Luca C.
Panos M.
Its more my personal taste
Ludovic P.
Customers reviews - There are 19585 reviews.
HENRI L.
Andoni G.
Good plugs
Good banana good looking and feeling for 5 mm cable
Andoni G.
Good for custom installation
A bit fat but it is good cable for custom interwall instalation for example a dedicated line
Jean-Jacques D.
Bien mais...
Bonne qualité, juste dommage que les vis de serrage du câble ne comportait pas d'empreinte pour y mettre un tourne vis ou clé six pans...
Ruben B.
Great clean neutral amplifer
It's a great clean amplifier, the quality that we know from NCore . The build is very well done, the case is sturdy, just like the connectors.
It has no trace, even very minimal, of the harshness that many class d amps have, it's just gain on a wire, very low distortion, and very high sound quality.
Only one remark, that led in the powerknob is way to bright for me, i'll try to mod that, but you should dim it and maybe make it something else than that annoying cold white colour. I prefer red or yellow myself.
The ordering and shipping went all flawless, and even in highseason (Christmas time) the delivery was fast and correct.
Payment was a bit a hassle, but that has more to do with my bank than with audiophonics, on their side no remarks.
Patrick M.
déçu
le corps en plastique est très fragile. Ces fiches ne supportent pas un cable rigide (du furutech en l'occurence !). Rapidement cassées...
Je déconseille !
OYAIDE TUNAMI GPXe V2 Power Cable Schuko IEC C15 102 SSC / OFC Copper Gold 24k Palladium Plated 1.8m This high quality Oyaide Tunami GPXe power cable is equipped with a Schuko and an IEC C15 connectors, with 24k gold and palladium plated contacts. The conductors of the cable...
Branché sur une barrette actinote grande musicalité très bons timbres ça ouvre
Tout cela sans être fatiguant au contraire on en redemande !
Bref a ne pas essayer sinon ...
Sylvain J.
Super ampli (utilisé depuis plus d'un an) que j’écoute en bypass et avec entrées xlr. Que des éloges (voir tous les avis). Le seul défaut que j'ai réussi à supprimer : des claquements aléatoires à l’allumage. J’ai résolu le problème en mettant des bouchons court-circuitant sur les entrées rca.
jean-françois v.
FIFO PI Q3 + Reclock PI Upgrade vers FIFO PI Q7 Excellent !!
Petit retour d'expérience sur ce nouveau Reclocker de chez Ian Canada. En effet, dans mes autres post sur le FiFO PI Q3 et de de son associé le Reclock PI dont j'ai été pendant de nombreux mois très satisfait (voir mes commentaires à ce sujet), J'ai décidé de tenter l'aventure avec ce nouveau Reclocker FIFO PI Q7. Et bien, je doit dire que je suis pas déçu !! Même si l'apport en qualité n'est pas aussi flagrant, il y a tout de même un gap significatif avec ce qui suit :
- Une amélioration de la scène sonore (plus de profondeur)
- Une dynamique plus grande
- Une plus grande justesse des timbres sur toute la plage audible
- Des fins de notes plus silencieuses
Attention cependant si vous avez des Horloges Accusilicon faire la modification sur les horloges en pliant la pin 1 pour que celles-ci ne soient pas Branchées sur leurs sockets sinon cela ne fonctionnera pas !!
Merci à Greg de Ian Canada et à l'équipe Audiophonics très réactif à ce sujet pour avoir trouvé l'origine de ce dysfonctionnement.
Seul petit bémol du FIFO PI Q7, j'ai toujours des plocs au changement de plages audio mais cependant moins fréquentes qu'avec le FIFO PI Q3.
Cordialement.
Jean-François.
Jean-François L.
Audiophonics-Phiree U2S
Pour écouter les WebRadios j'utilise un ordi, la télé (comme moniteur) et une chaîne HiFi.
Le télé me permet de lancer l'écoute; ensuite je la mets en veille, pendant l'écoute.
L'ordi ne dispose pas de sortie SPDIF.
J'ai acheté chez Audiophonics un extracteur HDMI vers SPDIF. Le son était bon mais des coupures de signal sur la télé et sur la sortie HDMI de l'ordi m'ont obligé à retourner l'extracteur. Je remercie Audiophonics de m'avoir permis ce retour.
J'ai ensuite acheté le convertisseur USB vers SPDIF Phiree U2S.
Il fonctionne parfaitement (on doit sélectionner la sortie son Phiree sur l'ordi), sans rien avoir à installer.
Le son me convient tout à fait.
Il convient de pondérer cette appréciation par le fait que la plupart des stations de radio diffusent en MP3 (je privilégie toutefois les diffusions en MP4 (aac)) et aussi que mes oreilles de 74 ans n'ont plus la finesse qu'elles ont pu avoir. Dans ces conditions, l'achat d'un appareil plus coûteux n'était pas justifié.
Pour les lecteurs intéressés, je précise que j'utilise le (bon) convertisseur N/A intégré à mon graveur de CD Marantz.
Les personnes ne disposant pas de convertisseur N/A trouveront ce qu'il leur faut chez Audiophonics.
En conclusion, je recommande Audiophonics pour sa gamme étendue de produits proposés et pour le bon contact qui m'a permis d'obtenir le produit qui me convient.
Merci.
JF
Philippe s.
SOMMERCABLE EPILOGUE Modulation Cable Male XLR to Female XLR 0.5m (Pair) This high quality XLR cable pair consists of a Sommercable Epilogue modulation cable and Neutrik connectors, specially designed for optimal signal transmission. The cable...
Grande qualité
C’est la deuxième paire que j’achète. Qualité au rendez-vous et prix très attractif. Merci à Audiophonics.
Philippe s.
Top !
Livraison hyper rapide même au moment des fêtes ! Super produit. Audiophonics est vraiment pro !
Philippe s.
Top !
Livraison hyper rapide même au moment des fêtes ! Audiophonics est vraiment pro !
Philippe s.
DIMOKRITOS D.
A true bargain
A remarkable speaker cable for the money. Exeded my expectations. It does have the sonic signature of the materials and the geometry used. It is fast, very clean and detailed, with exelent micro and macro dynamics, deep controled bass, lush midrange and very extended and clean highs. Beware though. It's not for the novice DIYer. It will demand serius skill and precision tools to terminate it correctly.
Gavrila S.
Excellent!
Works great! I installed it in a vintage Fisher 7000 power amplifier that has a only on/off switch. The delay provided by the device is around 3 seconds. Very fast shipping by Ups. Thank you! Keep up the good work!
Serge L.
HIDIZS MERMAID MS1 In-Ear Monitor IEM Dynamic Drivers 20Ω 112dB 20Hz-40kHz Hidizs proposes with its in-ear earphones MS1 a powerful model and proposed at a contained price. It uses dynamic transducers with a diaphragm specially designed by the brand...
Ecouteurs
Ecouteurs corrects, on sent bien les basses, aigus.
Christian O.
Recherche désespérément casque adapté
Il y a 3 ans j'ai posté un avis élogieux sur cet ampli casque.
A cette époque je l'utilisais avec un AKG K 702 et un Sennheiser HD 650.
Le problème est que le Little Dot MK3 a du mal à alimenter correctement ces deux casques. Sur certains morceaux le volume est souvent à 7 ou 8.
J'ai enfin trouvé le casque qui convient parfaitement à cet ampli casque. Il s'agit du Sennheiser HD 560S. Ce casque est fantastique. Son impédance est de 120 ohms et sa sensibilité est de 110 db.
Le son est neutre et très détaillé (voir analytique).
Les timbres sont superbes, la spatialisation est impressionnante.
C'est aussi un casque très dynamique.
Avec un réglage de gain à 5, le volume d'écoute est entre 3 et 5.
J'ai gardé l'AKG K702 et le HD 650, mais je n'écoute plus que le HD 560S.
Excellent produit !
J'ai essayé le couple Sparkos 3601-3602 puis le couple Staccato OSHS - OSH-DHb sur un ampli qui se compose de 4 simples AOP, et d'un Double. Eh bien, le top c'est ce SS2590, c'est incroyable de dynamique, de précision, les timbres sont parfaitement justes, c'est très équilibré, je ne vois vraiment pas comment ça pourrait être mieux. Et c'est instantané, pas attendu des heures de "rodage" pour donner mon avis, les modèles précédents sont totalement enterrés.
Excellent produit !
GUSTARD X18 DAC ES9038PRO XMOS I2S CPLD Accusilicon Bluetooth 5.0 32bit 768kHz DSD512 MQA Black Gustard offers with its X18 a versatile and extremely powerful DAC, capable of high quality digital/analog conversion for the most accurate and faithful sound reproduction.
Différence de prix justifiée
Possesseur du X16 qui a un problème sur la sélection de source en sortie XLR, j'ai voulu essayer le X18. Et le plaisir est au rendez-vous car on se rapproche encore de la vérité des sons et d'une scène sonore naturelle. Gain sur les basses, sur la précision des percutions et sur la spacialisation. La réception Bluetooth n'est pas très bonne mais c'est un crime de donner du bluetooth à une bête de cette qualité. Pleinement satisfait de mon achat et comme toujours d'Audiophonics dont le service est impeccable. Merci à l'équipe et meilleurs voeux.
Jean-Marie C.
Tout ce que je demandais !
Finitions impeccables pour cet appareil qui pèse bien lourd et aucune déstabilisation du signal à déclarer.
Photos un peu trompeuses : l'appareil est entièrement noir (on aurait pensé à un gris foncé d'après les visuels), mas la façade est bien couleur argent.
Bonus : commandé le jeudi 23 décembre, expédié le jour-même (bravo et merci Audiophonics !) et livré le lendemain. Royal !
Sebastien D.
Fais son job
Utilisé avec "USB payer pro" et fais bien son job, pour le prix je pense qu'il n'y ai pas mieux
André G.
cable Xlr Bon rapport prix/écoute
ce cable vendu 50 € est très bien réalisé et procure beaucoup d'informations et équilibré sans en rajouter. A recommander
PASCAL C.
Contrepointes conforme à mes attentes. Elles font classe, elles mettent bien en valeur mes enceintes
Georg K.
Exelent
Silky hot chocolate, micro detail in an huge arena.
It takes a few hours but wow so super smooth, rich in details death, width super sweet warm fast punchy bass that what I was searching for a long time. I use viborg xlr connectors
Highly recommend!
Nikolas H.
Excellent !!!!
Namil K.
review
The sound is clear and transparent. It's very cost-effective
Paul D.
Étonnant !
C'est mon premier amplificateur, donc forcément je n'ai pas une oreille extrêmement avertit mais j'ai étais réellement bluffé par ce petit ampli qui paraît minuscule a première vue mais qui surprend par la puissance et la qualité qu'il renferme !
Seul bémol la télécommande fournit avec l'ampli était H.S mais le SAV Audiophonics m'en a expédié une nouvelle le jour même que j'ai reçu très rapidement et qui est bien fonctionnelle donc merci beaucoup à la qualité de leur service !
Olivier P.
Très bonne liaison numérique 75 ohms entre Audiolab 6000cdt et hegel h190
Comparé à 2 autres câbles
C'est lui qui remporte le match. Il est neutre et évite de dépenser des fortunes.
Mention spéciale pour la fiche BNC qui verrouille idéalement le câble.
Vladimir S.
Buy and wait for ugly burn-in...you will be more than satisfied.
I mounted the cable to cheap plastic plugs (EU Power Plug 12 euros for 2) 2x1.5m
After 2 weeks of constant burn in I connected the 2 cables to 2 sbooster power supplies to my chord qutest and Auralic Aries
The sound is warmer with a good base foundation without losing resolution, more organic mid-range and the most important: !!! extremely musical and natural sound with a good size of the sound image.
I compared with transparent power cord 500 euros and up and I was not disappointed.
Frédérick M.
Gustard r26
Très bon produit beaucoup de détails une belle amélioration comparé à mon cxn v2 .et puis un grand merci a l équipe très professionnelle et très réactive de audiophonics.recu très rapidement
Grut S.
1MII B08S Amplifier 2.1 Class D Bluetooth 5.0 Receiver aptX HD QCC3034 2x50W / 4 Ohm The 1Mii B08s is a Bluetooth receiver with integrated amplifier that is both affordable and powerful. Incorporating a Qualcomm QCC3034 chip, it features Bluetooth 5.0 reception...
Petit ampli qui bouge très bien une paire de cabasse, bonne connexion et bonne puissance, le son est pas mal du tout...
Sorin P.
Quality for good price
Excellent build quality, works well, reasonable price. Thank you!
Alain C.
[GRADE S] HDMI 2.1 Cable 8K 60Hz 48Gbps HDR eARC ALLM Dolby 3m Refurbished product - Grade S This high performance HDMI 2.1 cable supports 8K 60Hz and 4K 120Hz video transmissions with a bandwidth of 48Gbps. Its conductors ensure an...
cable hdmi 2.1
Excellent cable 2.1 . La qualité de l'image est encore supérieur par apport à un cable 2.0. Très satisfait de mon achat
Alain C.
CABLE RJ 45 KAIBOER
Très bon cable rien à en redire
Bernardin A.
Top à condition d'être outillé.
Rien qu'au poids, vous sentez que ce n'est pas du cheap et les finitions sont nickel.
Pour chipoter, les visses de serrage en torx ou compatible étoile de petite taille, tout le monde n'a pas ça.
Personnellement, je recommande.
Bernardin A.
Presque top!
Beau produit, de qualité, pour chipoter une meilleure finition du bouton sélecteur, les arrêtes notamment.
J'ai testé 4 sources actives en même temps dont une phono, souvent problématique, et aucune interférence. En revanche, me concernant, un ploc dans les enceintes en cas de changement de sources actives.
Laurent P.
Acheté comme selecteur de sources , la fonction preampli est un plus avec les reglages basses /mediums/aigues et ou bypass .
Je trouve ce preampli très detaillé peut être un peu trop à mon goût avec mon ampli nc 250 ,enceintes magnat transpuls 1500 et ma source nvidia shield.
Je lui reproche un selecteur de sources et des potentiomètres sans graduations et 2 voyants rouge aveuglants.
Malgres cela , son prix vaut le détour et peu faire des heureux assurément!
Laurent P.
Très bon petit dac au look sympa avec un rendu precis sans être trop froid .
Il fonctionne aussi bien avec mon pc windows 10 et ma invidia shield .
" Pour les petits budgets qui veulent quand même de la qualité" c'est le bon choix !
Laurent P.
AUDIOPHONICS MPA-S250NC xlr
J'ai cet ampli depuis 2 ans maintenant et il me satisfait toujours autant !
Il fonctionne tous les jours de 15h à 22h30 et du matin jusqu au soir les week-ends.
Dès que vous changez de source, cela s'entend donc pour moi cet ampli est transparent .
Tres bonne dynamique avec de beaux medium et une spacialisation que j'apprecie !
Zero bruit de fonctionnement et de souffle dans mes enceintes de 95db (magnat transpuls 1500)
Si je devais changer aujourd'hui cela serai pour le nc 400 / 500 ou 600 pour etre sûr de ne rien perdre en voulant me faire plaisir et peut etre gagner encore ! la puissance apporte normalement plus de détails et de peps !
Merci audiophonics pour cette petite boîte qui embarque juste le principale pour faire de la musique.
Imre S.
Almost good..
Pretty good little amp, good sound. Treble and bass are good.
But it has its problems, unfortunately: When you turn it on, you hear a little electronic noise for a few seconds and then a soft crackling sound comes out of the speaker. Bluetooth connection is still fine, but there is some white noise.
Pascal F.
AUDIO-GD HE-1 MK2 Class-A Balanced Preamplifier ACSS XLR RCA Again Audio-GD strikes hard with its HE-1 MK2 of the series HE (evolution MASTER series) proposing a symmetrical Class A preamplifier of an exceptional quality. KEY POINTS:...
audioGD HE1 MK2
Une fois à température les transfo ronronne fort sinon très bon dans la reproduction des détails bon produit merci
Mickael c.
Utilisé en 5 et 6m sur des bw 801 alimentée par des mcintosh 601.tres bon, équilibré, dynamique et scène très correct. Je recommande
Jean-Claude P.
Mini mais costaud
Livré avec câble USB bas de gamme très court ... dans mon cas trop court ! commande d'un câble plus long chez Audiophonics et livré dans les temps.
La qualité est très étonnante pour un si petit DAC au prix raisonnable. Il prendra sa place dans une chaîne à plusieurs millier d'euros sans problème et si vous n'êtes pas satisfait du résultat vous devrez peut-être aller voir au niveau de votre ampli ou de vos enceintes ... mais là c'est une autre histoire ...
En conclusion: pas assez cher mon fils, pas assez cher...
Jean-Louis m.
Un bon ampli de Classe D
Je possède un D5pro et suis passé sur un AD-9 qui semble "marcher" tout aussi bien. Mes oreilles étant passé en Classe D je n'ai pas trouvé une grande différence. Pas de bruit de fond son bien spatialisé sur Mes colonnes triangle et mon sub-woofer Triangle.
A noter pas d'interrupteur physique, l'ampli se remet en On au retour du courant malgré l’Arrêt via la télécommande avant coupure de l'ensemble hifi (économies de veille oblige). Sinon RAS
VIBORG XM-202G Male XLR Connector 3 Poles Gold / Silver Plated Pure Copper Ø11mm Black (Unit) Viborg offers with its XM-202G a high-quality 3-pole XLR connector. Its contacts are indeed designed in pure Copper with triple plating Copper OFC, Silver and Gold, to ensure...
Bien aussi
J'avais déjà ces xlr en rodium et j'ai opté pour les 9r pour le câble AES/EBU. Je n'ai pas remarqué de grosse différence avec la version rodium. Montées sur un NEOTECH NEI-2001 ça marche d'enfer.
Bonnes prises
Ces xlr de Viborg sont de très bonne qualité, mâle et femelle. Montées sur un NEOTECH NEI-2001 le son est excellent, bien meilleur que du Qed au même prix.
Très bon câble monté sur des VIBORG XF-202R mâles et femelles pour du xlr. Le son est très propre, détaillé, transparent et avec de bons timbres. Le diamètre des fiches et du câble s'emboîte parfaitement sans avoir besoin de rajouter d'embout. Attention à la soudure, du flux de soudure est nécessaire. Je recommande.
Alexander D.
Kingsound M-03
I am really impressed with the power of the Kingsound M-03! Before I used the iFi IESL powered by the Topping LA90.
I am getting better results with the Kingsound M-03!
Thank you for the fast delivery!
