science Review
This Class D integrated amplifier offers a lot of features. It's nice to see such competent implementations as those found in the D3 Pro. Compared to most of its competitors, it stands out with its comprehensive set of inputs and remote control. Its measured performance is very good for its class, but given its price, I would have liked to see better PFFB.
logo ASR
Technical characterisrics
Product typeIntegrated amplifier
Amplification chipTPA3255
USB interfaceXMOS XU-316
DAC chipAK4493SEQ
Volume control chipNJW1194
Bluetooth chipQCC3084
Inputs1x RCA line input/output
1x USB-C (USB Audio)
1x USB-C (USB Host)
1x HDMI ARC
1x Coaxial
1x Toslink optical
Bluetooth
OutputsSpeaker terminals
1x Subwoofer output
Supported sample ratesUSB: PCM up to 32bit 768 kHz, DSD up to DSD512
Coaxial and Toslink optical: PCM up to 24bit 192 kHz
Supported Bluetooth codecsSBC, AAC, aptX Lossless, LDAC, LC3
Output power2x225W @ 4 ohm
THD+N< 0.0028%
SNR≥ 92dB
SINAD91dB
Power supplyPower supply via DC 24V-48V jack (48V 5A power supply unit included)
Dimensions170 x 120 x 35mm
Weight0.550kg
Package1x O-Noorus D3 Pro Amplifier
1x USB-A to USB-C cable
1x USB-A to USB-C adapter
1x Remote control
1x Bluetooth antenna
1x 48V 5A Power adapter
O-Noorus D3 Pro measurements
InputHDMI ARC
OutputSubwoofer
OutputSpeaker terminal
Channel2 (Stereo)
Channel2.1
Amplifier chipTPA3255
Power (W)300.0
Remote ControlYes
O-NOORUS D3 PRO Amplifier PFFB TPA3255 DAC AK4493SEQ HDMI ARC Bluetooth 5.4 2x225W 4 Ohms
The O-Noorus D3 Pro is a powerful integrated amplifier based on numerous audiophile components. Its amplification stage features a TPA3255 chip and...
