Zacharias L.
Very good but...
Pavol B.
Pavol B.
Moderate plugs
These RCA plugs looks good, quality made, aluminum body, good plast /no melting/, easy work with them. Pins and etc look...
Customers reviews - There are 19524 reviews.
john p.
Relaxed sound
This product lies outside the general rule “you get what you pay for”. As a standalone dac tested with optical ,coaxial, usb inputs sounds really good. I am not afraid to say it stands close to far more expensive R2R dacs I had the chance to listen to. My ongoing concern with digital has always been the listening fatigue ,this bombarding and exaggeration of microdetails that messes with your brain. This dac is a different story.
The RPI4 is a fantastic streamer transport and with the I2S connection to the dac sounds fantastic. Tidal HiFi in most cases sounds really good. (MQA is not my thing)
I have tested standard 16/44.1, higher sampling rates and DSD. My preference remains standard 16/44.1 and DSD through Volumio.
Being a vinyl fan from my early days and having accepted the pros and cons of this format I got lucky to run into this “desktop” sreamer-dac that gives me 4-6 hours of daily music listening without any fatigue. XLR output to a Luxman L550axII feeding a pair of heavily modified old Klipschorns and there you are !!!
A great combo from the Audiophonics guys!!
Rémi L.
HIFI 2000 GALAXY GX147 Aluminium Case 124 x 170 x 40mm 3mm Front Panel Silver This HIFI 2000 Galaxy GX147 all-aluminium case will allow you to create and dress your DIY creations. Strong, it will prove to be durable and will perfectly protect all the...
Fait le job mais jour de presque 1mm entre la façade avant et la façade supérieur/inférieur. Découpes des façades avant/arrière assez moyennes via cisaillement. Finition brossée sur ces façades - Beau rendu global mais il ne faut pas allé dans le détail.
Utilisé pour monter une alim SMPS 300RS 24V pour un petit ampli FDA.
TRES BON SUBSTITUT AU NE5532
En remplacement de deux NE5532 dans ampli classe D TPA 3255 de 3E audio alimenté en 44 volts. Le résultat est meilleur sur la majorité des critères. Grave bien maîtrisé sans traînage, aigu très raffiné et image stéréo plus profonde, excellente résolution également. Une option à prendre en considération aux cotés d'autres très bons AOP.
Christophe T.
FGG 2 Pins Connector for Focal Utopia Headphone This high quality connector has a specific format with 2 pins, adapted for the design of cables for Focal Utopia headphones. Its contacts are gold plated to ensure a very good...
Que du bon
Utilisé pour faire des câbles pour mon casque Focal Utopia. En effet, Focal sait fabriquer de très bon casques, mais n’est pas foutu de faire des câbles qui dure. Très bon connecteur. De la mécanique de précision. Les pins sont tous petits. Il faut un fer à souder avec une panne pointue, et avec la température réglable. J’ai soudé à 300°C. Je pense qu’une certaine expérience de la soudure à l’étain n’est pas de trop. J’ai utilisé le câble SOMMERCABLE ONYX 2025 MKII, que je trouve bien adapté à cet usage. Du coté de mon ampli AUDIO-GD R-28, j’ai mis une XLR mâle 4 broches NEUTRIK NC4MXX-B pour le câble symétrique, et un jack TRS 3,5mm avec filetage pour visser l’adaptateur jack 6,35, référence 10374, pour le câble asymétrique. Tous cela fonctionne très bien. La qualité et la solidité en plus.
Vincent M.
Très bon connecteur antenne coudé
ayant cassé mon connecteur de mon câble antenne audioquest forest, je l'ai remplacé par celui ci alors là bluffé par la qualité de fabrication et de la qualité de l'image de la TNT.
Le contraste a été amélioré sans changé de réglage de la TV :
le noir est plus profond
plus de perte de signal TNT
conclusion : que du plus
jean luc L.
https://www.audiophonics.fr/index.php?id_product=5071&controller=product
Andoni G.
VIABLUE UFO XL Vibration Absorbers Silver Ø65mm (Set x4) Viablue UFO XL absorbers can dampen harmful vibrations by placing themselves under your speakers or HiFi devices. Due to their optimal pressure on the lower surfaces of the...
Big and good building
I have eight of them
4 in the turntable
One in qutest
2 in both power supply's
And one in phono
Andoni G.
I had them in other cable
They have brute isolation be careful because they fit very very close, I had them with cardas audio cable and worked very good
Andoni G.
Good building
I use it for 2 device one is ifi zen phono and the other qutest dac.
I don't feel nothing special but is silent good building and you can turn on off the qutedt dac
I have a audiophonic current cable (very suspicious similar to audio agile lol) it cost 35 euro and have good isolation.
Thank for the advice
Frédéric A.
AUDIO-GD R2R-11 MK2 DAC Headphone Amplifier Amanero 32bit 384kHz DSD512 The Audio-GD R2R-11 MK2 is THE Swiss army knife for audiophiles. Combining the functions of DAC, preamplifier and headphone amplifier, it will meet most needs. It features a...
Phénoménal
Après presque 500h, le constat est simple: cet appareil peut tenir tête ou même humilier des appareils 4x plus chers. La scène sonore est large et profonde, le rendu est fouillé, les timbres sont justes et la dynamique, impressionnante. Le son est tout est en douceur et avec un naturel réjouissant, rien de forcé ou de fatigant. Tout le savoir fait de Kingwa (concepteur) est concentré dans cet appareil au rapport qualité-prix que l'on ne rencontre que très rarement. Un coup de maître, rien de moins.
Clément M.
Works as intented.
Excellent offering for the price. See my review and measurements there : https://www.audiosciencereview.com/forum/index.php?threads/phiree-u2s-2019-review-and-measurements-digital-usb-to-s-pdif-interface.29765/
Aurélien L.
Brancher sur mon amplificateur NuPrime IDA-8 sur une multi filtrée, j'arrive à entendre la différence dès les premières heures d'écoute dans tous les spectres du sons surtout dans les aigus.
Bon il va me rester que le câble RCA à changer dès qu'il y aura de la disponibilité sur les câbles Audiophonics.
Vous faites du super boulot. Merci.
Aurélien L.
IFI AUDIO IPURIFIER 3 EMI Filter Female USB-B 3.0 to Male USB-A In order to drastically reduce the noise of your system, iFi Audio offers you the iPurifier 3. This will reduce distortion effects and finally restore the details of your music.
Ben ca marche
Installer pour mon Ifi Audio micro iDSD Black Label, avec un cable Audiophonics Pulsar usb plaqué argent,j'ai entendu un réel changement au niveau du son. Surtout au niveau des aigus qui sont beaucoup plus douce, tout en étant plus détaillés.
Faire attention, les effets ne se font pas entendre tout de suite, il faut un certain rodage. Les premières heures ont été une souffrance pour mes oreilles.
Aurélien L.
Très bon coussinet
Changement de mes coussinets qui étaient mort après à peine 6 mois. C'est une honte pour Hifiman sur Sandara. La colle ne tient pas du tout, ils ont dû corriger le problème avec ce modèle coussinet.
J'ai essayé de faire jouer la garantie, mais Hifiman a refusé alors ce sera mon dernier casque Hifiman.
Jean Luc m.
Bonjour, restant sur ma faim du resultat d’une alim à découpage
Ifi audio très faible bruit je suis passé à cette alim linéaire.
Résultat, virez les alims à découpage,en terme de musicalité rien ne vaut une bonne alimentation linéaire.
L’alimentation linéaire Audiophonics apporte vraiment un plus à tous les niveaux, son plus doux dans les hauts médiums, plus de transparence, grave plus intense et mieux tenu..aigus plus fins et nuancés.très grande netteté des médiums.
Image stéréo vraiment en trois dimensions et excellente focalisation
des instruments dans l’espace.
Bref,que du bon.
Bravo à vous pour cette alimentation qui pour une somme modique apporte un vrai plus en terme de musicalité.
Pour conclure je me suis rendu sur le site de mon lecteur réseau
Sotm et il propose une alim sûrement très bonne mais à un prix
qui frise l’indécence , un peu plus de 600 €, plus chère que le lecteur.
TOPPING MX5 Amplifier Merus MA12070 Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Black The Topping MX5 is a combo amplifier and headphone amplifier with integrated DAC ESS ES9018. Particularly versatile and powerful, it benefits from a Bluetooth reception thanks...
Performant, complet et simple.
C'est un ampli que j'attendais avec impatience car il réunit tous les critères d'achat pour une utilisation simple et seul sans baisser la qualité de restitution ! Et topping est une valeur sure avec un bon firmware.
Je souhaitez un amplificateur qui intégre un bon dac , ici le xmos que j'aime bien (j'utilise aussi un alientek d8 et un topping dac d10).
C'est vraiment un bon choix pour un appareil complet avec plein d'entrées, un bluetooth de qualité.
La puissance est suffisante pour mes monitor audi bronze II. La restitution de la musique dématérialisée provenant d'un mini pc sous manjaro est très bonne.
Je l'ai utilisée une journée complète, il est légèrement tiède, sa coque est entièrement ajourée (attention aux liquides !).
L'ampli se mettra en veille seul au bout 1 minute d'arret du mini pc (veille du pc ou arret de la musique), c'était une condition d'achat, ce matin il s'est rallumé dès que le pc lui a renvoyé du signal (aucune manip à effectuer pour les néophytes vivant sous mon foyer).
On a le choix également à plusieurs niveaux d'affichage de l'écran et par défaut une exctinction de l'ecran au bout de 30".
il est plus cher que ces concurrents ou prédécesseurs (le mx3 que j'ai et qui sert plutot comme l'alientek d'ampli de bureau avec des mini biblio), mais ce n'est pas la même gamme.
Seul léger défaut c'est l'entrée en mode settings pas évident, se fait ampli éteint, on garde bouton rotatif appuyé et on allume par la télécommande. Un bouton menu n'aurait pas été du luxe, aussi ne pas perdre ou endommager la télécommande car pas de redondance sur l'appareil pour les fonctions et la veille.
Le bouton rotatif est de qualité, le choix est de bien sentir la rotation par clics (elle sert pour le volume et la sélection de source). J'aurai préféré un bouton plus épais.
Réglages basses aigus sans pop dans la musique, 2 préreglages sur la télécommande.
Un ampli discret , de bon design mais efficace. S'il est aussi robuste que mes autres topping il restera en place longtemps.
Gilles
Grégory O.
DAYTON AUDIO 3.5K-LPF-8 Speaker Low Pass Filter 3500Hz 12dB/Octave 8 Ohm Dayton Audio filters make it easy to limit the frequency response of a speaker to a desired frequency band. By using a combination of different Dayton Audio filters you can...
Filtre correct
Un filtre appréciable pour des hauts parleurs rigoureusement choisi.
Le commentaire Audiophonics (En utilisant une combinaison de différents filtres Dayton Audio) en vaut le détour.
Effectivement, la combinaison de plusieurs filtres de la marque peut être un choix de montage très correct si l'on veut éviter le plus que possible des réponses en fréquences en vrac, surtout lors de montage de filtres DIY. Les erreurs ne laissent pas insensible nos oreilles mélomanes...!!!
Globalement, un filtre correct, pour un montage à prix raisonnable.
Peut être qu'AudioPhonics ajoutera quelques références supplémentaires dans tout l'arsenal de filtres avec différentes gammes de fréquences déjà disponibles.
Emmanuel C.
TOPPING PA5 Balanced Class D Amplifier 2x125W 4 Ohm Black Topping offers with the PA5 a compact yet powerful and high performance balanced amplifier. It integrates a new generation of optimized Class D amplifier circuit capable of...
Une sonorité agréable et envoûtante sur tout le spectre.
Déjà, un tout grand merci à Audiophonics pour son sérieux. Ils ne sont pas avares de conseils et de suivi après-vente.
Pour me situer :
Tout d'abord, pour moi l'hifi, c'est une question de goût et chaque marque à souvent sa petite touche personnelle pour fidéliser le client. Moi, c'est plutôt le son des gros Technics des années 80 ou les NAD, qui me plait, parce que ça a du punch sans être agressif.
Je ne suis pas à mon premier Class D, mon ampli Class AB acheté d'occasion vient de me lâcher, donc je ré-inspecte le marché pour en acquérir un neuf et le PA5 faisant beaucoup de bruit sur la toile.
Mon impression toute subjective :
Le PA5 est une belle surprise, la définition et la netteté est surprenante, c'est vraiment une belle sonorité qui me fait penser à ce que fait Marantz. C'est propre sur tout le spectre, tout est bien délié, le piano ressort très bien dans les œuvres orchestrales, rien ne semble noyé. C'est un ampli qui parait avoir beaucoup de subtilité et de délicatesse. Pour ce qui est du relief musical, il est excellent, lorsque l'enregistrement le permet, on est bien immergé dans une large scène sonore.
Le grave est très bien maîtrisé également.
Ma seule déception est au niveau du punch, ce n'est pas le son des NAD ou des gros Technics. Mais ce « problème », je l'ai constaté sur tous les Class D que j'ai eu et entendu et surtout, il est à relativiser. Je crois que j'exagère avec ça.
Pour moi, un ampli doit être capable de me faire sursauter lors de brusques montées.
Celui-ci, moins (mais il le fait quand-même un peu).
Cela dit les attaques sont bien franches, question articulations ça passe très bien, tout ce qui est darbouka, djembé, bendir, … me remue avec beaucoup de détails.
Le grave est aussi surprenant, il est bien présent est ferme et ce, quel que soit le volume.
Le plus surprenant est son homogénéité, tout le spectre semble traité en toute impartialité, c'est vraiment très équilibré !
Pour la sonorité, en résumé :
Elle me fait réellement penser à ce que fait Marantz dans le plus haut de gamme : C'est équilibré, propre, net, doux (mais nerveux quand il le faut), détaillé, vif (mais sans excès). C'est assez loin du son du PA3, qui a ses qualités, mais souffre d'un manque de vivacité et autres petits détails
On peut dire que le son qui sort du PA5 est assurément très agréable, envoûtant même !
Question pratique :
Comme les entrées sont symétriques et mes éléments asymétriques, je pensais prendre un transformateur (boitier direct) mais la puissance est suffisante en asymétrique pour la taille de mon appartement et la sensibilité de mes hauts-parleurs. Dans le cas de haut-parleurs peu sensibles, symétriser le signal me paraît indispensable pour gagner du gain.
Sentiment de mon achat :
Même si j'ai eu une petite déception sur le punch (qui ne semble tenir qu'à ma perception), tout le reste n'est qu'enchantement et surtout, comme souvent chez Audiophonics, je n'ai pas dû étrangler mon portefeuille, à 350 €, je ne pouvais rien espérer d'exceptionnel sur le marché classique. Les premiers amplis qui me plaisaient commençaient autour des 500 € et plus. Ici, j'ai l'impression d'être avec un ampli que j'aurais dû payer plus de 800 €
Bref, sa réputation sur le Web n'est pas usurpée !
Luis V.
Amazing
I just received the Topping MX5 and i am truly amazed, the sound is very gorgeous and punchy and the tone control makes all the difference, it has driven my Hifiman Sundaras and the HE400se with authority and without problems, tried it with USB and with BT without any sound compromise whatsoever.
Akis P.
Believe the hype!
I bought this unit with guarded optimism based on the reviews, some actually saying that it provides a deeper soundstage than the D90, and sounding as good as units costing several times as much.
I wanted a DAC that not just sounded good, but has Bluetooth connectivity , can be used as a pre amplifier, and offers MQA and DSD. Not that Read more about review stating Believe the hype! , but I'd rather have it and not need it, - I didn't want to be limited to FLAC only if I should decide to try other codec formats.
I currently also own a Schiit Yggdrasil A2, RME ADI2 DAC FS, Burson Soloist 3X ,Cayin HA1AMK2 amp, Monolith THX AAA Desktop DAC/Amplifier, Topping D50& A50, Topping A90, XDUOO TA-20, and have owned a Sennheiser HDVD 800, Darkvoice 336SE with a ton of tubes.
Headphones include Sennheiser HD6XX and HD800S, Audeze LCD-XC and LCD-4, and others, and too many IEM's to list.
I haven't used the D70S as a pre amplifier yet, strictly as a DAC for USB FLAC only.
Quite frankly, I am stunned.
I didn't expect it to sound THAT good!
With the D50 and RME- I NEVER GOT LOST IN THE MUSIC.
I was always acutely aware of a digital glare, perhaps even overly analytical. I wasn't listening to the music. I was listening to digital playback of music.
As far as MY ears can tell- and I'm 56- so I probably don't hear as well as some of you younger people, this DAC stood tow to toe against the mighty Yggdrasil A2.
WT?
I've stated many times in other forums that I'm a HUGE fan of the Schiit Multibit sound, from the Bifrost and up.
Well, D70S made me a believer in Delta Sigma type DACs.
I can't believe that this day would ever come, where I would be endorsing a CHIFI device so enthusiastically.
Get it. It's gonna be all the DAC you could possibly appreciate, and for MOST people, will be the strongest link in the audio chain.
Massimo M.
Stereo Amplifier Class D TPA3251 2x140W 4 Ohm This affordable Class D amplifier is based on a TOPA3251D2 amplifier chip, ensuring a power of 2x140W under 4Ω and this with high efficiency. It will therefore have no...
NOT recommended
I cannot recommend this amp.
The case amp is very small, the output binding posts are ridiculously tiny and too close to each other.
The posts cannot be used with whatever "serious" cable or connector other than bananas.
I purchased it for testing purpose in an active system, but
I'm not able to judge the sound quality, cause the amp became dead silent at the very first use due to a supposed short on the output binding posts.
My fault, it's clear.
Phil D.
Fantastic device
I had a RaspDAC with Sabre Es9023 that I have upgraded to use this HAT. I also have a Denafrips Ares II DAC with Pi2AES streamer and using Topping pre90 and Perreaux 2150 power amp into B&W Matrix 804 speakers. I just spent the evening comparing the upgraded RaspDAC (with linear power supply) to the pi2Aes/Ares II. I was expecting the RaspDAC to come off 2nd by a long way, but iit was much closer than I thought. I would not have spent the money on the pi2AES/Ares II had I heard this DAC before. The pi2AES/Ares II is clearly better but this DAC comes close. Great detail and super smooth with no sibilant hardness. An absolute audio bargain!
Samuel P.
trés bon !!
Acheté pour m'essayer à la musique dématérialisée facilement avec un téléphone Xiaomi.
Vraiment surprenant en rapport avec son prix.
pour qui veux pas se prendre la tête et avoir du bon son, inutile de chercher plus loin.
Aussi bon qu'un lecteur CD de qualité
Un très bon RQP Audiophonics.
Christian C.
ROSE HIFI RS250 Lecteur Réseau Audio DAC ES9038Q2M 32bit 768kHz A true audiophile network player, the Rose Audio RS250 combines versatility with high performance, thanks to its high-end DAC and optimized power supply stage. A jewel of design...
Conviviale et performant
L'application propriétaire est ergonomique et sans
bug.
Le son est parfait.
Il mérite une optimisation
pour son support, la liaison eternet, hdmi etc.
Je ne parviens pas à utiliser
la télécommande Bluetooth.
J'aurais préféré une notice en français en pdf à la place de deux cordons secteur en plus inutiles.
Pour Audiophonics c'est plus que cinq étoiles.
Yohann A.
Très satisfait !
Je souhaitais améliorer l'utilisation de ma bibliothèque et j'ai découvert qu'à priori je pouvais aussi en améliorer le rendu sonore avec l'USBRIDGE pour un investissement relativement restreint. Je possède un Marrantz SR7012 qui me sert aussi pour la HIFI. Et bien oui ! Le avant / après (avec alimentation de base pour le moment) est bluffant. Meilleure présence des voix, plus grande spatialisation, meilleur contrôle des basses. Livraison rapide, conseil du service technique ! Merci Audiophonics.
remy p.
Très équilibrés !
De très loin les meilleurs fiches banane que j'ai eu ou essayé !
Sur mon système la difference à été flagrante : j'avais un léger creux de 0.5db sur la bande de 1 a 6Khz ( mesuré avec Rew et Dirac Live ) que je mettais sur le dos de la pièce et que j'aurais sans doute modifié en changeant une resistance sur mes filtres d'enceintes , jusqu'à présent j'utilisais un mini dsp SHD pour corriger le creux , c'est simple quand j'ai changé les fiches bananes je suis dis mince j'ai laissé le filtre acoustique allumé , comme il n'était pas activé j'ai redémarré le mini dsp en me disant qu'il avait du planté avec le filtre sur on , et bien non !!
J utilise un cable enceinte de 5.5mm² 1000 brins cuivre plaqué argent d'une marque allemande qui n'existe plus et ces fiches sont un exemple d'équilibre sur tout le spectre et surtout de transparence !! rien n'est mis en avant ou en arrière tout est d'un équilibre d'une subtilité d'une justesse et d'une intimité parfaitement dosé ( en tout cas sur mon système )
Pour information: j'utilise le câble nu sur mes bornier d'enceinte et j'utilise ces fiches sur les borniers de mon ampli qui ne sont pas percés et qui remplacent de précédentes fiches plaqués or.
Mon système : Ampli Kinki Studio Exm1+ ( mon plus gros coup de coeur de ces 4 dernières années ) dac Gustard X26Pro ( deuxième coup de coeur ) câble de modulation Plénitude Audio Signature ( un chef d œuvre de transparence ) enceintes 4 voies sur une base d Atlas MKV avec un filtre maison 1/3 Jantzen 2/3 Mundorf fabriqué par un ami passioné
Ces fiches complètent à merveille le dernier chainon manquant d'un ensemble que j'ai mis 4 ans à peaufiner pour enfin avoir le son que j'attendais.
Claude G.
l'excellence
Avant de poster un avis, je souhaitais le tester avec différents DACS.
J'ai commencé avec un Sanskrit MKII puis un SABAJ D20 et enfin un Gustard X18 que je viens d'acquérir.
Avec ce dernier, connecté en I2S à partir d'un module AUDIOPHONICS DIGIPI+I2S sur PI4 et câblé en XLR, c'est tout simplement l'excellence.
Merci à AUDIOPHONICS pour la qualité de ses réalisations et la réactivité et le professionnalisme de ses correspondants.
Nicolas M.
Faible qualité
L'initiative de proposer des transfo sur mesure est bonne mais la qualité de fabrication de ceux-ci est vraiment très basse (Europe de l'est voir Chine). Les enroulements ne sont pas forcément bien empilés (fait à la main?). L'isolant est de très mauvaise qualité et les tours ne se chevauche pas suffisamment. Le support SF01 est absent, à la place de celui-ci un résinage bleu au centre du torique. Celui-ci dispose d'un perçage de 5mm non centré, et insuffisant en diamètre au vu du poids! L'application n'est pas très exigeante (amplificateur classe D), il doit-être plus difficile de mettre un tel transformateur en œuvre pour de l'analogique (couplage, ronflette, etc). Il est loin d'une qualité audio. Je ne parle pas du délais de livraison de 2 mois et demis (repoussé 2 fois).
Nicola G.
Good but could be better
I bought this DAC and a Linear Power Supply, initially I had some trouble with the power supply but now it works well. I had to pay the assistance, Audiophonics team said that everything was ok, but I sent a non-working things and received back a working one... But all's well that ends well, as the old boot said.
The main problem is that the Pi isn't shutdown well.
I bought this to substitute a Cocktail Audio, looking for a better sound.
The usability feature on the cocktail audio are better, the touchscreen and the interface are very well made. I hoped that this could be like the Cambridge Audio but the only way to use Raspberry with Volumio is through another interface.
The remote control and the knob aren't useless to navigate inside the library.
The sound of the DAC is good, better than Cocktail Audio.
The unclean poweroff of the Pi is the biggest minus.
I didn't understand if there is one or more pin of Raspberry GPIO available for custom usage.
Raphaël M.
ELECAUDIO ADIACIUM GR Extensible PET braided sleeve Nylon 4-11mm Braided sleeve made in  PET (Polyethylene Terephthalate)  mono-strands which can be used in a wide variety of applications. Thanks to its expansibility, the unique PET...
Durabilité, qualité, simplicité.
Bientôt 5 ans que cette gaine protège mes câble d'alimentation pour un amplificateur dans ma voiture, ainsi que mes câbles HP et RCA (dans dans dimensions plus resserrées)
La gaine est simple à mettre en place autour du câble, c'est même très satisfaisant à faire !
Ensuite je doit dire que la longévité sans faille ne me surprend pas vu la qualité perçue lors de la mise en œuvre, mais force est de constater qu'après 5 ans aucun signe de faiblesse. Les parties dont j'ai un accès visuel n'ont pas changé d'aspect notamment sous le capot moteur près de la batterie qui est un environnement plutôt engageant, la gaine traverse le temps sans aucun problème.
J'en suis évidement hyper content.
Merci Audiophonics de proposer du matériel d'une aussi belle qualité.
Alan D.
Super satisfied!
This is the first DAC I have ever purchased for a Pi, so I didn't know what to expect. I am totally impressed with this little jewel! I have paired it with a Raspberry Pi 3B+, an ELV 38W amp and a pair of Focal LS RSE-130 speakers and installed all of this in a custom made wood enclosure. The sound has beaten absolutely all of my expectations for such a price point. I am particularly impressed with the clarity and stage/depth of the music. I highly, highly recommend it!
Valentin R.
Toogle Switch with Red Light ON-OFF 250V 3A Ø 21mm Black This is an ON / OFF toggle switch 250V 3A. Connection via 4.5 mm flat connector. Black case with I/O label.
Attention la temperature
ça bloque en position on sur un ampli de classe A qui chauffe bien le switch, donc un changement
Vous devez certainement lui faire passer plus des 3A pour lesquels il a été conçu.
Très bien sur pc portable
Venant d'acquérir un pc portable,j'utilise foobar règle sur Wasapi:c'est juste parfait...vraiment étonnant ce petit dac
Hasni Z.
Très bon produit et livraison ultra rapide!
Merci à l’équipe d’Audiophonics :)
Hasni Z.
Très bonne qualité de fabrication pour isoler un câble DYI
Un immense mini DAC à prix doux
La qualité sonore est vraiment bluffante (parfaite?), les sorties symétriques (4V) apportent aussi un vrai gain en qualité sonore car elle permettent de faire fonctionner l'amplificateur dans sa zone de confort.
Le D10B fonctionne aussi très bien alimenté en USB avec un RI4 et il s'arrête et s'éteind avec le Raspberry ce qui est un petit confort appréciable.
En revanche les adaptateurs XLR/jack 6.35 sont juste monstrueux, il pèsent plus lourd que le DAC ! (attention à l'équilibre...)
Alain c.
SHANLING M3X Digital Audio Player DAP 2x ES9219C Bluetooth MQA 32bit 384kHz DSD256 The Shanling M3X is a high quality portable music player with a well thought-out and optimized design. It is based on a powerful Qualcomm Snapdragon 430 processor, an Open...
mediocre produit !
ce produit n'est pas dans l'exellence pour le prix vendu !
plans sonore plat, aucune precision, mon Cowon plenue V est nettement et facilement au dessus quand a la qualité sonore !
la partie android est quand a elle souq alimenté par une ram rachetique de 2 GO, et audroid quand a lui utilise en moyenne
960 mo !
si l'on a comme beaucoup d'usager du materiel audio avec des fiches en 3.5 et 2.5 l'on se trouve dans l'obligation d'acheter un adaptateur
4.4 vers 3. ou 2.5 .... ce qui augemente l'enconbrement et les possible problemes de connectiques !!
donc retour a Audiphonic pour tout ces élements !
Marc B.
IFI AUDIO SUPANOVA Power Cable OFHC Copper Gold Plated Shielded with Active Noise Cancellation Technology 1.8m The impressive iFi Audio SupaNova power cable delivers incredible performance to provide your audio system with a clean and stable electrical signal. The cable features Active...
L'effet est là
Installé en amont de la multiprise sur laquelle sont branchés mon préampli et mon ampli, le son est plus propre, plus précis.
En revanche sur mon DAC Denafrips Venus II je n'ai ressenti aucune amélioration. A voir avec d'autres DACs peut-être.
Frank j.
gustard u18 very low jitter, sound the best i have heard.
at 48khz the jitter is down at -185db
ACCUSILICON AS338 110db at 10hz
where the ACCUSILICON AS318 is down 99db at 10hz
clock is important what gives the sound
crystal clear sound, all details are included, as well as 3d sound
on the neumann 310a studio monitor, one of the best, studio monitor in the world.
best dcc i have to date
have tried singxer su1 -su2 su6 as well as sotm dX-USB HD
but dcc gustard u18 beats them all
and only driven 2 hours gustard u18
gets better at 50hours
Jean-René N.
Bien mais compatibilité avec Windows 11 perfectible.
J’ai passé ma commande, le produit était en rupture de stock, je l’ai reçu 10 jours plus tard, un peu plus tôt que convenu. Emballage impeccable, comme d’habitude chez Audiophonics.
Il n’y a qu’une notice succincte en anglais, mais l’appareil est très intuitif : deux boutons, l’un on/off, l’autre pour sélectionner la source. Un potentiomètre pour le niveau de son et les basses/aigues quand on l’enfonce. J’ai essayé de connecter un caisson de basses issu d’un home-cinema, mais aucun son n’en sort. Effectivement la notice parle de caisson de basses actif, alors que le mien est passif.
Je me sers de l’ampli pour sonoriser mon bureau à partir de mon ordinateur que j’ai passé en Windows 11 à la fin de l’année 2021.
A la première connexion en USB, les derniers drivers Microsoft sont installés. Mais là, je déchante, aléatoirement, la sortie son « USB Audio-Hi-Fi » n’existe plus, il faut rebooter pour la retrouver. L’ampli n’y est probablement pour rien, mais c’est très désagréable.
Autre bizarrerie : quand je suis en visioconférence, au bout de 2-3 minutes, je suis déconnecté avec le message suivant : nouvelle caméra USB détectée. J’ai débranché à tour de rôle tous mes accessoires USB avant de me rendre compte que Windows 11 prenait l’ampli pour … une caméra. Très gênant.
Je me suis donc connecté en entrée optique où tout fonctionne correctement, mais sans avoir la profondeur des sons en basse qu’il y avait en USB.
En conclusion, un bon appareil avec un son tout à fait correct pour le prix, mais il faudra revoir la connexion en USB avec W11.
kg s.
Surprisingly good
It sounded too good when reading the specs and all comments around the web, but I couldn´t resist although I already have a good dac from Nuforce. The main reason was to be able to play DSD-files. From start I was convinced that it did sound as good as my old dac (did cost about ten times the price of Sanskrit 10th, several years ago) and it does play all DSD up to 256 without problems. Playing 512 is not possible yet, but it is a MacOS issue. And it does it great! I had a few questions and got prompt answers from audiophonics, cudos! I did change the tiny USB-cable to something mor sturdy and a bit longer. I use external power although it worked well without it. I made a blind-test to the Nuforce DAC-9 and it was impossible to hear any difference playing 24/192 or lower resolutions (DAC-9 doesn´t handle DSD). Really great sound for peanuts!
Do I recommend it? Yes
Do I recommend Audiophonics? Yes
Jerome t.
Gustard x 16
J ai acheté ce dac et il est parfait. Je l ai connecté à ma box en forçant la prise coax de celle-ci (pas aux normes) le son sort neutre mais pas froid, comme dans le réel, époustouflant !! J ai aussi relié le dac en optique a mon lecteur DVD Samsung de base avec le cordon viablue vendu sur ce site et ça m évite de payer un coax a 200 euros. Le son vaut un lecteur cd a 500 euros, que du bon. En plus je peux commander le volume vers l ampli. Franchement super.
Ludovic M.
RSS315HF-4 Impressionnant !!!
J'ai utilisé ce haut parleurs pour faire un caisson de basse reflex de 71l pour une fréquence de 23 Hz j'ai fait le svs pb 2000 pro
avec un amplis sledge sta 500d et je dois dire que le son des basses est impressionnant pour le home cinéma les explosions sont extraordinaires très puissantes que du bonheur
Jean Claude D.
Musicalité, définition, transparence.
J’utilise ce câble en bicablage et il remplace pour mon plus grand plaisir des VIARD AUDIO HD silver. Cela me donne un rendu plus favorable que des Nordost frey 2 que j’ai essayés sur mon système.
(Mac intosh D150/MC352/Audio research LS27/Klipsch forte 3)
Contrairement au schéma de la spécification, j’ai raccordé les 6 câbles à l’amplificateur ; Rouge/blanc/bleu pour le + et noir/jaune/vert pour le -, dont 2 câbles (rouge/vert) pour les médium/ tweeter et 4 câbles pour le grave.
Le résultat est une spatialisation plus accrue, le son est plus limpide, plus dynamique et plus de détail sans être fatiguant après de longues heures d’écoutes. Je découvre toute une gamme de nuance dans les graves et percussions. Les voix sont présentes et charnelles.
Avec ces câbles je redécouvre mon système et ma discothèque.
Jürg E.
Top quality Plug
Outstanding build quality and good construction. This is the best sounding Schuko plug i have tested so far. It sounds smooth, natural and organic with a lot of bass power. No harshness or edgy sibilants like some silver or rhodium plated plugs of other brands. Excellent combination with the Yarbo cable.
Jürg E.
Top Cable
This is a very balanced sounding cable. Smooth, natural, detailed and a big soundstage, Excellent cable for preamp and source components. Because of its smaller diameter, it fits all Plugs very well. Even it contains some silver as plating, it is still smooth and natural. The litz wires are sensitve bacause of its thin strands. When removing the insulation, a lot of care is needed.
Holger B.
LAN-Kabel Audiophonics, 5 m
J'utilise le câble comme connexion de la prise murale TAE au routeur comme câble DSL ! L'effet par rapport à un câble DSL normal est écrasant ! Tous les appareils de mon réseau profitent énormément de la transmission ! Acoustiquement, le câble améliore le son de mon streamer, bien numérique !
L'image sur ma TV est nettement meilleure (connexion TV via Internet !) !
Tout simplement génial...!
Yann J.
Kit intégré dans une petite enceinte passive pour créer une paire d'enceintes autonomes (1 active + 1 passive), se monte facilement, le rendu est très correct, pour l'instant l'autonomie a l'air conforme, la puissance est correcte, la portée bluetooth est d'une dizaine de mètres. Attention pour avoir un kit complet vous devez prendre 2 supports métallique (1 pour l'ampli et 1 pour la carte d'accus). De plus il vous faudra un interrupteur bistable NF (normalement fermé) car si vous ne câblez pas l'interrupteur le module reste allumé. Dommage que le prix ne soit pas un peu plus attractif.
Stephen J.
Meilleur rapport qualité / prix ?
J'ai d'abord acheté ces haut-parleurs un peu par hasard (les large bande que je voulais n'étais pas dispos, et ceux-ci semblaient intéressants). J'ai calculé de petites enceintes bass reflex en agglo de récupération, ceci avec l'objectif de remplacer les enceintes pourries dont ma fille avait hérité avec une micro chaîne. Elle pensait que c'était une lubie de ma part, mais quand je les ai branchées, elle a juste dit "Ah, d'accord...". L'ensemble n'est pas vraiment de la hifi, mais c'est agréable à écouter, un bon investissement.
Ensuite j'ai lu le commentaire de Kolja Z., que je remercie vivement ! J'ai commandé une deuxième paire de haut-parleurs, et j'ai fabriqué les Needle, en suivant les plans qu'on trouve facilement sur le net. J'ai encore utilisé de l'agglo de 15mmm (la construction était un peu sportive !), et j'ai connecté les baffles à mon ordi avec un DAC et un petit ampli classe D. Le résultat est franchement surprenant, surtout au niveau des graves compte tenu de la taille de ce tout petit haut-parleur. Il a fallu trouver un peu de place au sol, mais le son est agréable et précis avec une gamme étendue. Je sens que je vais me régaler. Ça doit être difficile de faire mieux à ce prix.
Jean-Marie M.
excellent préampli Class A
acquis sur la baie en occaz mais comme neuf... emballage au Top ! superbe équilibre, la matière est au rendez-vous doté d'une très bonne dynamique. la finition est également parfaite; merci Audiophonics pour ce produit rapport/qualité prix difficile à battre ... couplé avec un bloc de puissance Sony TA-3130F
