jevgenijs S.
Simply great!
My speakers never sounded this good! A very clear and open sound without being fatigue! The tone controls are very effective!
Reinhardt S.
VIABLUE EPC-4 Silver Balanced Interconnect Cable Ø3.9mm
sehr gute Qualität,sehr empfehlenswert
Reinhardt S.
NEUTRIK NC4MX-B 4 Gold Plated
Customers reviews - There are 20865 reviews.
philippe d.
Bon matériel polyvalent
Son plus percutant dans variations brusques, améliorations générales. Cependant, prendre garde au fait que les embouts sont vissés sans freinage. Il ne faut pas trop les serrer mais d'un autre coté, sans frein prévu, ils peuvent se débloquer en tournant à peine. Alors la liaison électrique sera basée sur le passage d'un petit filetage sans serrage. Une rondelle éventail acier ou une rondelle fine en laiton pourrait mieux bloquer ces liaisons.
Jürgen S.
J.S.
I was surprised how professional the ordering/shipping from France to Germany was handled by Audiophonics. Communication in English. Perfect information about state of order. Everything as it should. 5 Stars.
The packaging was functional but not as nice as you would expect it from a big high-end name. For me this is saving money at the right end, as I don't have the place to collect large boxes. 4 Stars.
The product looks much nicer in reality than on the pictures. The complete housing is made of brushed aluminium. Look and feel is solid, and everything you could expect is there. Trigger input, power switch/button at rear and front, well visible LED indication that it is switched on. The box gets warm when running a few hours but not hot. 5 Stars.
I opted for the small stereo board from Hypex because I like the small form factor and don't think a dual-mono solution would be audibly better. The final destination will be in a TV setting, but I made a sound check with my stereo.
My first impressions and comparison with a 5 year old dual-mono class A/B power amp in a 3000 Euro price range: I don't hear substantial differences. Bass is very clean and controlled. Possibly the highs sound slightly recessed on the Hypex amp compared to class A/B, but these differences are subtle and could as well be subjective. I am neither missing soundstage, nor separation or detail. Amazing for the price. 5 Stars.
Equipment: Topping D90 + A90 as source, 3 way LUA speakers (which require a bit of power).
All in all I can highly recommend the amp. Transparent and controlled sound for small money.
GEORGES V.
Selector 4 inputs 3 positions Ø6mm flat axis This 4-pole x3 position mechanical selector allows to switch several signals to a common point. It works in both directions, the IN can also be an OUT. The notches are...
Trop dur
selecteur de qualité mais trop dur à tourner , même avec un boutton de 40mm de diametre
Vid B.
Amazing dac
Really good dac, sonically superb. Also good support from audiophonics team.
jean-baptiste l.
C'est mon troisième... et 5 étoiles
En un an et demi de bons et loyaux services, pas un souci, même si on pouvait douter de la durabilité de la commande manuelle du potar.
Si c'est mon troisième, c'est parce que lorsque les gens l'écoutent, (après s'être tordus de rire en voyant l'aspect de la bête), ils sont suffisamment snuffés pour que je me sente obligé de leur en acheter un en cadeau.
Après avoir alimenté des Cabasse bibliothèque, l'animal me sert désormais sur des colonnes Ellipson (oui môôôôsssieu, j'achète français...sauf les amplis). Bon, c'est un peu plus dur a emmener sur des musiques exigeantes où il arrive que le petit SMSL panique - notamment sur des guitares grunge - mais de toute façon, vu le rapport qualité prix, c'est du 5 étoiles et basta.
Ouvrez bien vos oreilles et fermez la bouche, la Covid ne s'attrape pas par le pavillon
Bien à vous tous
Anne b.
NICHICON KW Electrolytic Audio Capacitor 50V 10000μF The KW series is a range of electrolytic capacitors specially designed for audio use. They offer excellent performance and technical characteristics.
condensateur nichicon
ce n est pas du tout les meme condensateur d origine je vais les employé pour autre chose un peu déçu quand meme
Christian C.
AUDIO-GD A-2 Headphone Amplifier Preamplifier Class A Discrete ACSS 2500mW The Audio-GD A-2 is a Class A headphone amplifier and preamplifier combo that takes advantage of totally discrete analog stages to offer a high quality sound reproduction that...
Bien, mais peut mieux faire
L'absence de notice est un peu gênant, l'utilisation des straps. pour modifier l'équilibre tonal n'est pas très aisé. Sur la position zéro du sélecteur de gain et volume au maximum, une tension parasite de faible amplitude et de 0,5 Hz environ apparait sur la sortie audio. Ce phénomène entraine un déplacement insolite des membranes des boomers. Ce phénomène disparait en sélectant le gain sur 1. Heureusement la qualité sonore est au rendez-vous.
Donal O.
Excellent DAC & Preamp
Great quality DAC with impressive stereo soundstage, simple but flexible menu-based configuration and uncomplicated remote control. Used as preamp, switching between USB (macbook) and TOSlink (TV), to active monitors or headphones (with independent volume control). Unbeatable quality and features at this price point.
Dominique B.
Après rodage meilleure saturation des couleurs, meilleure profondeur, TV oled Philips, box fibre orange, le tout passe par un Yamaha Rx a820
Bruno B.
Coaxial to Optical Toslink SPDIF Digital Adapter Offered at a low price, this simple SPDIF adapter will allow you to obtain a Toslink Optical signal from a Coaxial signal, for example to connect a TV or an Internet box.
Livrer en 48 heures, installation en 3 minutes, super content.
Permet de lier une television TECHWOOD avec une sortie cable SPIDF vers une barre de son SAMSUNG avec une entrée optique.
Je recommande.
Françis S.
Françis S
On peu trouver des prises de bon maintient dans le commerce de bricolage , mais pas avec des fiches qui ne s'oxydent pas dans le temp . Donc, si l'on veux une installation propre , c'est une bonne solution ,qui permet d'être sur de ses contactes .
François-Xavier L.
Alternative pertinente au marché de l'occasion
Je cherchais un intégré pour mon système DIY en tri-amplification active, le marché de l'occasion sur des références d'amplis reconnus m'ayant réservé quelques surprises par le passé...
Sur les conseils d'Audiophonics, j'ai utilisé cet ampli sur la voie médium en substitution d'un NAD C356 Bee révisé. Une fois le réglage de niveau validé à la mesure, et passé quelques jours d'écoute, je dois dire que cet ampli est une grande réussite.
L'effet stéréo est d'une toute autre mesure par rapport au NAD. C'est la différence majeure, avec une tonalité moins portée sur le bas médium et beaucoup plus de détails à l'écoute.
Autre bonus : l'encombrement réduit (je pourrais presque en mettre 3 pour l'encombrement d'un ampli hi-fi classique...).
Enfin, je n'ai pas constaté de chauffe ni de ronronnement au niveau transfo.
Recommandé !
Michel B.
Minuscule
A l'ouverture de la boîte on est surpris par la petite taille de l'appareil, il est vraiment minuscule! La qualité de fabrication est pourtant bien là. Cependant, pas la moindre trace d'un quelconque mode d'emploi. Il n'y a pas non plus de chargeur, seul un câble USB permet de raccorder une alimentation en provenance d'un port USB. L'appairage bluetooth se fait en posant le téléphone sur le boîtier, après avoir pris la précaution de mettre sur ON la fonction NFC du téléphone. Procédé extrêmement simple et rapide. Le son est parfait, un autre bon point est la rétrocompatibilité avec des appareils non équipés de codec aptX dernière génération. L'ampli casque est moyen.
En résumé, bon appareil, pratique. Tout a fait recommandable.
François G.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 8.2μF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
Condensateur Jantzen audio superior Z-cap
Condensateur de qualité utilisé sur un filtre d'ordre 2 pour des tweeters Heil AMT.
Je recommande.
GUSTARD U16 USB Digital Interface ES8620 SPDIF AES/EBU I2S HDMI LVDS Accusilicon 32bit 384kHz DSD512 The Gustard U16 is a high-end USB digital interface that integrates very high quality components into an intelligent architecture optimized to deliver exceptional sound...
Interface remarquable
Cette interface numérique s'avère efficace et la liaison USB convertie en AES/EBU est tout simplement excellente. Mon DAC a gagné en musicalité. J'avais besoin de cette interface car j'utilise un DAC qui ne possède pas de liaison USB mais seulement des liaisons toslink , coaxiale et XLR AES/UBU. Cette interface apporte vraiment un grand plus sur le message musicale.
Fabrice S.
restaurations ampli
très satisfait
Fabrice S.
LJM stereo Loudspeakers protection 15A Protection module for speaker
restaurations ampli
très satisfait
Fabrice S.
restaurations ampli
très satisfait du double module simple à mettre en œuvre
Michael A.
Preamplifier Volume Control OPA2604 This preamplifier is both simple and efficient, and benefits from a robust and high-performance design that provides high-quality, transparent and accurate audio reproduction.
The simplicity of being!
Well, 180 € is worth a game, alternatively you can still test something with a few OPA's that are out there, that was the background for my purchase decision. But what I have unpacked there was really stunning. Purely subjectively seen / heard plays completely in a different league than what you would expect here, very clear and detailed, huge foundation of structure, I know that sounds like hi-fi magazines but otherwise I can not describe it. It plays with a very high output voltage, on a UcD 180 brutal and on a KT 94 SE tube to kneel down, Incredible that it is here in a 180 € preamplifier, I know only from very high-priced equipment. Currently it runs with 1x V6 Vidid and 4x NJR Muse 8820 Dual J-FET for me a dream!
ATOHM S250-X ICE POWER Amplifier Module Class D Subwoofer 220W 4Ω The Athohm S250-X Ice Power is a Class D amplifier module for subwoofers offering excellent technical performance and great musicality. It is capable of delivering a power of...
bon achat
Je possède un caisson de la marque final. Le module de 300 w ayant décidé d'arrêter de fonctionner au bout de 15 ans, j'ai longtemps hésité à acheter un nouveau caisson. Finalement j'ai opté pour celui-ci et je suis vraiment satisfait. Par contre j'ai règlé le curseur sur "closed" et ça change vraiment tout côté dynamisme. ( hp de 26 cm de diamètre.)
Jean-Pierre L.
FX-AUDIO D802E FDA Amplifier STA326 Streamer WiFi DLNA Bluetooth 5.0 Multiroom 2x80W / 4 Ohm Silver The E version of FDA D802 amplifiers from FX Audio now includes WiFI (DLNA) connections to complement Bluetooth connectivity.
edit du 20/12/20 - défaut WIFI corrigé
après échange rapide aux frais d'audiophonics, j'ai reçu un modèle parfaitement fonctionnel, connexion WIFI immédiate, merci au support !
je confirme le plaisir constant à écouter de la musique via cet ampli, donne vie même à des MP3 moyens. Ecoute aussi bien sur des colonnes de bonne sensibilité que des bibliothèques. puissance largement suffisante.
pas mal en deux canaux spdif mais
j ai branché l extracteur entre une box upc tv et un dac audio gd r28.. sortie sur câble vialube tos link et branché sur une interface digital ifi.. ensuite un autre câble tos Link vialube au dac.. sais bon.. sais pas non plus le must. Mais le sont obtenu passe plus que bien pour écouté les chaines musical. Super sur mezzo hd..les film écouté avec se système prennent une dimension comme au cinéma. j ai des enceinte qui descende vraiment a 27hrz et sa s entant ;-)sans bavure et bien serrée. j ai amélioré encore avec le branchement r de ma box avec un pangy cuivre pl argent acheté ici..et un isolateur galvanique de qualité médical branché entre le modem et la box upc acheté en allemagne avec optimisation audio inclue pour moins de 100fr ch. Qui dit mieux. ..sais excellent.. surtout sur les émissions enregistrées en streaming.. l isolateur galvanique apporte un plus qui se ressent .. plus fluide plus net plus calme.. les graves sont bien tendue et descende bien plus bas avec énergie.. conclusion se petit extracteur ne paye pas de mine. Mais bien optimisé.. il étonne. valeur des matériels inclus l extracteur.380 fr ch douane comprise.. le prix d un switch audio bien connu ;-)
Lennart L.
Super product and quick delivery from Audiophonics.
Very good and easy to use digital eq/filter. Very good sound.
To bad it´s discontinued from the manufacturer.
Easy business and quick delivery to Sweden from Audiophonics. //Space1999
eric p.
première écoutes
merçi à AUDIOPHONICS pour la rapidité et la communication..EP
eric p.
DIP Extractor Clamp for Printed Circuit Board This clamp will allow you to simply extract the DIP components from your printed circuit boards without degrading them.
première écoutes
très bonne pince pour les opa et merçi a audiophonics pour la rapidité et le service.
eric p.
première écoutes
bonjour, je viens juste de les montés ,le son est plus propre on gagne en ouverture , les aigus sont plus fin les basses plus ferme sur mon matériel ,jais également mis un fusible sr orange .
Patrice M.
USBridge Allo signature
Après plusieurs échanges avec un technicien d'Audiophonics, j'ai choisi ce lecteur. Je l'ai associé avec l'alimentation Shanti. Associé au dac je dois dire que ce lecteur est excellent. Le système sous Volumio est simple à faire fonctionner. J'ai recyclé un vieux smartphone en guise de télécommande. Le lecteur est relié directement à ma box via un cäble RJ45 Cat 7.
Patrice M.
Dac SMSL SU-9
J'avais dématérialisé mes disques CD en Flac via Foobar 2000, et je cherchais un DAC afin de lire les fichiers sur mon ensemble Hifi.
Après analyse, je me suis penché sur ce DAC. Il est excellent. Le son est clair et détaillé. l'aiguë n'est pas agressif, le grave est très propre sans trainage. Les voix sont restituées avec beaucoup de réalisme. Beaucoup de micro détails sont présents. Je suis très satisfait de mon choix.
Dragan K.
soft and squashy :)
If you are worried about vibration affecting your component this is a simple and effective fix. It's like floating your component on pudding :) The pads are sticky and grip firmly on the surface bellow.
Dragan K.
Instant improvement
For all the theory and science i have read before getting a better power cable i was expecting an improvement. I got this cable for my integrated amplifier. So, to make sure i was not fooling myself :) i did a blind test on my wife by switching between pangea ac-14se mk2 and the stock cable and she also confirmed what i heard as well. The sound stage got deeper(further back in the room), the noise flor went down so more detail was reveled and the overall sound of instruments feels more realistic.
Power cables are not snake oil! A good power cable simply allows your amp to "breathe" properly. Replace all stock cables and your system will thank you for it and reward you with better sound.
Jean Marie L.
Casque agréable mais un peu basseux
J'ai testé entre autre ce casque sur un IBASSO DX120 acheté peu avant et comparé avec mon AKG K702 ( moins cher )
Bien sûr c'est avec mes oreilles qui sont tout sauf neuves et
" haut de gamme" à la base...
Alors et ce sera le coté négatif du MEZZE NEO 99 c'est qu'il ne fait pas le poids face à l'autre dès qu'il s'agit de musique en haute qualité et subtile... ambiance basseuse, perte de la finesse...
Par contre il est plutôt beau, léger, confortable et très sensible donc utilisable sans ampli casque et économe des batteries...
Donc super pour le tout venant : films, internet, smartphones... il permet d'écouter inversement du compressé même en 128 Kb bien mieux que l'AKG qui est plus exigeant et qui oblige à pousser bien plus le volume
Donc je l'ai gardé, un casque de plus...
Et en ce moment il vaut mieux écouter la musique que les infos si on veut rester en bonne santé...
Stephane R.
MOGAMI 2524 Asymmetrical modulation cable 0.56mm² Ø6mm The MOGAMI 2524 interconnect cable is an unbalanced interconnect cable with OFC copper conductor and shielding. It is specially designed to transmit signals from instruments...
La qualité Mogami tout simplement....
Utilisé pour réaliser un câble instrument avec deux jack Neutrik et ainsi remplacer mon câble MonsterCable. Et bien c’est le jour et la nuit, un son plus chaleureux et je redécouvre ma Les Paul avec mon tout lampe Marshall...
Christophe v.
Preampli
Très bon préamplificateur, bien construit et de qualité.
La qualité sonore est au rendez vous. Son clair, précis et détaillé. La restitution du bas registre est excellente. La séparation des canneaux se fait bien sentir, tout est sa place lors de l'écoute.
Les moins sont comme dans un autre commentaire, les lampes rouges interne qui ne servent pas à grand chose.
Moins convaincu par la section de correction de tonalité. En mode réglage de tonalité, pour ma part, je perd en qualité sonnnore, dynamique, et gain. Le son est moins naturel.
Assemblé avec mon ampli à lampe TAC,34 et mes enceintes wharfedale e50 en mode bypass, c'est un véritable régal auditif.
Satisfaction garantie avec ce petit preamplificateur dont le rapport qualité prix est bien plus que correct.
A recommender.
Jean Francois V.
Finalement une fois commandé on se demande si c'est 4A ou 5A qui sont assurés.
Pas sérieux de laisser des coquilles trompeuses...même dans l'intitulé du cadre pour écrire son avis les 2 valeurs sont mentionnées :-(
Nous vous confirmons que cette alimentation délivre jusqu'à 5A.
Denis T.
Quel son !
Je l ai monté en deux blocs avec de grosse alim et deux geous dissipateur et C est parti. Cet ampli est magique... Clair musical détaillé réaliste beaucoup de grave de la dynamique.. Je suis complètement sous le charme. Il drive les enceintes même a moins de 90db...vraiement surprenant. Audiophile assurément
Guillaume F.
Acheté pour remplacer un SMSL SA-50, il a parfaitement rempli son rôle. Construction sérieuse, le bouton face avant est pratique, avec un éclairage LED blanc sobre quand il est allumé. C'est tout léger, et ça ne chauffe pas. Assez profond par contre, vérifiez bien les mesure. Beaux borniers.
Côté musique je ne vais pas m'embarquer dans des qualificatifs ou comparaisons peu utiles. Ca sonne très bien, très précis & dynamique, mais surtout, élément objectif : disparition intégrale du bruit de fond que j'avais avec le SMSL. Là rien, nada, silence total, c'est ultra propre. Rien que pour ça l'upgrade valait le coup, et je conserve l'efficacité énergétique du classeD dont j'aurais maintenant du mal à me passer (l'ampli est allumé toute la journée).
Pour info associé à un SMSL M500 en XLR, aucun souci. Ca alimente des Dali Menuet haut la main : j'oscille entre 01 et 11 de volume sur le SMSL (sur 40 Max je crois). Il faut juste faire attention à éteindre l'ampli avant le DAC pour éviter un méchant plop.
Et le "logo made in france" fait plaisir même si on sait d'où vient le module principal ;)
Thomas M.
DC-Kabel für High End Low Noise Netzteil
Ich habe das Kabel eng verdrillt mit passendem Sleeve mit einem Oyaide Stecker konfektioniert und verwende es als DC-Kabel für mein Hoerwege-Netzteil am Auralic Aries Femto. Mit dem Kabel klingt meine Kette noch etwas feinauflösender, luftiger und vielleicht einen Tick schneller. Es zischelt nicht und produziert keine Schärfe.
Pascal M.
J’en ai même recommandés 2 autres…
Par contre ; apparemment trop tôt pour bénéficier de mes bons de réduction…
Florent K.
Ca fait le job :-)
Micro très correct pour mon utilisation et son prix.
Il est très valable pour calibrer un système d'écoute, évidement il n'offre pas les performances d'un outils de mesure de laboratoire et ne va pas concurrencer du matos pro avec un 0 de plus dans le prix.
J'ai réalisé un petit comparatif entre le behringer ECM8000 et le DaytonAudio EMM 6, que vous pouvez consulter ici :
https://fr.audiofanzine.com/homestudio/forums/t.729957,l-acoustique-de-vos-home-studios-et-les-discussions-qui-vont-avec,post.10629431.html
C'est le bon modèle
Belle qualité de fabrication. En 5m, assure la liaison entre box Orange et ordinateur fixe. Ensuite, câble optique (qui sera lui aussi changé) entre sortie ordinateur et entrée ampli stéréo. Ce produit remplace un Audioquest Forest qui n'avait pas démérité, mais qui tout de même est ici surclassé... Tout est nettement mieux ! Je ne vois donc pas dans ces conditions la nécessité de dépenser davantage pour ce genre de câble, celui concerné étant déjà excellent et valant largement certains modèles censés être supérieurs.
Simone E.
Excellent Amp
I bought this amp in order to replace a TA2024 based amp (that I consider a giant killer amp). In comparison the ncore amp has both more power and more neutral sound. Furthemore it is detailed and fast as the best digital amps are. I fed it with a smsl m500 (as preamp dac) and the result satisfied me at all.
Jean Claude L.
WBT-0681CU 24k Gold Plated OFC Pure Copper Spades Nextgen Ø7mm (Set x4) These WBT-0681Cu forks made of pure OFC Copper with 24k gold plating provide excellent conductivity and a practical and durable clamping system.
En remplacement des WBT 0660 en laiton taillé dans la masse et très solides j'ai essayé les WBT 0681 Cu elles sont plus légères mais solides la musicalité et un peu au dessus certainement du à l'apport du cuivre le prix me parait toutefois un peu élevé d'où 1 étoile en moins.
Jean Claude L.
déçu
En remplacement des WBT 0645 en laiton massif et très solide
j'ai voulu essayer les WBT 0610 Cu très légères et pour cause très peu de cuivre la structure étant en plastic elles me paraissent pas solides et le comble elles tiennent pas dans les borniers enceintes alors que les précédentes sont parfaitement verrouillées .
Certes la musicalité est un soupçon meilleure certainement du à l'apport du cuivre mais le compte n'y est pas, je regrette mon achat .
Arthur L.
Pas ébouriffant
J'ai choisi d'acheter ce produit pour ne pas entendre le démarrage de mon frigo sur mes enceintes, entre autres parasites... Et j'entends toujours mon frigo démarrer ainsi que le reste des autres parasites. Peut être qu'il bloque les parasites que je n'entends pas ?
Donc déçu, mais pas non plus outré à ce prix là.
En revanche, il faut noter que le boîtier est scellé, ce qui n'est franchement pas terrible en termes de durabilité en 2021.
Donc inutile + non modifiable = pas la peine d'acheter.
Musical mais pas universel
J'ai testé ce câble sur des B&W 702 S2 et de beaucoup plus anciennes Triangle Lyrr 222. Avec les B&W, les points suivants ont été observés : une bonne image stéréo, des timbres respectés, une absence d'agressivité, un message sonore dense et chaleureux mais aussi un grave un peu trop envahissant ainsi qu'un certain manque de spatialisation. Globalement, un résultat plutôt bon mais en retrait par rapport à mes écoutes habituelles. Avec les Triangle Lyrr 222, clairement montantes, le résultat s'est en revanche avéré tout à fait satisfaisant, le jeu des compensations fonctionnant ici pleinement. Le Mogami va donc continuer à alimenter ces enceintes. Au final, compte tenu de son prix, ce câble est vraiment surprenant. Du fait de sa signature sonore bien spécifique, il ne conviendra pas à toutes les enceintes mais dans le cadre d'une bonne association, il permettra d'obtenir d'excellents résultats.
patrick G.
Très bon produit, il faut simplement savoir l'utiliser pour le câblage.
Thomas P.
Runs as intended
Very good value for this price. Runs as intended, jitter lowered by a lot and overall a more pleasing sound. I'm using it for a TDA1541A, that is very jitter dependent and dont want to miss it there. Thumbs up !
BRUNO B.
tres satisfait !
très satisfait de ce petit baladeur audio ! je m'en sert aussi comme DAC et passerelle Bluetooth vers mon ensemble hifi ! cela marche très bien ! bien fini et construit ! très bon décodage avec la puce AKM et bien assez puissant pour une écoute avec mes intras ou casque audio ! bien pratique avec le réglage du gain ! envois rapide comme d’habitude donc merci a l’équipe audiophonics !
Raymond M.
Pas pour Sundara
Je pensais avoir tout vu (entendu plutôt) en matière d’optimisation sonore, mais je ne pensais pas que des coussinets de casques pouvaient aussi intervenir dans la partie. Mais là, si Carlos N. a découvert les bienfaits avec son HE 500, que nenni en ce qui me concerne avec mon Sundara ! Déjà, le contact du velours donne un contact plus chaud, pas très agréable, et le rendu sonore est plus étouffé, plus vers le grave au détriment des aigus. Rien à voir avec les coussinets d’origine, bien plus ouverts et neutres…
Raymond M.
Super Fiche Jack
Super fiches jack 3.5 qui m’ont permis de sauver 2 casques Grado, un 125 devenu muet avec ses cordons d’origine tellement ‘entortillés’ que sectionnés, et un 325 qui suivait le même chemin. Et par la même occasion, d’utiliser des cordons 'jack’ ‘amovibles’.
